    Padrão erro estranho no arquivo /var/log/messages
    Galera!
    Help-me!!!!
    O meu proxy squid está funcionando derepente ele para e notei que quando ele para de funcionar "tail -f /var/log/squid/access.log" , este arquivo não recebe nenhuma requisição notei que no /var/log/messages são geradas as seguintes mensagens de erro:
    Dez 17 19:16:06 colpmc70 squid: Project-Id-Version: PO-Revision-Date: YYYY-MM-DD HH:MM TZO DST Last-Translator: Language-Team: <[email protected]> MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8-bit succeeded
    Dez 17 19:42:44 colpmc70 squid: Project-Id-Version: PO-Revision-Date: YYYY-MM-DD HH:MM TZO DST Last-Translator: Language-Team: <[email protected]> MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8-bit succeeded
    Dec 17 19:43:07 colpmc70 squid[32574]: Squid Parent: child process 32682 exited due to signal 15
    Dez 17 19:43:07 colpmc70 squid: Project-Id-Version: PO-Revision-Date: YYYY-MM-DD HH:MM TZO DST Last-Translator: Language-Team: <[email protected]> MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8-bit succeeded
    Dec 17 19:43:10 colpmc70 squid[32574]: Squid Parent: child process 392 started
    Dec 17 19:43:57 colpmc70 sshd[419]: Could not reverse map address 172.16.64.3.
    Dec 17 19:44:00 colpmc70 sshd[419]: Accepted password for waltair from 172.16.64.3 port 1123
    Dec 17 19:44:00 colpmc70 sshd(pam_unix)[419]: session opened for user waltair by (uid=0)
    Dez 17 19:44:07 colpmc70 su(pam_unix)[433]: session opened for user root by waltair(uid=501)
    Dez 17 19:51:42 colpmc70 squid: Project-Id-Version: PO-Revision-Date: YYYY-MM-DD HH:MM TZO DST Last-Translator: Language-Team: <[email protected]> MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8-bit succeeded
    Dec 17 19:52:14 colpmc70 squid[32574]: Squid Parent: child process 392 exited with status 0
    Alguém já viu isso???
    Obrigado pelas dicas!!
    experimente da esse comando
    squid -z , e veja se existe algum probelma com ele !!!, o que tudo indica é o squid está saindo por alguma razao, elas podem ser pelo os arquivos logs estão cheios, o diretorio de cache tb pode está cheio. Verifique tb o log em /var/log/squid/cache.log
    fui
    ok!
    vou checar as suas dicas.
    O arquivo de log cheio é difícil pois tenho um script que limpa os arquivos de log todos os dias.
    Mas vou fazer outros testes aqui...obrigado.
    falow.
    Shi!!!!
    Esqueci de me logar.
    VAleu.
