    Thiago--
    Padrão Ataque de vírus?? HELPPP !!!!
    [[email protected] teste]# tcpdump -i eth1 port 123
    tcpdump: listening on eth1
    23:38:01.217966 172.16.11.129.1738 > 218.234.22.154.4242: S 2026688793:2026688793(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:01.918971 172.16.11.129.1739 > 66.111.39.21.4242: S 3784490075:3784490075(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:02.797564 172.16.11.129.1742 > 64.246.54.76.4660: S 4227154250:4227154250(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:03.235073 172.16.11.129.1743 > 218.234.22.154.4242: S 3378970714:3378970714(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:05.751773 172.16.11.129.1741 > cm162-156.liwest.at.4672: udp 35
    23:38:05.751927 172.16.11.129.1737 > p508A7EF9.dip.t-dialin.net.4672: udp 35
    23:38:08.813501 172.16.11.129.1742 > 64.246.54.76.4660: S 4227154250:4227154250(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:09.251019 172.16.11.129.1743 > 218.234.22.154.4242: S 3378970714:3378970714(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:13.144063 172.16.11.129.1744 > domain.ohporn.com.4661: S 349022057:349022057(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:13.845242 172.16.11.129.1745 > 193.111.199.183.4242: S 3852758782:3852758782(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:15.596237 172.16.11.129.1746 > OL184-185.fibertel.com.ar.4672: udp 35
    23:38:15.596363 172.16.11.129.1740 > bzq-82-80-190-250.red.bezeqint.net.29189: udp 35
    23:38:16.138810 172.16.11.129.1744 > domain.ohporn.com.4661: S 349022057:349022057(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:16.839785 172.16.11.129.1745 > 193.111.199.183.4242: S 3852758782:3852758782(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:20.849879 172.16.11.129.1747 > 66.79.184.80.4661: S 1537582885:1537582885(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:21.178029 172.16.11.129.1748 > razorback.ed2k.ch.4661: S 450373228:450373228(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:22.147195 172.16.11.129.1744 > domain.ohporn.com.4661: S 349022057:349022057(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:22.848165 172.16.11.129.1745 > 193.111.199.183.4242: S 3852758782:3852758782(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:23.798682 172.16.11.129.1747 > 66.79.184.80.4661: S 1537582885:1537582885(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:24.236186 172.16.11.129.1748 > razorback.ed2k.ch.4661: S 450373228:450373228(0) win 16384 <mss 1460,nop,nop,sackOK> (DF)
    23:38:25.440335 172.16.11.129.1749 > 230.Red-80-59-112.pooles.rima-tde.net.4672: udp 35
    23:38:25.440463 172.16.11.129.1750 > 218-168-138-45.HINET-IP.hinet.net.4672: udp 35
    Pacotes capturados pelo tcpdump em uma rede minha, esse ip(172.16.11.129) esta consumindo um link de + ou - 200k. Isso sem navegação alguma. O sistema operacional é um windows 2000.
    Acredito que seja algum tipo de ataque de vírus, mas nao tenho ideia de qual virus poderia atacar nessas portas. Ja pesquisei mas nao encontrei nada relacionado.
    Então pergunto, alguem tem noçao do que é isso???
    Desde já agradeço a atenção dispensada.
    Obrigado
    lss
    ele nao ta navegando , mais ta que ta nas redes p2p, esse razorback.ed2k.ch e do edonkey, emule sei la qual o nome .
    Thiago--
    seriam spywares entao?
    akeles ki vem junto de kazaa, imesh?
    Spelk
    Se for só o E-Donkey msm, tenta bloqueá-lo pelo iptables:
    iptables -A FORWARD -o ip.placa.rede.externa -p tcp --dport 4661 -j DROP # E-Donkey
    iptables -A FORWARD -o ip.placa.rede.externa -p tcp --dport 4662 -j DROP # E-Donkey
