    Padrão SAMBA ( Estou apanhando ) ERRO ao se LOGAR atraves do WIN
    Prezados,
    Estou com o seguinte problema:
    Instalei o conectiva 7 numa maquina, particionei da seguinte forma:
    para o " / " deixei 14 GB
    para o "swap" deixei 512 MB
    para o "/dados" ( onde terei um programa que estações WIN deveram acessar ) deixei 6 GB
    Montei o Samba da seguinte forma: ( smb.conf )
    [global]
    workgroup = azul
    server string = Servidor de Arquivos
    printcap name = /etc/printcap
    load printers = yes
    printing = lprng
    log file = /var/log/samba/log.%m
    max log size = 50
    debug level = 1
    security = domain
    password level = 8
    username level = 8
    encrypt passwords = yes
    smb passwd file = /etc/smbpasswd
    username map = /etc/smbusers
    ; include = /etc/smb.conf.%m
    socket options = TCP_NODELAY
    local master = yes
    os level = 33
    domain master = yes
    preferred master = yes
    domain logons = yes
    logon script = %U.bat
    logon path = \\server\netlogon
    dns proxy = no
    blocking locks = no
    locking = no
    [homes]
    comment = Home Directories
    browseable = no
    writable = yes
    [netlogon]
    comment = Network Logon Service
    path = /home/netlogon
    browseable = no
    guest ok = yes
    writable = no
    share modes = yes
    [printers]
    comment = All Printers
    path = /var/spool/samba
    browseable = yes
    guest ok = no
    writable = no
    printable = yes
    [dados]
    comment = Sevidor de Arquivos
    path = /dados
    browseable = yes
    public = yes
    guest ok = yes
    writable = yes
    share modes = yes
    create mask = 7777
    create mode = 7777
    force create mode = 7777
    directory mask = 7777
    force directory mode = 7777
    [escola]
    comment = Diretorio do programa da escola
    path = /dados/escola
    browseable = yes
    public=yes
    guest ok = yes
    writable = yes
    share modes = yes
    create mask = 7777
    create mode = 7777
    [cdrom]
    comment = Drive de cdrom
    path = /mnt/cdrom
    browseable = no
    public = yes
    guest ok = yes
    writable = no
    share modes = yes
    create mode = 0777
    force create mode = 0777
    #[outros]
    # comment = outros
    # path = /root
    # browseable = no
    # public = yes
    # guest ok = yes
    # writable = no
    # share modes = yes
    # create mode = 0777
    # force create mode = 0777
    O que esta acontecento é o seguinte:
    No WIN coloquei :
    Cliente para REDE NETWARE
    FAZER logon no NT
    no grupo coloquei AZUL
    porem quando ligo a maquina WINDOWS ele me pede o USUARIO, SENHA e SERVIDOR
    Eu coloco USUARIO: ADMIN
    SENHA: ( deixo em branco )
    SERVIDOR eu coloco SERVIDOR
    ELE me da a mensagem que não encontra o servidor:
    Quando peço para cancelar isso ele entra normal porem nao mapea o /dados que deveria.
    Vou no ambiente de rede e peco para procurar ele acha o servidor/dados quando peco para entrar nele ele da a seguinte mensagem
    /servidor/ipc$
    senha:
    Porque ele esta fazendo isso o que devo fazer para compartilhar com minhas estacoes WINDOWS o /dados que esta na maquina LINUX ?
    Eu levanto o SAMBA normal ./smb stop ./smb start !
    O que devo fazer mais ?
    Quem puder me ajudar eu agradeço.
    Abraço a todos
    Amigo,
    Se você quer que seu Samba aja como um PDC, você tem que utilizar o parâmetro security=user, não security=share.
    xstefanox,
    O que devo colocar no WINDOWS ???
    Por exemplo:
    Eu coloquei para fazer logon no dominio NT e coloquei o protocolo IPX como padrão ...
    ISSO ESTA CERTO ?
    Ate mais
    Não, não está.
    Aqui é como se configuram os clientes Windows 98.
    1 - Adicione o protocolo TCP/IP
    2 - Configure o Protocolo TCP/IP (configurações de rede em geral)
    3 - Defina o domínio. Este domínio deve ser o mesmo que você determinou no seu smb.conf. Para configurar o domínio você vai em "Ambiente de Rede > Propriedades > Clientes para rede Microsoft. em seguida, marque a opção "Efetuar logon no domínio do Windows NT" e preencha a caixa de texto com o domínio que está no seu smb.conf (no caso: "azul")
    Pronto, configurado.
    Padrão Continua nao logando !!
    Prezados.
    Como faço para me logar no SAMBA ?
    No windows quando entro em ambiente de rede e peço para ele procurar toda a rede ele encontra o meu servidor linux que esta montado o samba porem quando clico duas vezes sobre ele, vem a seguinte mensagem:
    \\server-linux\ipc$
    senha: ( que senha é essa ? )
    Não sei mais o que fazer !!!
    Ele não deveria estar mapeando o \dados que coloquei no arquivo smb.conf ?
    Ajudem me! please.
    Ate mais
    Amigo.... que windows vc usa nas estações? No caso de w2k vc precisa entrar no domínio lá nas propriedades de "Meu Computador"...
    Pra ingressar no domínio vc precisa adicionar o root no samba, e usa-lo qdo o sistema pedir usuário e senha, logogo ele reiniciará e pronto.
    É isso...
    kundera
    JIM,
    O windows é o 98....
    vc vendo meu SMB.CONF tem alguma coisa que eu possa mudar ?
    Pq. o windows quando eu entro no ambiente de rede e peco para ele procurar em toda a REDE ele acha o meu servidor mas nao conecta ? e pede a senha para o IPC$
    Honestamente, não estou entendendo mais nada... aqui no escritorio tenho este mesmo SMB.CONF configurado e esta rodando normal porém no meu CLIENTE esta dando este erro !!!
    OBRIGADO
    Até mais
    Vá nas configurações de rede dentro do Painel de Controle.
    No menu "Logon primário da rede", selecione "Cliente para redes Microsoft". Quando você se logar no Windows, você já irá estar se logando no servidor Samba.
    Espero que isso te ajude.
    Neste link tem um monte de informaçao sobre SAMBA
    https://under-linux.org/url.php?url=....cipsga.org.br
