Ola Lista
Estou instalando o vpopmail-5.4.0 no Redhat 9 e estou tendo problemas no make dele, alguem pode me dar uma luz:
o configure: O configure gera legal
./configure --disable-roaming-users --enable-logging=p --disable-ip-alias-domains --disable-passwd --enable-clear-passwd --disable-domain-quotas --enable-auth-module=mysql --disable-many-domains --enable-auth-logging --enable-mysql-logging --enable-valias --disable-mysql-limits --enable-incdir=/var/lib/mysql/
O erro no make:
vauth.c: In function `valias_select_all':
vauth.c:1386: warning: format argument is not a pointer (arg 3)
vauth.c:1390: warning: assignment makes pointer from integer without a cast
vauth.c: In function `valias_select_all_next':
vauth.c:1397: subscripted value is neither array nor pointer
vauth.c:1398: subscripted value is neither array nor pointer
make[2]: ** [vauth.o] Erro 1
make[2]: Saindo do diretório `/root/qmail/qmailrocks/vpopmail-5.4.0'
make[1]: ** [all-recursive] Erro 1
make[1]: Saindo do diretório `/root/qmail/qmailrocks/vpopmail-5.4.0'
make: ** [all] Erro 2
Grato
Fabio Alan Pracz
alan@cibraus.com.br
