    deluxe
    Padrão Proftp permissões HELP ! Alguem sabe ?
    Galera..to tentando configura aqui o proftp para os usuarios acessarem remotamente pelo Internet Explorer
    ftp://[email protected]
    mas preciso que o usuário sai da pasta home dele
    e não aparece aquela felchinha pra ele mudar de diretorio no Internet Explorer
    e que ele nao fique em chroot, mas eu nao abilitei esta opção nele
    alguem pode me ajudar ?
    meu proftpd.conf
    ServerName "FTP - Linha Ativa ! "
    ServerType standalone
    DeferWelcome off
    ServerIdent on "Linha Ativa FTP Server"
    MultilineRFC2228 on
    DefaultServer on
    ShowSymlinks on
    AllowOverwrite on
    TimeoutNoTransfer 600
    TimeoutStalled 600
    TimeoutIdle 1200
    DisplayLogin welcome.msg
    DisplayFirstChdir .message
    ListOptions "-l"
    DenyFilter \*.*/
    # Uncomment this if you are using NIS or LDAP to retrieve passwords:
    #PersistentPasswd off
    # Uncomment this if you would use TLS module:
    #TLSEngine on
    # Uncomment this if you would use quota module:
    #Quotas on
    # Uncomment this if you would use ratio module:
    #Ratios on
    # Port 21 is the standard FTP port.
    Port 21
    MaxInstances 8
    # Set the user and group that the server normally runs at.
    User nobody
    Group nogroup
    <Directory /*>
    # Umask 022 is a good standard umask to prevent new files and dirs
    # (second parm) from being group and world writable.
    Umask 022 022
    # Normally, we want files to be overwriteable.
    AllowOverwrite on
    </Directory>
    # A basic anonymous configuration, no upload directories.
    # <Anonymous ~ftp>
    # User ftp
    # Group usuarios
    # # We want clients to be able to login with "anonymous" as well as "ftp"
    # UserAlias anonymous ftp
    # # Cosmetic changes, all files belongs to ftp user
    # DirFakeUser on ftp
    # DirFakeGroup on ftp
    # RequireValidShell off
    # # Limit the maximum number of anonymous logins
    MaxClients 10
    # # We want 'welcome.msg' displayed at login, and '.message' displayed
    # # in each newly chdired directory.
    # DisplayLogin welcome.msg
    # DisplayFirstChdir .message
    # # Limit WRITE everywhere in the anonymous chroot
    # <Directory *>
    # <Limit WRITE>
    # DenyAll
    # </Limit>
    # </Directory>
    não entendi amigo... vc quer que o usuário consiga acessar uma pasta acima da dele?
    deluxe
    isso...quero que ele acesse uma pasta
    /home/Bancos
    Você tem que alterar o diretório home desse usuário... o ftp abre no diretório home dele, altere o diretório e o usuário irá cair onde vc quer
    rdigaum
    Padrão Diretorio FTP
    deluxe!
    Vc tbm pode fazer uso de um link simbólico.
    ex.: ~/(dir. usuário)$ ln -s Bancos /home/Bancos
    Onde bancos será equivalente ao diretório /home/Bancos
    Certo, assim não seria necessário modificar o diretório do usuário.
    [ ] 's
    rdigaum
