-  vpn duvida
 vpn duvida
							Estou montado uma vpn..parte do kernel..ja esta ok..de freeswan esta ok
ja fiz..isso..aqui
rm /etc/ipsec.secrets
ipsec newhostkey --output /etc/ipsec.secrets --hostname `hostname --fqdn` 2048
blz...
so quando vou editar o vi /etc/ipsec.secrets
ela gerou uma chave
tenho que por ela inteira no meu arquivo /etc/ipsec.secrets
 #pubkey=0sAQNjGD5T1vsGj88hvtMCRNtqX+WaGskcuuA9x6NwO62OwZoaHLktduLMwm4REW0n43/j2U95CIL9yA3C7cqy+tMu/tGfsMUq0w7cI7D2LHEe
25u0ftkNXqxNfkKl+Uwy0H4DQZ6SXTMGbOMiTXFc6ll6JMYIdr2cxtxVj/Vofsz2tpPqXSTO5dmu3c7X7mImgSxF3vONQgRuWrp4psg/HO6BloFLUjLb8YVd1pGK8e
FMj1SP5yluEtjgWSxOcC32QWZ9s+aQ1XuMLYBPIf78SHcPXd3jjWvHkowdutZJ6IFhfJh+aR5zaguNtNJRb6IRmDGD3hLvIh3BsBAU+YFCD/NTZ6SYpSdFQM0OK8eM
/crU7Z495
vi /etc/ipsec.conf
fica assim ...
leftrsasigkey=0sAQNjGD5T1vsGj88hvtMCRNtqX+WaGskcuuA9x6NwO62OwZoaHLktduLMwm4REW0n43/j2U95CIL9yA3C7cqy+tMu/tGfsMUq0w7cI7D2LHEe
/crU7Z495
que pode tirar essa duvida..agradeco...
# sample VPN connection  conn sample matriz-filial
        type=tunnel
        # Left security gateway, subnet behind it, next hop toward right.
        type=tunnel
        left=200.233.150.90
        leftsubnet=192.168.0.0/24
        leftnexthop=200.233.150.1
/crU7Z495
        # Right security gateway, subnet behind it, next hop toward left.
        right=200.150.229.10
        rightsubnet=10.0.0.0/24
        rightnexthop=200.233.150.1
        rightrsasigkey= Esse to gerando..chave
        # To authorize this connection, but not actually start it, at startup,
        # uncomment this.
        auto=start
 vpn duvida
							vc tem q usar a mesma chave em ambos os lados
[]'s
 blz..entao
							do jeito que esta ai..esta certo..entao .....por que chava ser muito grande...
