    Odair Borges
    Padrão Servidor DNS
    Caros colegas,
    Configurei o servidor DNS em nosso routeador Linux e apos a configuração percebi que esta tendo uma quantidade muito grande de pacotes UDP da porta 53, gostaria de saber se isto é normal do servidor DNS
    OBS.: Servidor CL9 - bind 9.2.2*
    192.168.8.62..netbios-ns 192.168.8.255..netbios-ns udp 288 19
    192.168.8.5..blackjack G.ROOT-SERVERS.NET..domain udp 82
    G.ROOT-SERVERS.NET..domain 192.168.8.5..blackjack udp 235
    192.168.8.5..blackjack m.root-servers.net..domain udp 502
    m.root-servers.net..domain 192.168.8.5..blackjack udp 3505
    192.168.8.5..blackjack b.gtld-servers.net..domain udp 927
    b.gtld-servers.net..domain 192.168.8.5..blackjack udp 2766
    192.168.8.5..blackjack chia.arin.net..domain udp 222
    192.168.8.5..blackjack e3.NSTLD.COM..domain udp 399
    192.168.8.5..blackjack l.root-servers.net..domain udp 207
    chia.arin.net..domain 192.168.8.5..blackjack udp 40
    192.168.8.5..blackjack f.gtld-servers.net..domain udp 138
    192.168.8.5..blackjack c.root-servers.net..domain udp 82
    c.root-servers.net..domain 192.168.8.5..blackjack udp 236
    192.168.8.5..blackjack ns.ripe.net..domain udp 82
    192.168.8.5..blackjack tinnie.apnic.net..domain udp 210
    192.168.8.5..blackjack a.gtld-servers.net..domain udp 135
    a.gtld-servers.net..domain 192.168.8.5..blackjack udp 40
    192.168.8.5..blackjack a.root-servers.net..domain udp 155
    192.168.8.5..blackjack figwort.arin.net..domain udp 224
    figwort.arin.net..domain 192.168.8.5..blackjack udp 40
    192.168.8.5..blackjack g2.NSTLD.COM..domain udp 164
    192.168.8.5..blackjack d3.NSTLD.COM..domain udp 149
    d3.NSTLD.COM..domain 192.168.8.5..blackjack udp 382
    192.168.8.5..blackjack b2.NSTLD.COM..domain udp 162
    b2.NSTLD.COM..domain 192.168.8.5..blackjack udp 766
    192.168.8.5..blackjack ginseng.arin.net..domain udp 223
    ginseng.arin.net..domain 192.168.8.5..blackjack udp 505
    192.168.8.5..blackjack c2.NSTLD.COM..domain udp 246
    c2.NSTLD.COM..domain 192.168.8.5..blackjack udp 1167
    192.168.8.5..blackjack k.root-servers.net..domain udp 82
    k.root-servers.net..domain 192.168.8.5..blackjack udp 235
    192.168.8.5..blackjack epazote.arin.net..domain udp 224
    epazote.arin.net..domain 192.168.8.5..blackjack udp 154
    192.168.8.5..blackjack c.gtld-servers.net..domain udp 248
    c.gtld-servers.net..domain 192.168.8.5..blackjack udp 410
    192.168.8.5..blackjack dot.ep.net..domain udp 82
    dot.ep.net..domain 192.168.8.5..blackjack udp 270
    192.168.8.5..blackjack henna.arin.net..domain udp 142
    henna.arin.net..domain 192.168.8.5..blackjack udp 688
    192.168.8.5..blackjack e2.NSTLD.COM..domain udp 306
    e2.NSTLD.COM..domain 192.168.8.5..blackjack udp 916
    192.168.8.5..blackjack dill.arin.net..domain udp 142
    dill.arin.net..domain 192.168.8.5..blackjack udp 457
    192.168.8.5..blackjack d.gtld-servers.net..domain udp 248
    d.gtld-servers.net..domain 192.168.8.5..blackjack udp 80
    192.168.8.5..blackjack ns2.psi.net..domain udp 81
    192.168.8.5..blackjack f.root-servers.net..domain udp 160
    f.root-servers.net..domain 192.168.8.5..blackjack udp 380
    192.168.8.5..blackjack cumin.apnic.net..domain udp
    violinista
    Padrão Servidor DNS
    Quando o teu servidor DNS não conhece o nome de algum host, provavelmente busque num desses servidores aí, ou em vários deles ... se o tráfego na tua rede não é muito grande (se não é necessária a resolução de nomes constantemente) não vejo motivo pra esse tráfego todo ... mas isso é normal se é a primeira vez que você está rodando o DNS ...
    Essas msgs são constantes, não param ????? A tua rede é muito grande ????
    Padrão Servidor DNS
    Não, minha rede não tem um volume grande de acesso, as mensagens não são constantes..
    violinista
    Padrão Servidor DNS
    Então é isso ... o seu servidor estava consultando endereços que ele não conhecia ... perceba se com o passar do tempo esse volume não diminui (o que é muito provável) ...
    T+ !
    Padrão Servidor DNS
    blz..., agradeço pelas informções
