    vivaldorf
    # see /usr/share/postfix/main.cf.dist for a commented, fuller
    # version of this file.
    # Do not change these directory settings - they are critical to Postfix
    # operation.
    command_directory = /usr/sbin
    daemon_directory = /usr/lib/postfix
    program_directory = /usr/lib/postfix
    smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
    setgid_group = postdrop
    biff = no
    # appending .domain is the MUA's job.
    append_dot_mydomain = no
    myhostname = microserviceinfo.com
    mydomain = microserviceinfo.com
    alias_maps = hash:/etc/aliases
    alias_database = hash:/etc/aliases
    myorigin = /etc/mailname
    mydestination = microserviceinfo.com
    relayhost =
    mynetworks = 127.0.0.0/8, 192.168.0.0/24
    mailbox_command =
    mailbox_size_limit = 0
    recipient_delimiter = +
  2. adiciona issu: relay_domains = $mynetworks
    e o tail -f /var/log/maillog qdo vc foi autenticar? oq deu?
  3. #8
    vivaldorf
    apareceu algumas linhas de configuração que não sei o que eh...
    Grato Vivaldo
  4. ta faz o comando q falei acima, tenta se autenticar, ae as linhas q aparecerem na hora da autenticacao vc cola aki
  5. #10
    vivaldorf
    Apr 28 23:12:19 microservice postfix/cleanup[3577]: warning: mail_queue_enter: rename incoming/880957.3577 to incoming/E/B/EB64439094: No space left on device
    Apr 28 23:12:19 microservice postfix/cleanup[3581]: warning: mail_queue_enter: rename incoming/130731.3581 to incoming/3/2/3287939096: No space left on device
    Apr 28 23:12:20 microservice postfix/cleanup[3577]: warning: mail_queue_enter: rename incoming/880957.3577 to incoming/E/B/EB64439094: No space left on device
    Apr 28 23:12:20 microservice postfix/cleanup[3581]: warning: mail_queue_enter: rename incoming/130731.3581 to incoming/3/2/3287939096: No space left on device
    Apr 28 23:12:20 microservice in.qpopper[3634]: microservice@microserviceinfo.com at 192.168.0.100 (192.168.0.100): -ERR [AUTH] Password supplied for "microservice@microserviceinfo.com" is incorrect. [pop_pass.c:1291]
    Apr 28 23:12:20 microservice in.qpopper[3644]: (v4.0.4) Unable to get canonical name of client 192.168.0.100: Unknown host (1) [pop_init.c:1075]
    Apr 28 23:12:21 microservice postfix/cleanup[3581]: warning: mail_queue_enter: rename incoming/130731.3581 to incoming/3/2/3287939096: No space left on device
    Apr 28 23:12:21 microservice postfix/cleanup[3577]: warning: mail_queue_enter: rename incoming/880957.3577 to incoming/E/B/EB64439094: No space left on device
    Apr 28 23:12:21 microservice in.qpopper[3644]: write to newly-created lock file /var/mail/cristian.lock failed: No space left on device (28) [maillock.c:533]
    Apr 28 23:12:21 microservice in.qpopper[3644]: cristian at 192.168.0.100 (192.168.0.100): -ERR [SYS/TEMP] maillock error 'Unable to write pid into lockfile' (3) on '/var/mail/cristian': No space left on device (28) [pop_dropcopy.c:1636]
    Apr 28 23:12:22 microservice postfix/cleanup[3581]: warning: mail_queue_enter: rename incoming/130731.3581 to incoming/3/2/3287939096: No space left on device
    Apr 28 23:12:22 microservice postfix/cleanup[3581]: fatal: mail_queue_enter: rename incoming/130731.3581 to incoming/3/2/3287939096: giving up
    Apr 28 23:12:22 microservice postfix/cleanup[3577]: warning: mail_queue_enter: rename incoming/880957.3577 to incoming/E/B/EB64439094: No space left on device
    Apr 28 23:12:22 microservice last message repeated 60 times
    Apr 28 23:12:22 microservice postfix/cleanup[3578]: warning: mail_queue_enter: rename incoming/906777.3578 to incoming/E/D/ED3E939095: No space left on device
    Apr 28 23:12:22 microservice last message repeated 54 times
    Apr 28 23:12:22 microservice postfix/cleanup[3578]: fatal: mail_queue_enter: rename incoming/906777.3578 to incoming/E/D/ED3E939095: giving up
