    copynow
    Padrão ERRO NO PDC SEGUI O O TUTORIAL DAKI-MAS ELE NAUM ACEITA USER
    SEGUI ESTE TURORIAL
    https://under-linux.org/modules.php?...icle&artid=250
    FIZ TUDO CERTINHU MAS NAHROA QUE VOU LA NA MAKINA WIN 2000 E TENTO ACESSAR O SERVIDOR ELE PEDE SENHA E USER E NAO ENRA NEM A PAU, E QUANDO EU TENTO COLOCAR LA NO ESQUEMA PRA SETAR PARA O DOMINIO DO SERVER ELE FALA Q NÃO EXISTE O USER PARA O DOMINIO E EU FIZ CERTINHO IGUAL DO TUTORIAL O QUE TO FAZENDO DE ERRADO?? SALVEI O SMB.CONF PRA VCS VEREM QUE ESTA CERTINHO EU ACHO! HEHEHE ALGUEM SABE QUE ERRO É ESSE??? Q NAO ACEITA NENHUM USER?? TENHO QUE FAZER ISSO COM 2000 XP E 98, POR ENQUANTO TO SÓ NO 2000.
    [global]
    log file = /var/log/samba/log.%m
    smb passwd file = /etc/samba/smbpasswd
    admin users = douglas
    local master = yes
    domain master = yes
    domain logons = yes
    unix password sync = yes
    null passwords = yes
    load printers = yes
    name resolve order = host wins bcast
    socket options = TCP_NODELAY SO_SNDBUF=8192 SO_RCVBUF=8192
    hosts equiv = /etc/hosts
    hostname lookups = yes
    username map = /etc/samba/smbusers
    encrypt passwords = yes
    hosts allow = 192.168.100.65
    logon drive = Z:
    logon path = \\%L\profiles
    logon home = \\%L\profiles
    password level = 0
    wins support = true
    dns proxy = no
    netbios name = Aquiles
    server string = Servidor de Arquivos (PDC)
    remote announce = 192.168.255.255
    workgroup = Marketing
    os level = 65
    debug level = 1
    printcap name = cups
    security = user
    max log size = 100
    domain logons = yes
    domain logons = yes
    [homes]
    comment = Home Directories
    browseable = no
    writable = yes
    [printers]
    comment = All Printers
    path = /var/spool/samba
    browseable = no
    guest ok = yes
    writable = no
    printable = yes
    create mode = 0700
    print command = lpr-cups -P %p -o raw %s -r
    [print$]
    path = /var/lib/samba/printers
    browseable = yes
    write list = @adm root
    guest ok = yes
    inherit permissions = yes
    [pdf-generator]
    path = /var/tmp
    guest ok = No
    printable = Yes
    comment = PDF Generator (only valid users)
    print command = /usr/share/samba/scripts/print-pdf %s ~%u //%L/%u %m %I "%J" &
    [netlogon]
    writeable = yes
    path = /var/lib/samba/netlogon
    force create mode = 0777
    create mask = 0777
    comment = Network Logon Service
    public = yes
    [profiles]
    comment = %u
    path = /home/%u
    public = no
    writable = yes
    browseable = yes
    printable = no
    create mask = 0777
    force create mode = 0770
    [files]
    comment = Arquivos
    path = /home/files
    public = no
    writable = yes
    browseable = yes
    printable = no
    write list = @users
    valid users = @users
    create mask = 0770
    force directory mode = 0770
    [TEMP]
    writeable = yes
    public = yes
    path = /servidor_arquivos/temp
    [RPM]
    writeable = yes
    public = yes
    path = /servidor_arquivos/rpm
    [TIMBRADO]
    writeable = yes
    public = yes
    path = /servidor_arquivos/timbrado
    [INTERNET]
    writeable = yes
    public = yes
    path = /servidor_arquivos/internet
    [WINDOWS]
    writeable = yes
    public = yes
    path = /servidor_arquivos/windows
    [PROGRAMAS]
    writeable = yes
    public = yes
    path = /servidor_arquivos/programas
    FIZ ASSIM MAS NAO VAI!!!
    ops: ops: ops: :roll: :roll: :roll:
    pra windows 98 nao precisa... mas pra windows 2000 e windows XP precisa criar um usuario de maquina com o nome da estacao windows. Senao a estacao nao ingressar no dominio...
    e além disso se não me engano deve-se fazer umas alterações no regedit das máquinas ruindows 2000 e XP para que funcione corretamente
    isso se for samba 2.x samba 3 nao precisa mais... poiseh... qual a versao do samba?
    Padrão HeHe .. :P
    Boas.. eu tb tive esse problema, felizmente n apanhei dor de cabeça, pkausa do rwindows :P, apanhei o gajo a tempo...
    Pra vc resolver esse problema, basta adicionar a máquina e o utilizador ao dominio 2 vezes (pelo windows klaro)
    há primeria vez ele vai dizer "Seja bem vindo a dominio xpto.." dps pede pra reiniciar, vc reinicia, ma diz utilizador invalido, então a solução é repetir o processo de novo, e vai ver como funciona logo
    Não me perguntem pq... eu tb n percebo, mas é mesmo assim .. verdade..
    ta loco... quando ingressa no dominio, a estacao windows reinicia, e sai tudo funcionando...
    hosts allow = 192.168.100.65 <--- q merda eh essa? soh permite 1 maquina a se conectar no samba??
    soh precisa-se saber qual a versao do samba. Sugiro a ultima 3.alguma.coisa, tbm sugiro que seja lida com paciencia e atencao. Samba eh muito facil, nao importa sua configuracao.
    mas antes de ingressar no dominio tu deve criar as contas dos usuario e criar uma conta de maquina....
    PRA INGRESSAR NO DOMÍNIO VC TEM QUE USAR USUÁRIO E SENHA DE ROOT!!!!!!!!!!!!!!!!
    Eu acho melhor voce usar uma estaçao com Win 98 para testar as configuraçoes e depois que tiver todo configurado e testado voce inicia a configuraçao das estaçoes Rwin 2000 e XP.
    As estaçoes Win 98 nao tem muits frescuras com conta de usuarios nos dois lados e etc...
    fake
    Padrão ...
    Qual é a versão do samba que você está usando?
    Eu configurei o um samba na versão 3.0.3 pra win2000 e NT.
    Isso em um Fedora 2.
    Não precisa mexer em registro do windows e nem colocar $ para nome da maquina.
    Qual distribuição você tá usando?
    Seguinte,, eu envie um artigo para os responsaveis aqui da underlinux para eles publicarem, vai fazer duas semanas, acho que não publicaram pois já tem muito artigo sobre o assunto, mas pelo menos nesse eu não precisei fazer muitas alterações.
    No artigo segue o meu exemplo de smb.conf , não tenho como postar aqui pois formatei o meu micro, fico lhe devendo essa.
    Mas ainda aguardo o pessoal publicar ou ao menos colocar no forum o meu artigo.
    Responde ae as perguntas, vamos ver se dá para ajudar.
    Juarez Junior
