    odbc
    Padrão Sem permissão para Outlook Express
    Galera,
    Minhas estações com WinXP acessam internet e msn na boa, mas naum funciona o Outlook Express.
    Estou postando meu script do squid para vcs verem se existe rrros:
    http_port 8080
    icp_port 0
    cache_mem 100 MB
    maximum_object_size 4096 KB
    cache_dir ufs /cache 7000 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log none
    emulate_httpd_log off
    connect_timeout 120 seconds
    acl logname proxy_auth REQUIRED
    acl SSL_ports port 443 444 447 563 7443
    # acl Safe_ports port 80 21 443 444 447 563 70 210 7443 1024-65535
    acl CONNECT method CONNECT
    acl download urlpath_regex .exe$ .zip$ .arj$ .tar.gz$ .tgz$ .rpm$ .mp3$
    acl proibido url_regex "/etc/squid/proibido"
    acl aceito url_regex "/etc/squid/aceito"
    acl all src 192.168.0.0/255.255.255.0
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow all !proibido
    http_access allow !aceito
    icp_access allow all
    miss_access allow all
    cache_mgr [email protected]
    cache_effective_user squid
    cache_effective_group squid
    visible_hostname localhost
    store_avg_object_size 4 KB
    E o meu firewall está assim:
    #!/bin/sh
    #### CONFIGURAÇÔES DO IPTABLES FIREWALL ####
    # REDIRECIONAMENTO LIGADO (Forwarding ON) #
    log file = /var/log/firewall/%U.log
    LAN_IP_NET='192.168.0.1/24'
    LAN_NIC='eth1'
    WAN_NIC='eth0'
    # DHCP
    WAN_IP='ifconfig eth0 | grep inet | cut -d : -f 2 | cut -d ' ' -f 1'
    # CARREGANDO MODULOS #
    modprobe ip_nat_ftp
    modprobe iptable_nat
    modprobe ip_conntrack_ftp
    # LIMPANDO (FLUSH)
    iptables -t nat -F POSTROUTING
    iptables -t nat -F PREROUTING
    iptables -t nat -F OUTPUT
    iptables -F
    iptables -P INPUT DROP
    iptables -P FORWARD DROP
    iptables -P OUTPUT ACCEPT
    # LIBERAR O TRAFEGO DE REDE PARA O ROTEADOR
    iptables -A INPUT -i lo -j ACCEPT
    # LIGANDO MASQUERADE E REDIRECIONAMENTO (NAT - ON)
    iptables -t nat -A POSTROUTING -s $IPTB_LAN_IP_NET -j MASQUERADE
    iptables -A FORWARD -j ACCEPT -i $IPTB_LAN_NIC -s $IPTB_LAN_IP_NET
    iptables -A FORWARD -m state --state ESTABLISHED,RELATED -j ACCEPT
    iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
    #### BLOQUEIO DE ICMP - DESLIGADO (OFF) ####
    #### LIBERAR PORTAS ABERTAS NO ROTEADOR ####
    # Portas abertas no roteador para Servidores/Servicos - LIGADO
    iptables -A INPUT -j ACCEPT -p tcp --dport 21
    iptables -A INPUT -j ACCEPT -p tcp --dport 22
    iptables -A INPUT -j ACCEPT -p tcp --dport 25
    iptables -A INPUT -j ACCEPT -p tcp --dport 80
    iptables -A INPUT -j ACCEPT -p tcp --dport 110
    #### REDIRECIONAMENTO DE PORTAS PARA O SERVIDOR ####
    # Portas Abertas para a REDE - LIGADO
    iptables -A FORWARD -j ACCEPT -p tcp --dport 21
    iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 21 -j DNAT --to :21
    iptables -A FORWARD -j ACCEPT -p tcp --dport 22
    iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 22 -j DNAT --to :22
    iptables -A FORWARD -j ACCEPT -p tcp --dport 25
    iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 25 -j DNAT --to :25
    iptables -A FORWARD -j ACCEPT -p tcp --dport 80
    iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j DNAT --to :80
    iptables -A FORWARD -j ACCEPT -p tcp --dport 110
    iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 110 -j DNAT --to :110
    #### PORTAS FECHADAS ####
    iptables -A INPUT -p tcp -s 0/0 --dport 3128 -j DROP
    Alguém puder ajudar eu agadeço.
    Valew!!!
    Nesse link estão discutindo a mesma coisa:
    https://under-linux.org/modules.php?...wtopic&t=14027
    Eu tive o mesmo problema q vc, usei estas regras no meu firewall e funfou legal.
    #POP E SMTP
    #/usr/sbin/iptables -A FORWARD -p tcp -m tcp -s 192.168.0.0/24 -d 192.168.0.0/24 --dport 25 -j ACCEPT
    #/usr/sbin/iptables -A FORWARD -p tcp -m tcp -s 192.168.0.0/24 -d 192.168.0.0/24 --dport 110 -j ACCEPT
    Onde: 192.168.0.0/24 é o end. da minha rede.
    tenta aí e me fala.
    altera isso:
    pra isso:
    iptables -t nat -A POSTROUTING -s $LAN_IP_NET -j MASQUERADE
    iptables -A FORWARD -j ACCEPT -i $IPTB_LAN_NIC -s $LAN_IP_NET
    Num sei se li errado mas vc num tem a variavel IPTB_LAN_IP_NET vc soh tem a LAN_IP_NET
    odbc
    Beleza vou verficar aki, inclusive vi que qdo entro nas configuraçõe sdo modem atraves do ip dele vi que ele tb tem algumas opções de net e firewall. Sem querer eu vi isso, assim vou desabilitar as opções dele e em seguida vou alterar os tópicos que vc me passaram.
    Valew pela ajuda pessoal.
