  1. eu tentei rodar o pptp pra conectar no modem ( alcatel - brasiltelecom - adsl )
    abaixo estao as confs e o log do ./pptp valeww
    ppp.conf
    set authname di_vera@brturbo.com
    set authkey minhasenha
    set timeout 0
    set log Phase Chat IPCP CCP tun command
    set ifaddr 10.0.0.138/0 255.255.255.0
    add default HISADDR
    options
    lock
    updetach
    noipdefault
    usepeerdns
    defaultroute
    debug
    auth
    proxyarp
    modem
    crtscts
    lcp-echo-interval 30
    lcp-echo-failure 4
    pap-secrets
    # Secrets for authentication using PAP
    # client server secret IP addresses
    di_vera@brturbo.com * senha 10.0.0.138 RELAY_PPP1
    chap-secrets
    # Secrets for authentication using CHAP
    log do ./pptp
    [root@skynet sbin]# ./pptp 10.0.0.138
    using channel 11
    Using interface ppp0
    Connect: ppp0 <--> /dev/pts/4
    sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x11a03886> <pcomp> <accomp>]
    rcvd [LCP ConfReq id=0x75 <mru 9178> <auth pap> <magic 0xe814590>]
    sent [LCP ConfRej id=0x75 <auth pap>]
    rcvd [LCP ConfReq id=0x76 <mru 9178> <magic 0xe814590>]
    sent [LCP ConfAck id=0x76 <mru 9178> <magic 0xe814590>]
    rcvd [LCP TermReq id=0x77]
    sent [LCP TermAck id=0x77]
    rcvd [LCP ConfReq id=0x28 <mru 9178> <auth pap> <magic 0x4e888548>]
    sent [LCP ConfRej id=0x28 <auth pap>]
    rcvd [LCP ConfReq id=0x29 <mru 9178> <magic 0x4e888548>]
    sent [LCP ConfAck id=0x29 <mru 9178> <magic 0x4e888548>]
    rcvd [LCP TermReq id=0x2a]
    sent [LCP TermAck id=0x2a]
    rcvd [LCP ConfReq id=0x95 <mru 9178> <auth pap> <magic 0x5d92cbf5>]
    sent [LCP ConfRej id=0x95 <auth pap>]
    rcvd [LCP ConfReq id=0x96 <mru 9178> <magic 0x5d92cbf5>]
    sent [LCP ConfAck id=0x96 <mru 9178> <magic 0x5d92cbf5>]
    rcvd [LCP TermReq id=0x97]
    sent [LCP TermAck id=0x97]
    rcvd [LCP ConfReq id=0x6a <mru 9178> <auth pap> <magic 0x5fd5bc73>]
    sent [LCP ConfRej id=0x6a <auth pap>]
    rcvd [LCP ConfReq id=0x6b <mru 9178> <magic 0x5fd5bc73>]
    sent [LCP ConfAck id=0x6b <mru 9178> <magic 0x5fd5bc73>]
    rcvd [LCP TermReq id=0x6c]
    sent [LCP TermAck id=0x6c]
    rcvd [LCP ConfReq id=0x37 <mru 9178> <auth pap> <magic 0x68ef99e8>]
    sent [LCP ConfRej id=0x37 <auth pap>]
    rcvd [LCP ConfReq id=0x38 <mru 9178> <magic 0x68ef99e8>]
    sent [LCP ConfAck id=0x38 <mru 9178> <magic 0x68ef99e8>]
    rcvd [LCP TermReq id=0x39]
    sent [LCP TermAck id=0x39]
    rcvd [LCP ConfReq id=0x8c <mru 9178> <auth pap> <magic 0x7f3b445d>]
    sent [LCP ConfRej id=0x8c <auth pap>]
    rcvd [LCP ConfReq id=0x8d <mru 9178> <magic 0x7f3b445d>]
    sent [LCP ConfAck id=0x8d <mru 9178> <magic 0x7f3b445d>]
    rcvd [LCP TermReq id=0x8e]
    sent [LCP TermAck id=0x8e]
    rcvd [LCP ConfReq id=0x6d <mru 9178> <auth pap> <magic 0x2f6b37>]
