- Samba - me ajudem
Samba - me ajudem
Pessoal...instalei o slack 9.1...fui criar uma conta no samba e nao encontrei o smbsdduser, como faco pra criar um usuario no samba...
Obrigado
Samba - me ajudem
man smbpasswd
-a This option specifies that the username following
should be added to the local smbpasswd file, with
the new password typed. This option is ignored if
the username specified already exists in the smb-
passwd file and it is treated like a regular change
password command. Note that the user to be added
must already exist in the system password file
(usually /etc/passwd) else the request to add the
user will fail.
easy way:
smbpasswd -a user
Samba - me ajudem
Desculpe...mas nao entendi...ja tenho uma conta chamada "usuario" no linux, como crio ela no samba?? ou estou boiando...
olhe
smbpasswd -a <user>
facil facil ! :wink:
Samba - me ajudem
Use o command:
smbpasswd -a nome_user
Valeu?