    Apr 28 23:12:23 microservice last message repeated 7 times
    Apr 28 23:12:23 microservice postfix/cleanup[3577]: fatal: mail_queue_enter: rename incoming/880957.3577 to incoming/E/B/EB64439094: giving up
    Apr 28 23:12:23 microservice postfix/smtpd[3579]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:12:23 microservice postfix/smtpd[3579]: fatal: unable to connect to the public cleanup service
    Apr 28 23:12:23 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 3581 exit status 1
    Apr 28 23:12:23 microservice postfix/master[2662]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
    Apr 28 23:12:23 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 3578 exit status 1
    Apr 28 23:12:23 microservice postfix/smtpd[3515]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:12:23 microservice postfix/smtpd[3515]: fatal: unable to connect to the public cleanup service
    Apr 28 23:12:24 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 3577 exit status 1
    Apr 28 23:12:24 microservice postfix/smtpd[3234]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:12:24 microservice postfix/smtpd[3234]: fatal: unable to contact the cleanup service
    Apr 28 23:12:24 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 3579 exit status 1
    Apr 28 23:12:24 microservice postfix/master[2662]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
    Apr 28 23:12:24 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 3515 exit status 1
    Apr 28 23:12:25 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 3234 exit status 1
    Apr 28 23:13:11 microservice postfix/smtpd[3633]: connect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:13:12 microservice postfix/smtpd[3633]: disconnect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:13:33 microservice in.qpopper[3690]: (v4.0.4) Unable to get canonical name of client 192.168.0.100: Unknown host (1) [pop_init.c:1075]
    Apr 28 23:13:33 microservice in.qpopper[3690]: vivaldo at 192.168.0.100 (192.168.0.100): -ERR [SYS/PERM] Temporary drop /var/spool/pop//.vivaldo.pop not owned by vivaldo. [pop_dropcopy.c:1506]
    Apr 28 23:14:28 microservice postfix/smtpd[3633]: connect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:14:28 microservice postfix/smtpd[3633]: disconnect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:14:38 microservice postfix/smtpd[3633]: connect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:14:38 microservice postfix/smtpd[3633]: disconnect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:16:10 microservice postfix/smtpd[3633]: warning: 200.161.136.167: hostname 200-161-136-167.planetsys.com.br verification failed: Host not found
    Apr 28 23:16:10 microservice postfix/smtpd[3633]: connect from unknown[200.161.136.167]
    Apr 28 23:16:13 microservice postfix/smtpd[3633]: DB24239097: client=unknown[200.161.136.167]
    Apr 28 23:16:15 microservice postfix/smtpd[3633]: reject: RCPT from unknown[200.161.136.167]: 452 Insufficient system storage; from=<luiz@bbl.com.br> to=<cristian@microserviceinfo.com>
    Apr 28 23:18:37 microservice postfix/smtpd[3882]: warning: 200.161.136.167: hostname 200-161-136-167.planetsys.com.br verification failed: Host not found
    Apr 28 23:18:37 microservice postfix/smtpd[3882]: connect from unknown[200.161.136.167]
    Apr 28 23:18:38 microservice postfix/cleanup[3883]: warning: mail_queue_enter: rename incoming/59094.3883 to incoming/2/6/2676239097: No space left on device
    Apr 28 23:18:43 microservice last message repeated 1001 times
    Apr 28 23:18:43 microservice postfix/cleanup[3883]: fatal: mail_queue_enter: rename incoming/59094.3883 to incoming/2/6/2676239097: giving up
