SEGUI ESTE TURORIAL
https://under-linux.org/modules.php?...icle&artid=250
FIZ TUDO CERTINHU MAS NAHROA QUE VOU LA NA MAKINA WIN 2000 E TENTO ACESSAR O SERVIDOR ELE PEDE SENHA E USER E NAO ENRA NEM A PAU, E QUANDO EU TENTO COLOCAR LA NO ESQUEMA PRA SETAR PARA O DOMINIO DO SERVER ELE FALA Q NÃO EXISTE O USER PARA O DOMINIO E EU FIZ CERTINHO IGUAL DO TUTORIAL O QUE TO FAZENDO DE ERRADO?? SALVEI O SMB.CONF PRA VCS VEREM QUE ESTA CERTINHO EU ACHO! HEHEHE ALGUEM SABE QUE ERRO É ESSE??? Q NAO ACEITA NENHUM USER?? TENHO QUE FAZER ISSO COM 2000 XP E 98, POR ENQUANTO TO SÓ NO 2000.
[global]
log file = /var/log/samba/log.%m
smb passwd file = /etc/samba/smbpasswd
admin users = douglas
local master = yes
domain master = yes
domain logons = yes
unix password sync = yes
null passwords = yes
load printers = yes
name resolve order = host wins bcast
socket options = TCP_NODELAY SO_SNDBUF=8192 SO_RCVBUF=8192
hosts equiv = /etc/hosts
hostname lookups = yes
username map = /etc/samba/smbusers
encrypt passwords = yes
hosts allow = 192.168.100.65
logon drive = Z:
logon path = \\%L\profiles
logon home = \\%L\profiles
password level = 0
wins support = true
dns proxy = no
netbios name = Aquiles
server string = Servidor de Arquivos (PDC)
remote announce = 192.168.255.255
workgroup = Marketing
os level = 65
debug level = 1
printcap name = cups
security = user
max log size = 100
domain logons = yes
domain logons = yes
[homes]
comment = Home Directories
browseable = no
writable = yes
[printers]
comment = All Printers
path = /var/spool/samba
browseable = no
guest ok = yes
writable = no
printable = yes
create mode = 0700
print command = lpr-cups -P %p -o raw %s -r
[print$]
path = /var/lib/samba/printers
browseable = yes
write list = @adm root
guest ok = yes
inherit permissions = yes
[pdf-generator]
path = /var/tmp
guest ok = No
printable = Yes
comment = PDF Generator (only valid users)
print command = /usr/share/samba/scripts/print-pdf %s ~%u //%L/%u %m %I "%J" &
[netlogon]
writeable = yes
path = /var/lib/samba/netlogon
force create mode = 0777
create mask = 0777
comment = Network Logon Service
public = yes
[profiles]
comment = %u
path = /home/%u
public = no
writable = yes
browseable = yes
printable = no
create mask = 0777
force create mode = 0770
[files]
comment = Arquivos
path = /home/files
public = no
writable = yes
browseable = yes
printable = no
write list = @users
valid users = @users
create mask = 0770
force directory mode = 0770
[TEMP]
writeable = yes
public = yes
path = /servidor_arquivos/temp
[RPM]
writeable = yes
public = yes
path = /servidor_arquivos/rpm
[TIMBRADO]
writeable = yes
public = yes
path = /servidor_arquivos/timbrado
[INTERNET]
writeable = yes
public = yes
path = /servidor_arquivos/internet
[WINDOWS]
writeable = yes
public = yes
path = /servidor_arquivos/windows
[PROGRAMAS]
writeable = yes
public = yes
path = /servidor_arquivos/programas
FIZ ASSIM MAS NAO VAI!!!
ops:
ops:
ops: :roll: :roll: :roll:
ops:
Citação