    sent [LCP ConfRej id=0x6d <auth pap>]
    rcvd [LCP ConfReq id=0x6e <mru 9178> <magic 0x2f6b37>]
    sent [LCP ConfAck id=0x6e <mru 9178> <magic 0x2f6b37>]
    rcvd [LCP TermReq id=0x6f]
    sent [LCP TermAck id=0x6f]
    rcvd [LCP ConfReq id=0xe3 <mru 9178> <auth pap> <magic 0x28983b25>]
    sent [LCP ConfRej id=0xe3 <auth pap>]
    rcvd [LCP ConfReq id=0xe4 <mru 9178> <magic 0x28983b25>]
    sent [LCP ConfAck id=0xe4 <mru 9178> <magic 0x28983b25>]
    rcvd [LCP TermReq id=0xe5]
    sent [LCP TermAck id=0xe5]
    rcvd [LCP ConfReq id=0xe <mru 9178> <auth pap> <magic 0x68a77996>]
    sent [LCP ConfRej id=0xe <auth pap>]
    rcvd [LCP ConfReq id=0xf <mru 9178> <magic 0x68a77996>]
    sent [LCP ConfAck id=0xf <mru 9178> <magic 0x68a77996>]
    rcvd [LCP TermReq id=0x10]
    sent [LCP TermAck id=0x10]
    rcvd [LCP ConfReq id=0xac <mru 9178> <auth pap> <magic 0x18c11f80>]
    sent [LCP ConfRej id=0xac <auth pap>]
    rcvd [LCP ConfReq id=0xad <mru 9178> <magic 0x18c11f80>]
    sent [LCP ConfAck id=0xad <mru 9178> <magic 0x18c11f80>]
    rcvd [LCP TermReq id=0xae]
    sent [LCP TermAck id=0xae]
    LCP: timeout sending Config-Requests
    Connection terminated.
    [root@skynet sbin]#
    []´z
    Valew
    estanisgeyer
    Qual é o modelo do Alcatel?
    Ele suporte PPOE?
    Caso não suporte, faça-o em modo bridge e use o pacote rp-ppoe para conectar.
    []&acute;s
    Marcelo Estanislau.
  3. alcatel speed touch pro
    ele suporta pppoe
    sim!
    o q devo fazer?
  4. acho q a brasiltelecom naum trabalha com PPPOE....
    mas voi se te explicar como fazer o q o estanisgeyer disse...... (mas antes tem que confirmar isso com a brasiltelecom.... tenho quase certeza q naum vai funciona)
    ve se vc já tem instalado o rp-pppoe.......
    se vc já tiver instalado tenta executar o adsl-setup
    ai vc configura....
    e pra iniciar a conexão adsl-start
  5. a brasiltelecom aceita pppoe o modem ta pra pptp
    configurei o ppoe e olha só o q deu
    [root@skynet sbin]# ./adsl-setup
    Welcome to the Roaring Penguin ADSL client setup. First, I will run
    some checks on your system to make sure the PPPoE client is installed
    properly...
    Looks good! Now, please enter some information:
    USER NAME
    >>> Enter your PPPoE user name (default di_vera@brturbo.com):
    INTERFACE
    >>> Enter the Ethernet interface connected to the ADSL modem
    For Solaris, this is likely to be something like /dev/hme0.
    For Linux, it will be ethn, where &acute;n&acute; is a number.
    (default eth0):
    Do you want the link to come up on demand, or stay up continuously?
    If you want it to come up on demand, enter the idle time in seconds
    after which the link should be dropped. If you want the link to
    stay up permanently, enter &acute;no&acute; (two letters, lower-case.)