    Apr 28 23:18:45 microservice postfix/smtpd[3882]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:18:45 microservice postfix/smtpd[3882]: fatal: unable to connect to the public cleanup service
    Apr 28 23:18:45 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 3883 exit status 1
    Apr 28 23:18:45 microservice postfix/master[2662]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
    Apr 28 23:18:46 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 3882 exit status 1
    Apr 28 23:18:46 microservice postfix/master[2662]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
    Apr 28 23:21:26 microservice postfix/smtpd[3633]: timeout after RSET from unknown[200.161.136.167]
    Apr 28 23:21:26 microservice postfix/cleanup[3996]: warning: mail_queue_enter: rename incoming/691374.3996 to incoming/B/7/B74E439098: No space left on device
    Apr 28 23:21:32 microservice last message repeated 1001 times
    Apr 28 23:21:32 microservice postfix/cleanup[3996]: fatal: mail_queue_enter: rename incoming/691374.3996 to incoming/B/7/B74E439098: giving up
    Apr 28 23:21:33 microservice postfix/smtpd[3633]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:21:33 microservice postfix/smtpd[3633]: fatal: unable to contact the cleanup service
    Apr 28 23:21:33 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 3996 exit status 1
    Apr 28 23:21:33 microservice postfix/master[2662]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
    Apr 28 23:21:34 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 3633 exit status 1
    Apr 28 23:21:42 microservice postfix/smtpd[4007]: connect from bay8-f31.bay8.hotmail.com[64.4.27.31]
    Apr 28 23:22:34 microservice postfix/cleanup[4044]: warning: mail_queue_enter: rename incoming/988889.4044 to incoming/F/3/F366639099: No space left on device
    Apr 28 23:22:39 microservice last message repeated 1001 times
    Apr 28 23:22:39 microservice postfix/cleanup[4044]: fatal: mail_queue_enter: rename incoming/988889.4044 to incoming/F/3/F366639099: giving up
    Apr 28 23:22:40 microservice postfix/smtpd[4007]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:22:40 microservice postfix/smtpd[4007]: fatal: unable to connect to the public cleanup service
    Apr 28 23:22:40 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 4044 exit status 1
    Apr 28 23:22:40 microservice postfix/master[2662]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
    Apr 28 23:22:41 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 4007 exit status 1
    Apr 28 23:22:41 microservice postfix/master[2662]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
    Apr 28 23:24:56 microservice postfix/smtpd[4137]: connect from bay8-f81.bay8.hotmail.com[64.4.27.81]
    Apr 28 23:24:56 microservice postfix/cleanup[4138]: warning: mail_queue_enter: rename incoming/815280.4138 to incoming/E/E/EE0893909A: No space left on device
    Apr 28 23:25:02 microservice last message repeated 1001 times
    Apr 28 23:25:02 microservice postfix/cleanup[4138]: fatal: mail_queue_enter: rename incoming/815280.4138 to incoming/E/E/EE0893909A: giving up
    Apr 28 23:25:03 microservice postfix/smtpd[4137]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:25:03 microservice postfix/smtpd[4137]: fatal: unable to connect to the public cleanup service
    Apr 28 23:25:03 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 4138 exit status 1
    Apr 28 23:25:03 microservice postfix/master[2662]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
    Apr 28 23:25:04 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 4137 exit status 1
    Apr 28 23:25:04 microservice postfix/master[2662]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
    Apr 28 23:26:15 microservice postfix/smtpd[4184]: connect from unknown[200.179.65.2]
    Apr 28 23:26:15 microservice postfix/smtpd[4184]: disconnect from unknown[200.179.65.2]
