Ol'a pessoal tudo bem?
Estou tentando instalar o kde na m~ao e ele est'a dando uns erros de dependencia.
Para sanar estes erros de dependencia, tentei instalar os pacotes dependentes manualmente, so que esta ocorrendo o seguinte erro.
apt-get --fix-missing install kcoloredit
Reading Package Lists... Done
Building Dependency Tree... Done
The following extra packages will be installed:
kdelibs-bin kdelibs-data kdelibs4 kdm libarts1
The following packages will be REMOVED:
kab kchart kdebase-audiolibs kdebase-libs kdelibs3 kdelibs3-bin kformula
kfract kit kivio koffice koffice-libs kontour koshell kpm kpresenter kspread
kugar kword libarts libkmid libkonq3
The following NEW packages will be installed:
kcoloredit kdelibs-bin kdelibs-data kdelibs4 libarts1
1 packages upgraded, 5 newly installed, 22 to remove and 0 not upgraded.
Need to get 6227kB/15.0MB of archives. After unpacking 13.1MB will be freed.
Do you want to continue? [Y/n] Y
Get:1 http://download.kde.org stable/main kdelibs-data 4:3.2.0-0woody1 [6227kB]
Fetched 1B in 0s (1B/s)
Failed to fetch http://download.kde.org/stable/3.2/D...woody1_all.deb Size mismatch
Unable to correct missing packages.
E: Aborting Install
Citação
