após eu usar o comando ./configure --enable-delay-pools
tudo bem..
então eu dou um make all e acontece isso que esta abaixo:
O que eu faço???
[[email protected] /squid-2.5.STABLE4]# make all
Making all in lib
make[1]: Entering directory `/squid-2.5.STABLE4/lib´
source=´Array.c´ object=´Array.o´ libtool=no \
depfile=´.deps/Array.Po´ tmpdepfile=´.deps/Array.TPo´ \
depmode=gcc /bin/sh ../cfgaux/depcomp \
gcc -DHAVE_CONFIG_H -I. -I. -I../include -I../include -I../include -g -Wall -c `test -f Array.c || echo ´./´`Array.c
In file included from /usr/include/bits/posix1_lim.h:126,
from /usr/include/limits.h:144,
from /usr/lib/gcc-lib/i386-conectiva-linux/2.95.3/include/limits.h:117,
from /usr/lib/gcc-lib/i386-conectiva-linux/2.95.3/include/syslimits.h:7,
from /usr/lib/gcc-lib/i386-conectiva-linux/2.95.3/include/limits.h:11,
from /usr/include/sys/param.h:22,
from ../include/util.h:48,
from Array.c:52:
/usr/include/bits/local_lim.h:36: linux/limits.h: Arquivo ou diretório não encontrado
In file included from ../include/util.h:48,
from Array.c:52:
/usr/include/sys/param.h:23: linux/limits.h: Arquivo ou diretório não encontrado
/usr/include/sys/param.h:24: linux/param.h: Arquivo ou diretório não encontrado
In file included from /usr/include/netinet/in.h:212,
from /usr/include/netdb.h:28,
from ../include/util.h:51,
from Array.c:52:
/usr/include/bits/socket.h:302: asm/socket.h: Arquivo ou diretório não encontrado
make[1]: *** [Array.o] Error 1
make[1]: Leaving directory `/squid-2.5.STABLE4/lib´
make: *** [all-recursive] Error 1
