    guardian_metal
    Padrão Dúvidas DNS (Configuração)
    Segui as dicas do site para configurar o DNS (HOW TO DNS) e abaixo estão meus arquivos de configuração. Como sei se o DNS está funcionando?.
    lasertools.conf
    zone "lasertools.laser.br" {
    type master;
    file "zone/db.lasertools";
    zone "4.172.168.192.in-addr.arpa" {
    type master;
    file "zone/rev.lasertools";
    db.lasertools
    $TTL 86400
    @ IN SOA lasertools.laser.br. postmaster.lasertools.laser.br. (
    2003090200 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    @ IN NS lasertools.laser.br.
    @ IN NS ns.lasertools.laser.br.
    lasertools.laser.br. IN A 192.168.172.4
    ns.lasertools.laser.br. IN A 192.168.172.4
    ftp IN A 192.168.172.4
    www IN CNAME lasertools.laser.br.
    mail IN A 192.168.172.4
    @ IN MX 5 mail.lasertools.laser.br.
    pop IN CNAME mail.lasertools.laser.br.
    smtp IN CNAME mail.lasertools.laser.br.
    rev.lasertools
    $TTL 86400
    2003092002 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    4.172.168.192.in-addr.arpa. IN PTR lasertools.laser.br.
    named.conf
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    // a caching only nameserver config
    controls {
    inet 127.0.0.1 allow { localhost; } keys { rndckey; };
    zone "." IN {
    type hint;
    file "named.ca";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    allow-update { none; };
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    include "/etc/rndc.key";
    include "/var/named/primary/lasertools.conf";
    Jul 2001
    Campinas Area
    ps ax |grep named
    guardian_metal
    Digitei o comando que estava no artigo "HOW TO DNS" e o comando que o psy me passou e apareceu o seguinte:
    [[email protected] root]# ps ax |grep named
    817 ? S 0:00 [named]
    3337 pts/1 S 0:00 grep named
    [[email protected] root]# dig lasertools.laser.br
    ; <<>> DiG 9.2.1 <<>> lasertools.laser.br
    ;; global options: printcmd
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 13286
    ;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
    ;; QUESTION SECTION:
    ;lasertools.laser.br. IN A
    ;; Query time: 31 msec
    ;; SERVER: 200.204.0.10#53(200.204.0.10)
    ;; WHEN: Fri Dec 12 09:35:26 2003
    ;; MSG SIZE rcvd: 37
    Isso significa que o DNS está configurado e funcionando?.
    guardian_metal
    Fiz mais algumas mudanças, no resolv.conf em /etc eu coloquei "nameserver 192.168.172.4" e dei os comandos novamente e encontrei os resultados abaixo, preciso configurar mais algum arquivo ou o DNS ja está funcionando?.
    4995 pts/1 S 0:00 grep named
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 20365
    ;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 1
    ;; ANSWER SECTION:
    lasertools.laser.br. 86400 IN A 192.168.172.4
    ;; AUTHORITY SECTION:
    lasertools.laser.br. 86400 IN NS ns.lasertools.laser.br.
    lasertools.laser.br. 86400 IN NS lasertools.laser.br.
    ;; ADDITIONAL SECTION:
    ns.lasertools.laser.br. 86400 IN A 192.168.172.4
    ;; Query time: 1 msec
    ;; SERVER: 192.168.172.4#53(192.168.172.4)
    ;; WHEN: Fri Dec 12 10:02:48 2003
    ;; MSG SIZE rcvd: 100
    [[email protected] root]# ping lasertools.laser.br
    PING lasertools.laser.br (192.168.172.4) 56(84) bytes of data.
    64 bytes from lasertools.laser.br (192.168.172.4): icmp_seq=1 ttl=64 time=0.047 ms
    64 bytes from lasertools.laser.br (192.168.172.4): icmp_seq=2 ttl=64 time=0.047 ms
    64 bytes from lasertools.laser.br (192.168.172.4): icmp_seq=3 ttl=64 time=0.050 ms
    64 bytes from lasertools.laser.br (192.168.172.4): icmp_seq=4 ttl=64 time=0.054 ms
    --- lasertools.laser.br ping statistics ---
    4 packets transmitted, 4 received, 0% packet loss, time 3002ms
    rtt min/avg/max/mdev = 0.047/0.049/0.054/0.007 ms
    [root[email protected] root]#
    Jul 2001
    Campinas Area
    Exatamente