    Apr 28 23:29:13 microservice postfix/smtpd[4293]: connect from unknown[200.179.65.2]
    Apr 28 23:29:13 microservice postfix/smtpd[4293]: disconnect from unknown[200.179.65.2]
    Apr 28 23:35:02 microservice postfix/smtpd[4516]: connect from smtp-35.ig.com.br[200.226.132.185]
    Apr 28 23:35:03 microservice postfix/smtpd[4516]: 0BDA03909B: client=smtp-35.ig.com.br[200.226.132.185]
    Apr 28 23:35:03 microservice postfix/smtpd[4516]: reject: RCPT from smtp-35.ig.com.br[200.226.132.185]: 452 Insufficient system storage; from=<roberta.padoan@ig.com.br> to=<cristian@microserviceinfo.com>
    Apr 28 23:35:08 microservice postfix/cleanup[4518]: 3DB5F3909C: message-id=<20040429023508.3DB5F3909C@microserviceinfo.com>
    Apr 28 23:35:08 microservice postfix/cleanup[4518]: warning: 3DB5F3909C: write queue file: No space left on device
    Apr 28 23:35:08 microservice postfix/cleanup[4518]: warning: 3DB5F3909C: skipping further client input
    Apr 28 23:35:08 microservice postfix/smtpd[4516]: disconnect from smtp-35.ig.com.br[200.226.132.185]
    Apr 28 23:36:27 microservice postfix/smtpd[4516]: connect from unknown[200.179.65.2]
    Apr 28 23:36:27 microservice postfix/smtpd[4516]: disconnect from unknown[200.179.65.2]
    Apr 28 23:36:48 microservice postfix/smtpd[4516]: warning: 200.161.136.167: hostname 200-161-136-167.planetsys.com.br verification failed: Host not found
    Apr 28 23:36:48 microservice postfix/smtpd[4516]: connect from unknown[200.161.136.167]
    Apr 28 23:36:49 microservice postfix/smtpd[4516]: 49E513909B: client=unknown[200.161.136.167]
    Apr 28 23:36:49 microservice postfix/smtpd[4516]: reject: RCPT from unknown[200.161.136.167]: 452 Insufficient system storage; from=<luiz@bbl.com.br> to=<cristian@microserviceinfo.com>
    Apr 28 23:37:42 microservice postfix/smtpd[4621]: connect from bay8-f31.bay8.hotmail.com[64.4.27.31]
    Apr 28 23:37:43 microservice postfix/smtpd[4621]: 4D9A63909B: client=bay8-f31.bay8.hotmail.com[64.4.27.31]
    Apr 28 23:37:43 microservice postfix/smtpd[4621]: reject: RCPT from bay8-f31.bay8.hotmail.com[64.4.27.31]: 452 Insufficient system storage; from=<bebelabrasil@hotmail.com> to=<cristian@microserviceinfo.com>
    Apr 28 23:37:49 microservice postfix/cleanup[4584]: warning: mail_queue_enter: rename incoming/82185.4584 to incoming/2/7/273D23909B: No space left on device
    Apr 28 23:37:55 microservice last message repeated 1001 times
    Apr 28 23:37:55 microservice postfix/cleanup[4584]: fatal: mail_queue_enter: rename incoming/82185.4584 to incoming/2/7/273D23909B: giving up
    Apr 28 23:37:56 microservice postfix/smtpd[4621]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:37:56 microservice postfix/smtpd[4621]: fatal: unable to contact the cleanup service
    Apr 28 23:37:56 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 4584 exit status 1
    Apr 28 23:37:57 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 4621 exit status 1
    Apr 28 23:37:57 microservice postfix/master[2662]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
    Apr 28 23:38:57 microservice postfix/smtpd[4669]: connect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:38:58 microservice postfix/smtpd[4669]: disconnect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:40:04 microservice postfix/smtpd[4669]: connect from bay8-f81.bay8.hotmail.com[64.4.27.81]
    Apr 28 23:40:05 microservice postfix/smtpd[4669]: 96A973909C: client=bay8-f81.bay8.hotmail.com[64.4.27.81]
    Apr 28 23:40:05 microservice postfix/smtpd[4669]: reject: RCPT from bay8-f81.bay8.hotmail.com[64.4.27.81]: 452 Insufficient system storage; from=<bebelabrasil@hotmail.com> to=<cristian@microserviceinfo.com>
    Apr 28 23:40:11 microservice postfix/cleanup[4715]: warning: mail_queue_enter: rename incoming/437282.4715 to incoming/6/B/6BCAE3909C: No space left on device
