    wmerlin
    Padrão Nvidia driver no debian
    Recompilei o Kernel, to rodando agora o 2.6.2 a porcaria do driver da nvidia
    continua alegando que não determinou a versão do kernel, repito to rodando o
    Debian R2, kernel 2.6.2 minha placa de video é uma fx5200 to tentando
    instalar o driver da nvidia e o driver me retorna a seguinte msg de erro.
    nvidia-installer log file '/var/log/nvidia-installer.log'
    creation time: Mon Feb 16 09:10:57 2004
    option status:
    license pre-accepted : false
    update : false
    force update : false
    expert : false
    uninstall : false
    driver info : false
    no precompiled interface: false
    no ncurses color : false
    query latest driver ver : false
    OpenGL header files : false
    no questions : false
    silent : false
    XFree86 install prefix : /usr/X11R6
    OpenGL install prefix : /usr
    Installer install prefix: /usr
    kernel source path : (not specified)
    kernel install path : (not specified)
    proc mount point : /proc
    ui : (not specified)
    tmpdir : /tmp
    ftp site : ftp://download.nvidia.com
    Using: nvidia-installer ncurses user interface
    -> License accepted.
    -> No precompiled kernel interface was found to match your kernel; would you
    li
    ke the installer to attempt to download a kernel interface for your
    kernel f
    rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: No)
    -> No precompiled kernel interface was found to match your kernel; this
    means
    that the installer will need to compile a new kernel interface.
    -> Kernel source path: '/usr/src/linux'
    -> Performing cc_version_check with CC="cc".
    ERROR: Unable to determine the NVIDIA kernel module filename.
    ERROR: Installation has failed. Please see the file
    '/var/log/nvidia-installer.log' for details. You may find
    suggestions
    on fixing installation problems in the README available on the Linux
    driver download page at www.nvidia.com.
    Isso é por que o driver da nvidea está compilado para o kernel 2.4
    Tente verificar se este driver já não está imbutido no kernel 2.6
