pessoal...a hora que eu vou dar o comando indexmaker mrtg.cfg para gerar os graficos do MRTG, da o seguinte erro:
[[email protected] mrtg]# indexmaker mrtg.cfg > index.html
Possible precedence problem on bitwise | operator at /usr/bin/../lib/mrtg2/BER.pm line 601.
Can't locate package $VERSION for @MRTG_lib::ISA at /usr/bin/indexmaker line 49
main::BEGIN() called at /usr/bin/../lib/mrtg2/MRTG_lib.pm line 49
eval {...} called at /usr/bin/../lib/mrtg2/MRTG_lib.pm line 49
o meu mrtg.cfg esta assim:
[[email protected] mrtg]# vi mrtg.cfg
# Created by
# /usr/bin/cfgmaker [email protected]
### Global Config Options
# for UNIX
# WorkDir: /home/http/mrtg
# or for NT
WorkDir: /var/www/html/mrtg
Refresh: 600
Interval: 5
WriteExpires: Yes
Language: portuguese
RunAsDaemon: Yes
Options[_]: growright, bits
# WorkDir: c:\mrtgdata
### Global Defaults
aguardo respostas
abracos
atenciosamente
epf
