    Padrão ajuda num pptp client
    eu tentei rodar o pptp pra conectar no modem ( alcatel - brasiltelecom - adsl )
    abaixo estao as confs e o log do ./pptp valeww
    ppp.conf
    set authname [email protected]
    set authkey minhasenha
    set timeout 0
    set log Phase Chat IPCP CCP tun command
    set ifaddr 10.0.0.138/0 255.255.255.0
    add default HISADDR
    options
    lock
    updetach
    noipdefault
    usepeerdns
    defaultroute
    debug
    auth
    proxyarp
    modem
    crtscts
    lcp-echo-interval 30
    lcp-echo-failure 4
    pap-secrets
    # Secrets for authentication using PAP
    # client server secret IP addresses
    [email protected] * aleizarg 10.0.0.138 RELAY_PPP1
    chap-secrets
    # Secrets for authentication using CHAP
    log do ./pptp
    [[email protected] sbin]# ./pptp 10.0.0.138
    using channel 11
    Using interface ppp0
    Connect: ppp0 <--> /dev/pts/4
    sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x11a03886> <pcomp> <accomp>]
    rcvd [LCP ConfReq id=0x75 <mru 9178> <auth pap> <magic 0xe814590>]
    sent [LCP ConfRej id=0x75 <auth pap>]
    rcvd [LCP ConfReq id=0x76 <mru 9178> <magic 0xe814590>]
    sent [LCP ConfAck id=0x76 <mru 9178> <magic 0xe814590>]
    rcvd [LCP TermReq id=0x77]
    sent [LCP TermAck id=0x77]
    rcvd [LCP ConfReq id=0x28 <mru 9178> <auth pap> <magic 0x4e888548>]
    sent [LCP ConfRej id=0x28 <auth pap>]
    rcvd [LCP ConfReq id=0x29 <mru 9178> <magic 0x4e888548>]
    sent [LCP ConfAck id=0x29 <mru 9178> <magic 0x4e888548>]
    rcvd [LCP TermReq id=0x2a]
    sent [LCP TermAck id=0x2a]
    rcvd [LCP ConfReq id=0x95 <mru 9178> <auth pap> <magic 0x5d92cbf5>]
    sent [LCP ConfRej id=0x95 <auth pap>]
    rcvd [LCP ConfReq id=0x96 <mru 9178> <magic 0x5d92cbf5>]
    sent [LCP ConfAck id=0x96 <mru 9178> <magic 0x5d92cbf5>]
    rcvd [LCP TermReq id=0x97]
    sent [LCP TermAck id=0x97]
    rcvd [LCP ConfReq id=0x6a <mru 9178> <auth pap> <magic 0x5fd5bc73>]
    sent [LCP ConfRej id=0x6a <auth pap>]
    rcvd [LCP ConfReq id=0x6b <mru 9178> <magic 0x5fd5bc73>]
    sent [LCP ConfAck id=0x6b <mru 9178> <magic 0x5fd5bc73>]
    rcvd [LCP TermReq id=0x6c]
    sent [LCP TermAck id=0x6c]
    rcvd [LCP ConfReq id=0x37 <mru 9178> <auth pap> <magic 0x68ef99e8>]
    sent [LCP ConfRej id=0x37 <auth pap>]
    rcvd [LCP ConfReq id=0x38 <mru 9178> <magic 0x68ef99e8>]
    sent [LCP ConfAck id=0x38 <mru 9178> <magic 0x68ef99e8>]
    rcvd [LCP TermReq id=0x39]
    sent [LCP TermAck id=0x39]
    rcvd [LCP ConfReq id=0x8c <mru 9178> <auth pap> <magic 0x7f3b445d>]
    sent [LCP ConfRej id=0x8c <auth pap>]
    rcvd [LCP ConfReq id=0x8d <mru 9178> <magic 0x7f3b445d>]
    sent [LCP ConfAck id=0x8d <mru 9178> <magic 0x7f3b445d>]
    rcvd [LCP TermReq id=0x8e]
    sent [LCP TermAck id=0x8e]
    rcvd [LCP ConfReq id=0x6d <mru 9178> <auth pap> <magic 0x2f6b37>]
    sent [LCP ConfRej id=0x6d <auth pap>]
    rcvd [LCP ConfReq id=0x6e <mru 9178> <magic 0x2f6b37>]
    sent [LCP ConfAck id=0x6e <mru 9178> <magic 0x2f6b37>]
    rcvd [LCP TermReq id=0x6f]
    sent [LCP TermAck id=0x6f]
    rcvd [LCP ConfReq id=0xe3 <mru 9178> <auth pap> <magic 0x28983b25>]
    sent [LCP ConfRej id=0xe3 <auth pap>]
    rcvd [LCP ConfReq id=0xe4 <mru 9178> <magic 0x28983b25>]
    sent [LCP ConfAck id=0xe4 <mru 9178> <magic 0x28983b25>]
    rcvd [LCP TermReq id=0xe5]
    sent [LCP TermAck id=0xe5]
    rcvd [LCP ConfReq id=0xe <mru 9178> <auth pap> <magic 0x68a77996>]
    sent [LCP ConfRej id=0xe <auth pap>]
    rcvd [LCP ConfReq id=0xf <mru 9178> <magic 0x68a77996>]
    sent [LCP ConfAck id=0xf <mru 9178> <magic 0x68a77996>]
    rcvd [LCP TermReq id=0x10]
    sent [LCP TermAck id=0x10]
    rcvd [LCP ConfReq id=0xac <mru 9178> <auth pap> <magic 0x18c11f80>]
    sent [LCP ConfRej id=0xac <auth pap>]
    rcvd [LCP ConfReq id=0xad <mru 9178> <magic 0x18c11f80>]
    sent [LCP ConfAck id=0xad <mru 9178> <magic 0x18c11f80>]
    rcvd [LCP TermReq id=0xae]
    sent [LCP TermAck id=0xae]
    LCP: timeout sending Config-Requests
    Connection terminated.
    []´z
    Valew
    Não entendi absolutamente nada vc pode ser mais claro meu amigo.
    <IMG SRC="images/forum/icons/icon21.gif">