    NOTE: Demand-activated links do not interact well with dynamic IP
    addresses. You may have some problems with demand-activated links.
    >>> Enter the demand value (default no): no
    DNS
    Please enter the IP address of your ISP&acute;s primary DNS server.
    If your ISP claims that &acute;the server will provide DNS addresses&acute;,
    enter &acute;server&acute; (all lower-case) here.
    If you just press enter, I will assume you know what you are
    doing and not modify your DNS setup.
    >>> Enter the DNS information here: 200.199.241.38
    Please enter the IP address of your ISP&acute;s secondary DNS server.
    If you just press enter, I will assume there is only one DNS server.
    >>> Enter the secondary DNS server address here: 200.199.241.17
    PASSWORD
    >>> Please enter your PPPoE password:
    >>> Please re-enter your PPPoE password:
    FIREWALLING
    Please choose the firewall rules to use. Note that these rules are
    very basic. You are strongly encouraged to use a more sophisticated
    firewall setup; however, these will provide basic security. If you
    are running any servers on your machine, you must choose &acute;NONE&acute; and
    set up firewalling yourself. Otherwise, the firewall rules will deny
    access to all standard servers like Web, e-mail, ftp, etc. If you
    are using SSH, the rules will block outgoing SSH connections which
    allocate a privileged source port.
    The firewall choices are:
    0 - NONE: This script will not set any firewall rules. You are responsible
    for ensuring the security of your machine. You are STRONGLY
    recommended to use some kind of firewall rules.
    1 - STANDALONE: Appropriate for a basic stand-alone web-surfing workstation
    2 - MASQUERADE: Appropriate for a machine acting as an Internet gateway
    for a LAN
    >>> Choose a type of firewall (0-2): NONE
    Please enter a number from 0 to 2
    for a LAN
    >>> Choose a type of firewall (0-2): 0
    ** Summary of what you entered **
    Ethernet Interface: eth0
    User name: di_vera@brturbo.com
    Activate-on-demand: No
    Primary DNS: 200.199.241.38
    Secondary DNS: 200.199.241.17
    Firewalling: NONE
    >>> Accept these settings and adjust configuration files (y/n)? y
    Adjusting /etc/ppp/pppoe.conf
    Adjusting /etc/resolv.conf
    (But first backing it up to /etc/resolv.conf-bak)
    Adjusting /etc/ppp/pap-secrets and /etc/ppp/chap-secrets
    (But first backing it up to /etc/ppp/pap-secrets-bak)
    (But first backing it up to /etc/ppp/chap-secrets-bak)
    Congratulations, it should be all set up!
    Type &acute;adsl-start&acute; to bring up your ADSL link and &acute;adsl-stop&acute; to bring
    it down. Type &acute;adsl-status&acute; to see the link status.
    [root@skynet sbin]# ./adsl-start
    ................TIMED OUT
    ./adsl-start: line 192: 1214 Terminado $CONNECT "$@" >/dev/null 2>&1
    [root@skynet sbin]#
  1. Quero usar o sudo para adsl-start más não funciona direito?
    Por cROMADO no fórum Servidores de Rede
    Respostas: 7
    Último Post: 25-04-2006, 20:43
  2. Radius + ADSL + Simultaneous-Login nao funciona
    Por nod3vic3 no fórum Servidores de Rede
    Último Post: 17-10-2005, 19:00
  3. ADSL - Internet não funciona
    Por micaias no fórum Servidores de Rede
    Último Post: 06-02-2005, 09:45
  4. Bloqueio SSH nao funciona! me ajudem!
    Por Felipe_ no fórum Servidores de Rede
    Respostas: 8
    Último Post: 29-08-2004, 10:39
  5. E a ADSL no Conectiva 8 não funciona ....
    Por pssgyn no fórum Servidores de Rede
    Respostas: 6
    Último Post: 03-12-2003, 13:24
