    Padrão POSTFIX - URGENTE
    Caros colegas,
    Instalei o CL9 e estou tentando configurar o Postfix + Amavis + NAI
    o problema é que fica aparecendo estas mensgens no LOG e não consigo enviar mensagens, agora verifiquei que no diretorio /var/spool/postfix/public não existe o item " cleanup ". Gostaria de algumas orientções, grato pela atenção.
    Odair Borges
    MENSAGEM:
    May 3 18:56:31 zeon postfix/master[6029]: daemon started -- version 2.0.7
    May 3 18:56:31 zeon postfix/pickup[6036]: warning: connect #1 to subsystem public/cleanup
    : No such file or directory
    May 3 18:56:41 zeon postfix/pickup[6036]: warning: connect #2 to subsystem public/cleanup
    May 3 18:56:51 zeon postfix/pickup[6036]: warning: connect #3 to subsystem public/cleanup
    May 3 18:57:01 zeon postfix/pickup[6036]: warning: connect #4 to subsystem public/cleanup
    May 3 18:57:11 zeon postfix/pickup[6036]: warning: connect #5 to subsystem public/cleanup
    May 3 18:57:21 zeon postfix/pickup[6036]: warning: connect #6 to subsystem public/cleanup
    May 3 18:57:31 zeon postfix/pickup[6036]: warning: connect #7 to subsystem public/cleanup
    May 3 18:57:41 zeon postfix/pickup[6036]: warning: connect #8 to subsystem public/cleanup
    May 3 18:57:51 zeon postfix/pickup[6036]: warning: connect #9 to subsystem public/cleanup
    May 3 18:58:01 zeon postfix/pickup[6036]: warning: connect #10 to subsystem public/cleanu
    p: No such file or directory
    May 3 18:58:11 zeon postfix/pickup[6036]: fatal: connect #11 to subsystem public/cleanup:
    May 3 18:58:12 zeon postfix/master[6029]: warning: process /usr/lib/postfix/pickup pid 60
    36 exit status 1
    May 3 18:58:12 zeon postfix/master[6029]: warning: /usr/lib/postfix/pickup: bad command s
    tartup -- throttling
    May 3 18:59:12 zeon postfix/pickup[6039]: warning: connect #1 to subsystem public/cleanup
    May 3 18:59:22 zeon postfix/pickup[6039]: warning: connect #2 to subsystem public/cleanup
    May 3 18:59:32 zeon postfix/pickup[6039]: warning: connect #3 to subsystem public/cleanup
    May 3 18:59:42 zeon postfix/pickup[6039]: warning: connect #4 to subsystem public/cleanup
    May 3 18:59:52 zeon postfix/pickup[6039]: warning: connect #5 to subsystem public/cleanup
    geralmente qdo falta algum diretorio ele cria sozinho... da uma olhada se a pasta ta com permissao pro usuario postfix
    O diretorio cleanup não existe .... no diretorio /var/spool/postfix/public tem estes diretorios ou arquivos " pickup| , gmgr|, showq=...como proceder para criar o diretorio ja que os diretorios são diferentes dos outros...
    Citação Postado originalmente por 1c3_m4n
    veja se ele tem permissao como eu disse q na hora q ele foi executar ela vai criar oq tiver faltando................................. :?
    as permissões do diretorio /var/spool/postfix estão root.root agora a do diretorio /var/spool/postfix/public estão postfix.postdrop, alterei as permissões do diretorio postfix para postfix.postifx, mas não deu certo...
    faz assim
    chown postfix.postdrop -R /var/spool/postfix
    Caro colegas,
    Continua dando a mesngem de erro...
    May 3 20:44:11 zeon postfix/postfix-script: starting the Postfix mail system
    May 3 20:44:11 zeon postfix/master[7493]: daemon started -- version 2.0.7
    May 3 20:44:11 zeon postfix/pickup[7494]: warning: connect #1 to subsystem public/cleanup: No such file or directory
    May 3 20:44:21 zeon postfix/pickup[7494]: warning: connect #2 to subsystem public/cleanup: No such file or directory
    May 3 20:44:31 zeon postfix/pickup[7494]: warning: connect #3 to subsystem public/cleanup: No such file or directory
    Q estranho ta isso.... bom tenta criar esse diretorio na mao mesmo