    Apr 28 23:40:17 microservice last message repeated 1001 times
    Apr 28 23:40:17 microservice postfix/cleanup[4715]: fatal: mail_queue_enter: rename incoming/437282.4715 to incoming/6/B/6BCAE3909C: giving up
    Apr 28 23:40:18 microservice postfix/smtpd[4669]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:40:18 microservice postfix/smtpd[4669]: fatal: unable to contact the cleanup service
    Apr 28 23:40:18 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 4715 exit status 1
    Apr 28 23:40:19 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 4669 exit status 1
    Apr 28 23:40:45 microservice postfix/smtpd[4744]: connect from unknown[200.179.65.2]
    Apr 28 23:40:46 microservice postfix/smtpd[4744]: disconnect from unknown[200.179.65.2]
    Apr 28 23:41:59 microservice postfix/smtpd[4516]: timeout after RSET from unknown[200.161.136.167]
    Apr 28 23:41:59 microservice postfix/cleanup[4790]: 96EF03909D: message-id=<20040429024159.96EF03909D@microserviceinfo.com>
    Apr 28 23:41:59 microservice postfix/cleanup[4790]: warning: 96EF03909D: write queue file: No space left on device
    Apr 28 23:41:59 microservice postfix/cleanup[4790]: warning: 96EF03909D: skipping further client input
    Apr 28 23:41:59 microservice postfix/smtpd[4516]: disconnect from unknown[200.161.136.167]
    Apr 28 23:42:23 microservice postfix/smtpd[4744]: connect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:42:23 microservice postfix/smtpd[4744]: disconnect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:42:35 microservice postfix/smtpd[4516]: connect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:42:36 microservice postfix/smtpd[4516]: disconnect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:43:00 microservice postfix/smtpd[4744]: warning: 200.161.136.167: hostname 200-161-136-167.planetsys.com.br verification failed: Host not found
    Apr 28 23:43:00 microservice postfix/smtpd[4744]: connect from unknown[200.161.136.167]
    Apr 28 23:43:01 microservice postfix/cleanup[4790]: warning: mail_queue_enter: rename incoming/988505.4790 to incoming/0/3/0327E3909D: No space left on device
    Apr 28 23:43:06 microservice last message repeated 1001 times
    Apr 28 23:43:06 microservice postfix/cleanup[4790]: fatal: mail_queue_enter: rename incoming/988505.4790 to incoming/0/3/0327E3909D: giving up
    Apr 28 23:43:07 microservice postfix/smtpd[4744]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:43:07 microservice postfix/smtpd[4744]: fatal: unable to connect to the public cleanup service
    Apr 28 23:43:07 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 4790 exit status 1
    Apr 28 23:43:08 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 4744 exit status 1
    Apr 28 23:44:21 microservice postfix/smtpd[4873]: connect from unknown[200.179.65.2]
    Apr 28 23:44:21 microservice postfix/smtpd[4873]: disconnect from unknown[200.179.65.2]
    Apr 28 23:45:54 microservice postfix/smtpd[4873]: connect from unknown[200.179.65.2]
    Apr 28 23:45:55 microservice postfix/smtpd[4873]: disconnect from unknown[200.179.65.2]
    Apr 28 23:47:30 microservice postfix/smtpd[4873]: connect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:47:30 microservice postfix/smtpd[4873]: disconnect from sisifo2i.petrobras.com.br[200.157.150.2]
    Apr 28 23:48:50 microservice postfix/smtpd[4873]: warning: 200.161.136.167: hostname 200-161-136-167.planetsys.com.br verification failed: Host not found
    Apr 28 23:48:50 microservice postfix/smtpd[4873]: connect from unknown[200.161.136.167]
    Apr 28 23:48:51 microservice postfix/cleanup[5036]: warning: mail_queue_enter: rename incoming/362419.5036 to incoming/6/8/6835F3909F: No space left on device
    Apr 28 23:48:54 microservice last message repeated 655 times
