    visitante
    Padrão windows xp naum entra no dominio samba
    caros colegas, configurei o samba do fedora core 2 e esta acontecendo o seguinte erro.
    quando vou adicionar uma maquina win xp ela manda uma mensagem de erro: "Não foi possivel localizar o usuario root no dominio indicado"
    aki esta meu smb.conf
    [global]
    # workgroup = NT-Domain-Name or Workgroup-Name
    workgroup = ORBITAL
    # server string is the equivalent of the NT Description field
    server string = Servidor de Dominio
    printcap name = /etc/printcap
    load printers = yes
    log file = /var/log/samba/%m.log
    max log size = 50
    security = user
    encrypt passwords = yes
    smb passwd file = /etc/samba/smbpasswd
    unix password sync = Yes
    passwd program = /usr/bin/passwd %u
    passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
    username map = /etc/samba/smbusers
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    local master = yes
    os level = 99
    domain master = yes
    preferred master = yes
    domain logons = yes
    logon script = %m.bat
    logon script = script.bat
    logon path =
    #adicionar uma maquina no dominio
    add user script = /usr/sbin/useradd -d /dev/null -g 100 -s /bin/false -M %u
    #usuarios administradores do samba
    admin users = root
    dns proxy = no
    #============================ Share Definitions ==============================
    # idmap uid = 16777216-33554431
    # idmap gid = 16777216-33554431
    # template shell = /bin/false
    # winbind use default domain = no
    [homes]
    comment = Diretorios Pessoais
    browseable = no
    writable = yes
    # Un-comment the following and create the netlogon directory for Domain Logons
    [netlogon]
    comment = Network Logon Service
    path = /etc/samba/netlogon
    guest ok = yes
    writable = no
    share modes = no
    # NOTE: If you have a BSD-style print system there is no need to
    # specifically define each individual printer
    [printers]
    comment = All Printers
    path = /var/spool/samba
    browseable = no
    # Set public = yes to allow user 'guest account' to print
    guest ok = no
    writable = no
    printable = yes
    tenta um smbpasswd -a root
    Caro amigo .....
    Tem uma opção que não me lembro agora no Windows XP, que você entra em ferramentas administrativas, e vai aparecer subopções que vc vai encontrar algo como logar no servidor samba.
    Na verdade, vc vai alterar no seu windows , algo relacionado a PlainPasswd.
    Estou procurando aqui. Se eu encontrar eu posto novamente.
    Inté .......... :wink:
    Adicionou o usuário root no seu smbpasswd? Quero lembrar que não é porque o usuário root do GNU/Linux está logando na máquina Windows é que ele vai ter poderes de administrador. Para mais informações, consulte o Focalinux...
    http://focalinux.cipsga.org.br
    Abraços!
    Caro amigo .....
    Aqui na empresa, quando queremos que uma máquina Windows XP, se conecte no servidor samba fazemos o seguinte no XP :
    Vá em Ferramentas Administrativas
    Diretivas Segurança Local
    Diretivas Locais
    Opções de Segurança
    Veja no lado direito a opção Cliente para Rede Microsoft
    Depois clique em Enviar Senha não Criptografada p/Conectar a Servidor SMB.
    Clique 2 vezes e manda aplicar para ativar essa opção. Feito isso dê OK e reinicie o computador.
    Pelo menos fazemos assim aqui na empresa e nunca tivemos problemas de conexão do XP no servidor Samba ...
    Um grande abraço ..... :wink:
