    Padrão Sendmail padrao slackware 9.1
    Po pessoal , faz 3 dias que tento colocar esse sendmail pra funcinar apenas para mandar mensagem e nao consigo.
    tenho que colocar o sendmail pra mandar msg urgente e nao vai nem que a vaca mame!
    estou com slackware 9.1
    sendmail padrao 8.12.10
    padrao.
    meus logs do /var/log/mailloig sao:
    DSN: Cannot send message for 5 days
    Jun 2 13:11:48 ipep sm-msp-queue[543]: i52G8Zjh000543: to=nobody, delay=00:00:04, xdelay=00:00:00, mailer=relay, pri=31646, relay=[127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:11:48 ipep sm-msp-queue[543]: i51MQ7HD000943: [email protected], delay=17:45:41, xdelay=00:00:00, mailer=relay, pri=120432, relay=[127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:11:48 ipep sm-msp-queue[543]: i51MQ7HD000943: i52G8Zji000543: sender notify: Warning: could not send message for past 4 hours
    Jun 2 13:11:48 ipep sm-msp-queue[543]: i52G8Zji000543: [email protected], delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=31807, relay=[127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:12:19 ipep sm-msp-queue[551]: i51MYu6E001042: [email protected], delay=17:37:23, xdelay=00:03:09, mailer=relay, pri=120412, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:12:19 ipep sm-msp-queue[551]: i51MYu6E001042: i52G9Aas000551: sender notify: Warning: could not send message for past 4 hours
    Jun 2 13:12:19 ipep sm-msp-queue[551]: i52G9Aas000551: [email protected], delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=31787, relay=[127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:12:19 ipep sm-msp-queue[551]: i51MQ7HD000943: [email protected], delay=17:46:12, xdelay=00:00:00, mailer=relay, pri=210432, relay=[127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:36:01 ipep sendmail[600]: daemon invoked without full pathname; kill -1 won't work
    Jun 2 13:36:01 ipep sendmail[601]: starting daemon (8.12.10): [email protected]:15:00
    Jun 2 13:38:12 ipep sendmail[628]: i52GbrCS000628: from=root, size=1, class=0, nrcpts=2, [email protected]
    Jun 2 13:41:48 ipep sm-mta[679]: starting daemon (8.12.10): [email protected]:25:00
    Jun 2 13:41:48 ipep sm-msp-queue[682]: starting daemon (8.12.10): [email protected]:25:00
    Jun 2 13:44:57 ipep sm-msp-queue[683]: i52G8Zjh000543: to=nobody, delay=00:33:13, xdelay=00:03:09, mailer=relay, pri=121646, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:44:57 ipep sm-msp-queue[683]: i52G9Aas000551: [email protected], delay=00:32:38, xdelay=00:00:00, mailer=relay, pri=121787, relay=[127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:44:57 ipep sm-msp-queue[683]: i52G8Zji000543: [email protected], delay=00:33:09, xdelay=00:00:00, mailer=relay, pri=121807, relay=[127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:44:58 ipep sm-msp-queue[683]: i51MYu6E001042: [email protected], delay=18:10:02, xdelay=00:00:00, mailer=relay, pri=210412, relay=[127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 13:44:58 ipep sm-msp-queue[683]: i51MQ7HD000943: [email protected], delay=18:18:51, xdelay=00:00:00, mailer=relay, pri=300432, relay=[127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 14:02:44 ipep sendmail[712]: i52H2fjn000712: from=root, size=1, class=0, nrcpts=2, [email protected]
    Jun 2 14:14:54 ipep sendmail[735]: i52HEWuu000735: from=root, size=0, class=0, nrcpts=2, [email protected]
    Jun 2 14:17:49 ipep sendmail[753]: i52HHWKD000753: from=root, size=0, class=0, nrcpts=2, [email protected]
    Jun 2 14:25:17 ipep sendmail[761]: i52HJM9p000761: from=root, size=0, class=0, nrcpts=2, [email protected]
    Jun 2 14:25:22 ipep sendmail[763]: i52HPLI7000763: from=root, size=6, class=0, nrcpts=1, msgid=<[email protected]>, [email protected]
    Jun 2 14:26:04 ipep sendmail[765]: i52HQ29o000765: from=root, size=0, class=0, nrcpts=1, [email protected]
    Jun 2 14:47:56 ipep sendmail[948]: i52HluEq000948: from=root, size=249, class=0, nrcpts=1, msgid=<[email protected]>, [email protected]
    Jun 2 14:51:05 ipep sendmail[948]: i52HluEq000948: [email protected], ctladdr=root (0/0), delay=00:03:09, xdelay=00:03:09, mailer=relay, pri=30249, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection timed out with [127.0.0.1]
    Jun 2 15:14:25 ipep sendmail[22292]: i52IENgS022292: from=root, size=2, class=0, nrcpts=0, [email protected]
    Jun 2 15:20:37 ipep sendmail[22303]: i52IKWUg022303: from=root, size=0, class=0, nrcpts=1, [email protected]
    Jun 2 15:22:59 ipep sendmail[22308]: i52IKtqj022308: from=root, size=0, class=0, nrcpts=2, [email protected]
    Jun 2 15:23:10 ipep sendmail[22316]: i52IN0L7022316: from=root, size=0, class=0, nrcpts=2, [email protected]
    Jun 2 15:30:19 ipep sendmail[22320]: i52INUeA022320: from=root, size=0, class=0, nrcpts=2, [email protected]
    Jun 2 15:33:08 ipep sendmail[22330]: i52IUTql022330: from=root, size=0, class=0, nrcpts=2, [email protected]
    Jun 2 15:35:16 ipep sendmail[22331]: i52IXK9C022331: from=root, size=0, class=0, nrcpts=2, [email protected]
    Jun 2 15:37:03 ipep sendmail[22337]: i52Iasto022337: from=root, size=0, class=0, nrcpts=2, [email protected]
    Jun 2 15:43:01 ipep sendmail[22348]: i52IeJHl022348: from=root, size=0, class=0, nrcpts=2, [email protected]
    Help manowss
    abracos!
    ideias?
    oq esta acontecendo?
    ele nao acha meu servidor de dns?
    qual é a desse sendmail?
    po ja configurei o postfix e foi lindo , pq esse sendmail é tao embacado assim =[
    + estou com um aplicativo que necessita dele =/
    to penando aqui =/
