    rober
    Padrão mysql ended - naum instala nem com reza
    Pessoal.......to desesperadamente tentando instalar o mysql a uma semana, já tentei pkg e copilação normal, aqui no topíco vou só expor os erros na coilação normal
    baixei o tar.gz
    Extrai seu conteudo
    abri o console e dei ./configure , ele começo a configuração mas logo parau e exibiu a msg "mysql ended"
    qnd preciono qualker tecla ele volta ao console
    isso já aconteceu varias vezes em varias tentativas de instalação,
    -Uso slackware 9.1
    Se tiver algum que possa me ajuda fico muito grato
    Jul 2001
    Campinas Area
    O que diz o config.log?
    rober
    Padrão Essa é msg que ele gera
    NOTE: This is a MySQL binary distribution. It's ready to run, you don't
    need to configure it!
    To help you a bit, I am now going to create the needed MySQL databases
    and start the MySQL server for you. If you run into any trouble, please
    consult the MySQL manual, that you can find in the Docs directory.
    Installing all prepared tables
    040429 0:11:07 ./bin/mysqld: Shutdown Complete
    To start mysqld at boot time you have to copy support-files/mysql.server
    to the right place for your system
    PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
    To do so, start the server, then issue the following commands:
    ./bin/mysqladmin -u root password 'new-password'
    ./bin/mysqladmin -u root -h darkstar password 'new-password'
    See the manual for more instructions.
    NOTE: If you are upgrading from a MySQL <= 3.22.10 you should run
    the ./bin/mysql_fix_privilege_tables. Otherwise you will not be
    able to use the new GRANT command!
    You can start the MySQL daemon with:
    cd . ; ./bin/mysqld_safe &
    You can test the MySQL daemon with the benchmarks in the 'sql-bench' directory:
    cd sql-bench ; perl run-all-tests
    Please report any problems with the ./bin/mysqlbug script!
    The latest information about MySQL is available on the web at
    http://www.mysql.com
    Support MySQL by buying support/licenses at https://order.mysql.com
    Starting the mysqld server. You can test that it is up and running
    with the command:
    ./bin/mysqladmin version
    [email protected]:/rober/extract/mysql-4.0.18# Starting mysqld daemon with databases from /rober/extract/mysql-4.0.18/data
    040429 00:11:07 mysqld ended
    wrochal
    Padrão Solução
    Caro,
    Tente iniciar o mysql:
    #safe_mysqld &
    Se dar um erro, é "normal" e necessário para gerar o sock. Agora devemos fazer o seguinte:
    #chown -R mysql.mysql /var/lib/mysql
    Fonte: http://www.linuxit.com.br/modules.ph...icle&artid=243
    falou,
    rober
    O problema é que le naum instala..no começo da copilação ela da mysql ended e acaba por ai.ele naum termina a instalação
    rober
    Galera, eu resolvi o problema instalando o pkg
    ai vai pra quem tah com o problema de "ERROR 2002: Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2)"
    Solução
    - > no console :
    - > mysql_install_db
    - > chown -R mysql.mysql /var/lib/mysql (Nos pkg normalmente é ai onde ele fica)
    - > mysqld_safe &
    - > mysqladmin -u root password senha_aqui
    - > mysql - u root - p
    pra mim deu certinho ,
    jah tentou rodar o mysql_install_db antes de iniciar o mysql?
    ooops agora q vi que jah tinha sido resolvido
