    grilo
    uso o squide pra servidor de internet, mas quero começar a autenticar os usuarios, eu li tutorial de configuraçao squid.. segui os passos mas ta dando este erro
    root@net256:/etc/init.d# ./squid restart
    Restarting proxy server:
    Waiting ................2004/06/22 14:47:06| aclParseIpData: WARNING: Netmask masks away part of the specified IP in '10.48.0.0/8'
    2004/06/22 14:47:06| squid.conf line 17: acl proxy_auth REQUIRED
    2004/06/22 14:47:06| aclParseAclLine: Invalid ACL type 'REQUIRED'
    2004/06/22 14:47:06| parseConfigFile: line 19 unrecognized: 'auth_param basic program /usr/lib/squid/ncsa_auth /etc/squid/passwd'
    2004/06/22 14:47:06| parseConfigFile: line 20 unrecognized: 'auth_param basic children 5'
    2004/06/22 14:47:06| parseConfigFile: line 21 unrecognized: 'auth_param basic realm "Digite seu Login"'
    squid.
    alguem pode me ajudar?
    o q ta acontecendo/?
    valews
  2. Você está definindo as acl's de autenticação erroneamente:
    O certo seria:
    acl autenticacao proxy_auth REQUIRED
    Que versão do Squid vocẽ está utilizando?
    Abraços!
    grilo
    eu arrumei o requerid q vc falow, mas ainda ta dando pau..... o erro q esta dando agora é
    2004/06/22 16:17:17| aclParseAclLine: ACL 'all' already exists with different typ e, skipping.
    2004/06/22 16:17:17| parseConfigFile: line 19 unrecognized: 'auth_param basic pro gram /usr/lib/squid/ncsa_auth /etc/squid/passwd'
    2004/06/22 16:17:17| parseConfigFile: line 20 unrecognized: 'auth_param basic chi ldren 5'
    2004/06/22 16:17:17| parseConfigFile: line 21 unrecognized: 'auth_param basic rea lm 'Digite seu Login''
    squid.
    como esta meu squid.conf
    acl all src 10.48.0.0/24
    acl all proxy_auth REQUIRED
    auth_param basic realm 'Digite seu Login'
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl purge method PURGE
    acl CONNECT method CONNECT
    acl proibidos dstdom_regex "/etc/squid/proibidos"
    #http_acess allow all
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access deny proibidos
    icp_access allow all
    httpd_accel_port 80
    por favor me de uma mao.... valew kra...
  4. acl all src 10.48.0.0/24
    esse é um dos erros que está no seu arquivo, você tem duas acls all.
  5. Citação Postado originalmente por flipeexpl
    Pega a segunda acl e muda o nome dela para "autenticacao" por exemplo...
    Abraços!
  1. autenticacao no squid parent
    Último Post: 02-01-2004, 12:47
  2. autenticacao no squid
    Último Post: 16-09-2003, 08:09
  3. Autenticação no Squid de Usuário PDC Windows NT
    Por Hawthorn no fórum Servidores de Rede
    Último Post: 24-07-2003, 14:20
  4. Autenticação no Squid
    Por marmota_uou no fórum Servidores de Rede
    Respostas: 7
    Último Post: 15-04-2003, 17:09
  5. Liberar indereço sem pedir autenticação no squid
    Por AndrewAmorimdaSilva no fórum Servidores de Rede
    Último Post: 02-11-2002, 16:06
