    marcelloduarte
    Padrão Erro "Cannot open HTTP Port" no SQUID !!!! *URGENT
    Alguem sabe o que pode ser esse erro:
    2004/01/30 16:12:29| Starting Squid Cache version 2.5.STABLE1 for i686-pc-linux-gnu...
    2004/01/30 16:12:29| Process ID 2910
    2004/01/30 16:12:29| With 1024 file descriptors available
    2004/01/30 16:12:29| Performing DNS Tests...
    2004/01/30 16:12:29| Successful DNS name lookup tests...
    2004/01/30 16:12:29| DNS Socket created at 0.0.0.0, port 1040, FD 5
    2004/01/30 16:12:29| Adding nameserver 200.176.2.10 from /etc/resolv.conf
    2004/01/30 16:12:29| Adding nameserver 200.176.2.12 from /etc/resolv.conf
    2004/01/30 16:12:29| Unlinkd pipe opened on FD 10
    2004/01/30 16:12:29| Swap maxSize 102400 KB, estimated 7876 objects
    2004/01/30 16:12:29| Target number of buckets: 393
    2004/01/30 16:12:29| Using 8192 Store buckets
    2004/01/30 16:12:29| Max Mem size: 8192 KB
    2004/01/30 16:12:29| Max Swap size: 102400 KB
    2004/01/30 16:12:29| Rebuilding storage in /var/cache/squid (DIRTY)
    2004/01/30 16:12:29| Using Least Load store dir selection
    2004/01/30 16:12:29| Set Current Directory to /var/cache/squid
    2004/01/30 16:12:29| Loaded Icons.
    2004/01/30 16:12:29| commBind: Cannot bind socket FD 12 to *:3128: (98) Address already in use
    FATAL: Cannot open HTTP Port
    Squid Cache (Version 2.5.STABLE1): Terminated abnormally.
    CPU Usage: 0.540 seconds = 0.430 user + 0.110 sys
    Maximum Resident Size: 0 KB
    Page faults with physical i/o: 467
    Memory usage for squid via mallinfo():
    total space in arena: 11564 KB
    Ordinary blocks: 11555 KB 2 blks
    Small blocks: 0 KB 1 blks
    Holding blocks: 200 KB 1 blks
    Free Small blocks: 0 KB
    Free Ordinary blocks: 8 KB
    Total in use: 11755 KB 102%
    Total free: 9 KB 0%
    2
    Conectiva 9, squid 2.5.1
    Abutre
    Cara,
    Vc precisa postar o seu squid.conf pra gente dar uma olhada !!!!
    Abutre
    realmente assim não da para saber o que é.... mas pode ser algum pau na conf do squid mas tb ve se naum é o firewall.
    marcelloduarte
    Padrão ....
    Ai vai meu squid.conf:
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    #--- ACL's da rede interna
    acl agrottha.com src 192.168.1.0/24
    acl ipslivres src 192.168.1.200 192.168.1.10 192.168.1.140 192.168.1.180 192.168.1.190
    acl block url_regex -i "/etc/squid/bloqueados/block.txt"
    acl unblock url_regex -i "/etc/squid/abertos/unblock.txt"
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow ipslivres
    http_access deny block !unblock
    http_access allow agrottha.com
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    Fora as opções padrão. Na primeira tinha funcionado ....
    marcelloduarte
    Padrão certo
    Bom não sei como , mas parece que resolvi o problema.
    O que fiz foi desinstalar o squid intalar de novo e configura o squid.conf manualmente, sem colar nada....talvez esse arquivo de algum pau quando se cola....utilizei o vi .
    Valeu a ajuda de todos.
