    Ola, estive tentando instalar meu modem hsp56 da pctel e ocorreu um erro durante a instalação abaixo esta descrita a saida do terminal.
    [root@localhost pctel-0.9.6]# ./configure --with-hal=cm8738 --with-kernel-includes=/usr/src/linux/include
    make
    configure: WARNING: you should use --build, --host, --target
    checking for a BSD-compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking for gawk... gawk
    checking whether make sets ${MAKE}... yes
    checking build driver for... HAL_CM8738
    checking for make-gcc... no
    checking for gcc... gcc
    checking for C compiler default output... a.out
    checking whether the C compiler works... yes
    checking whether we are cross compiling... no
    checking for suffix of executables...
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether gcc accepts -g... yes
    checking for style of include used by make... GNU
    checking dependency style of gcc... none
    checking whether make sets ${MAKE}... (cached) yes
    checking whether ln -s works... yes
    checking for gawk... (cached) gawk
    checking how to run the C preprocessor... gcc -E
    checking for ANSI C header files... yes
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking /usr/src/linux/include/linux/modversions.h usability... no
    checking /usr/src/linux/include/linux/modversions.h presence... no
    checking for /usr/src/linux/include/linux/modversions.h... no
    configure: error: modversions.h is missing - you should configure your kernel first!
    Se alguem puder me ajudar com isso agradeço.
    Ps: A distro que estou utilizando é a Red Hat 9. Por favor alguem me ajude!!!!!!
  2. Ola anonimo , entao ja houviu falar em recompilar o kernel?
    hiihhihiohohoohhohohohuhuhuhuhuhu
    entao , modversions.h isso que seu log esta soltando de erro , entao trata de compilar o kernel com ele =]
    sabe recompilar?
    abracos
    Rooter
    Me corrijam se eu estiver errado, mas isso não seria a falta do kernel-headers ?
    Cara não faço ideia de como compilar o kernel??
    Não sei se percebeu sou iniciante...hehhe
    Valhalla
    Se não me falhe a memória o comando p/ recompilar é algo como makemenuconfig <IMG SRC="images/forum/icons/icon_eek.gif">
  1. Erro na instalação do Red Hat 9
    Por luiz_nando no fórum Servidores de Rede
    Respostas: 6
    Último Post: 03-03-2004, 07:31
  2. Erro na instalação do Red Hat 9
    Último Post: 03-03-2004, 06:17
  3. Erro na instalação do logrep para analisar Snort?
    Por Hacinn no fórum Segurança
    Último Post: 05-12-2003, 07:12
  4. erro na instalação do postfix
    Último Post: 30-10-2003, 12:27
  5. msg de erro na instalacao do modulo Archive::Zip... o que eh
    Por fisicko no fórum Servidores de Rede
    Último Post: 15-08-2003, 14:09
