    Padrão SLACKWARE PATCH KERNEL
    Ola , gostaria de saber como fasso OS PATCHES DO MEU KERNEL , de seguranca ... obrigado
    Jan 2004
    Capital do Triângulo
    Installation instructions:
    Use upgradepkg to install the new packages.
    After installing the kernel-ide package you will need to run lilo ('lilo'
    at a command prompt) or create a new system boot disk ('makebootdisk'), and
    reboot.
    If desired, a kernel from the kernels/ directory may be used instead. For
    example, to use the kernel in kernels/scsi.s/, you would copy it to the
    boot directory like this:
    cd kernels/scsi.s
    cp bzImage /boot/vmlinuz-scsi.s-2.4.26
    Create a symbolic link:
    ln -sf /boot/vmlinuz-scsi.s-2.4.26 /boot/vmlinuz
    Then, run 'lilo' or create a new system boot disk and reboot.
    Slackware Linux Security Team
    http://slackware.com/gpg-key
    [email protected]
    Mr_Mind
    pergunta mal feita! deves querer saber como aplicas patches de segurança no teu kernel não?!
    man patch
