    Padrão Squid + Iptables Redir (wierdo stuff)
    Bom , o problema eh o seguinte: o meu redir nao funciona de jeito nenhum quando vem da rede interna, ou seja, eh muito bizarro:
    10.94.1.5 - firewall (+proxy)
    192.168.1.7 - servidor web
    fw:~# tcpdump -i eth1 -n dst host 10.94.1.5 and dst port 80
    tcpdump: listening on eth1
    11:05:42.241464 192.168.1.236.4941 > 10.94.1.5.80: S 92569632:92569632(0) win 64240 <mss 1460,nop,nop,sackOK> (DF)
    11:05:45.227224 192.168.1.236.4941 > 10.94.1.5.80: S 92569632:92569632(0) win 64240 <mss 1460,nop,nop,sackOK> (DF)
    11:05:51.161680 192.168.1.236.4941 > 10.94.1.5.80: S 92569632:92569632(0) win 64240 <mss 1460,nop,nop,sackOK> (DF)
    3 packets received by filter
    0 packets dropped by kernel
    ou seja o pilantra nao me devolve nada... mas entretanto qdo eu vou pela internet.
    11:09:38.938007 200.217.88.20.61107 > 10.94.1.5.80: S 1600006107:1600006107(0) win 5840 <mss 1452,sackOK,timestamp 163698185 0,nop,wscale 0> (DF)
    11:09:39.159912 200.217.88.20.61107 > 10.94.1.5.80: . ack 784569905 win 5840 <nop,nop,timestamp 163698214 0> (DF)
    11:09:39.216678 200.217.88.20.61107 > 10.94.1.5.80: P 0:582(582) ack 1 win 5840 <nop,nop,timestamp 163698214 0> (DF)
    11:09:39.432384 200.217.88.20.61107 > 10.94.1.5.80: . ack 1 win 5840 <nop,nop,timestamp 163698243 0,nop,nop,sack sack 1 {218:219} > (DF)
    11:09:39.446260 200.217.88.20.61107 > 10.94.1.5.80: . ack 212 win 6432 <nop,nop,timestamp 163698243 1608818,nop,nop,sack sack 1 {218:219} > (DF)
    11:09:39.449906 200.217.88.20.61107 > 10.94.1.5.80: . ack 219 win 6432 <nop,nop,timestamp 163698243 1608818> (DF)
    11:09:39.463896 200.217.88.20.61107 > 10.94.1.5.80: F 582:582(0) ack 219 win 6432 <nop,nop,timestamp 163698244 1608818> (DF)
    eu tenho comunicacao.
    minha linha de iptables eh a seguinte:
    $IPTABLES -A FORWARD -d 192.168.1.7 -p tcp --dport 80 -j ACCEPT
    $IPTABLES -t nat -A PREROUTING -p tcp --dport 80 -d 10.94.1.5 -j DNAT --to 192.168.1.7
    meu firewall eh stateful e default policy de dropar.
    agora quando eu uso meu proxy eu gero o mesmo problema do redir de antes (se eu resolver o de cima, eu resolvo esse)
    # tcpdump -i lo -n
    11:11:57.434172 10.94.1.5.3858 > 10.94.1.5.80: S 2986185642:2986185642(0) win 32767 <mss 16396,sackOK,timestamp 320694592 0,nop,wscale 0> (DF)
    11:11:57.434206 10.94.1.5.80 > 10.94.1.5.3858: R 0:0(0) ack 2986185643 win 0 (DF)
    11:11:57.434963 10.94.1.5.3859 > 10.94.1.5.80: S 2985825885:2985825885(0) win 32767 <mss 16396,sackOK,timestamp 320694592 0,nop,wscale 0> (DF)
    11:11:57.434987 10.94.1.5.80 > 10.94.1.5.3859: R 0:0(0) ack 2985825886 win 0 (DF)
    11:11:57.435514 10.94.1.5.3860 > 10.94.1.5.80: S 2987901856:2987901856(0) win 32767 <mss 16396,sackOK,timestamp 320694592 0,nop,wscale 0> (DF)
    11:11:57.435562 10.94.1.5.80 > 10.94.1.5.3860: R 0:0(0) ack 2987901857 win 0 (DF)
    ele tentando se comunicar com ele mesmo (jah que o dns em questao do meu www resolve para ele) o proxy resolve e tenta falar com ele, logo eu tenho um problema pois ele nao me faz o redir.
    # telnet 10.94.1.5 80
    Trying 10.94.1.5...
    telnet: Unable to connect to remote host: Connection refused
    Cruel, se alguem tiver alguma luz me de um toque porque eu ainda nao consegui resolver esse pepino, esse me aconteceu depois que eu tive que colocar a seguinte diretiva no meu proxy:
    pois se eu nao por ela eu nao consiguo acessar o sites internos da rede que eu presciso (outra rede nao a minha, mas nao a internet)
    Xlab
    Ola mistymst, eh o seguinte posta sua regra do iptables para o redirecionamento do squid pra mim, pois eh possivel que o problema esteja la. Eu particulamente nao faco DNAT com o iptables prefiro fazer com o xinetd, alem de ser mais seguro a performance eh melhor pelo o fato que o proprio xinetd executar o daemon(como o httpd por exemplo).
    Aguardo.
    Hehe amigo voce nao entendeu meu proxy nao eh transparente e eu nao faco redir para ele.
    esse DNAT que eu fiz nao eh para o squid e sim para um servidor de web dentro da intranet.
    entretanto eu consigui resolver, nao da maneira que eu queria, resolver esse problema, pois o mesmo problema continua acontecendo, mas eu fiz um workaround que ta quebrando um galho.
    agora o redir de portas do xinetd se eu nao me engano eh para a mesma maquina ou eles faz port forwarding ??? pelo que eu me lembre ele so faz redir e tem que ter algum daemon rodando.
    Xlab
    Citação Postado originalmente por mistymst
    Ok, eu pensei que seu redirecionamento nao estava funcionando por cuasa do squid, pois nega um trafego http vindo da mesma maquina, o que poderia ta causando esse problema. Por exemplo
    iptables -t nat -A PREROUTING -p tcp --dport 80 -j REDIRECT --to-port 3128
    Nessa caso seu eu possuir um servidor web na mesma maquina o squid me mostrar acesso negado quando eu acessar tentar acessar o meu servidor web. Nesse caso espefico poderiamos colocar um execao tipo:
    -d ! IP_DO_SERVIDOR_WEB
    Ja sobre o xinetd eh isso mesmo ele tem que ter um daemon rodando, colocando "redirect = 192.168.0.1" qualquer tentativa de conexao com o dominio suposto como foo.bar.net sera direcionado para o ip em ridirect. Uso isso muito quando os meus usuarios tentam usar o sshd, quando eles tentam logar no meu domino eles sao redirecionado para outra servidor interno dentro da minha rede.
    falow
