    LeonardoDG
    Padrão Problema no SSH? to perdidinho!!!
    Bom gente quando eu copio um arquivo via scp dá esse erro!! nunca deu esse negocio!!
    @ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
    IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
    Someone could be eavesdropping on you right now (man-in-the-middle attack)!
    It is also possible that the RSA host key has just been changed.
    The fingerprint for the RSA key sent by the remote host is
    6f:3f:18:46:8c:05:d8:b1:32:a1:a1:77:3b:3b:9f:39.
    Please contact your system administrator.
    Add correct host key in /root/.ssh/known_hosts to get rid of this message.
    Offending key in /root/.ssh/known_hosts:2
    RSA host key for 172.16.125.67 has changed and you have requested strict checking.
    Host key verification failed.
    lost connection
    edita esse aquivo:
    e apaga a linha q tem o ip de onde vc ta conectando
    LenTu
    eh... issu acontece pq vc deve ter mudado o ip da makina...
    vai no arquivo /etc/known_hosts e apaga a linha q indica a makina com esse ip... e tenta acessar novamente...
    qq coisa voltae
    :wink:
    LenTu
    eita.. demorei mto pra responde... ahuahauhaua...
    foi mal...
    ops:
    heheeheh eh q tem um vagabundo aki o 1c3_m4n conhece? ele ta sem faze nda o dia inteiro entaum fica soh aki no forum hehehehe
    LeonardoDG
    muito obrigado a todos!!! e funcionou obrigao mesmo!!!