    Apr 28 23:48:54 microservice postfix/smtpd[5046]: connect from unknown[200.179.65.2]
    Apr 28 23:48:54 microservice postfix/cleanup[5036]: warning: mail_queue_enter: rename incoming/362419.5036 to incoming/6/8/6835F3909F: No space left on device
    Apr 28 23:48:54 microservice postfix/smtpd[5046]: disconnect from unknown[200.179.65.2]
    Apr 28 23:48:57 microservice last message repeated 344 times
    Apr 28 23:48:57 microservice postfix/cleanup[5036]: fatal: mail_queue_enter: rename incoming/362419.5036 to incoming/6/8/6835F3909F: giving up
    Apr 28 23:48:58 microservice postfix/smtpd[4873]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:48:58 microservice postfix/smtpd[4873]: fatal: unable to connect to the public cleanup service
    Apr 28 23:48:58 microservice postfix/master[2662]: warning: process /usr/lib/postfix/cleanup pid 5036 exit status 1
    Apr 28 23:48:58 microservice postfix/master[2662]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
    Apr 28 23:48:59 microservice postfix/master[2662]: warning: process /usr/lib/postfix/smtpd pid 4873 exit status 1
    Apr 28 23:49:46 microservice postfix/smtpd[5046]: connect from unknown[200.179.65.2]
    Apr 28 23:49:46 microservice postfix/smtpd[5046]: disconnect from unknown[200.179.65.2]
    Apr 28 23:50:33 microservice postfix/smtpd[5046]: connect from unknown[200.179.65.2]
    Apr 28 23:50:34 microservice postfix/smtpd[5046]: disconnect from unknown[200.179.65.2]
    Apr 28 23:52:13 microservice postfix/smtpd[5046]: connect from unknown[200.179.65.2]
    Apr 28 23:52:13 microservice postfix/smtpd[5046]: disconnect from unknown[200.179.65.2]
    Apr 28 23:52:31 microservice postfix/postfix-script: stopping the Postfix mail system
    Apr 28 23:52:31 microservice postfix/master[2662]: terminating on signal 15
    Apr 28 23:52:38 microservice postfix/postfix-script: starting the Postfix mail system
    Apr 28 23:52:38 microservice postfix/master[5251]: daemon started
    Apr 28 23:52:57 microservice postfix/smtpd[5263]: connect from bay8-f31.bay8.hotmail.com[64.4.27.31]
    Apr 28 23:52:59 microservice postfix/cleanup[5264]: warning: mail_queue_enter: rename incoming/917281.5264 to incoming/5/F/5F24A390A0: No space left on device
    Apr 28 23:53:05 microservice last message repeated 1001 times
    Apr 28 23:53:05 microservice postfix/cleanup[5264]: fatal: mail_queue_enter: rename incoming/917281.5264 to incoming/5/F/5F24A390A0: giving up
    Apr 28 23:53:06 microservice postfix/smtpd[5263]: warning: premature end-of-input from public/cleanup socket while reading input attribute name
    Apr 28 23:53:06 microservice postfix/smtpd[5263]: fatal: unable to connect to the public cleanup service
    Apr 28 23:53:06 microservice postfix/master[5251]: warning: process /usr/lib/postfix/cleanup pid 5264 exit status 1
    Apr 28 23:53:06 microservice postfix/master[5251]: warning: /usr/lib/postfix/cleanup: bad command startup -- throttling
    Apr 28 23:53:07 microservice postfix/master[5251]: warning: process /usr/lib/postfix/smtpd pid 5263 exit status 1
    Apr 28 23:53:07 microservice postfix/master[5251]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
  1. Shorewall não libera MSN
    Por PcGuy no fórum Servidores de Rede
    Último Post: 03-10-2006, 07:41
  2. Somente uma conta não autentica no pop.
    Por juniovitorino no fórum Servidores de Rede
    Respostas: 5
    Último Post: 24-08-2006, 11:20
  3. Proxy Transparente : Nao consigo acessar pop, smtp e nem dar ping
    Por master_foca no fórum Servidores de Rede
    Respostas: 7
    Último Post: 09-05-2006, 17:32
  4. Squid nao libera FTP
    Por slackrio no fórum Servidores de Rede
    Respostas: 12
    Último Post: 21-04-2006, 17:27
  5. Proxy Transparente nao libera nada
    Por mastellaro no fórum Servidores de Rede
    Último Post: 10-02-2006, 18:20
