Olá,
Tenho um servidor CL8 que está travando inesperadamente, muitas das vezes é logo após ele ser ligado. Abaixo está o conteúdo do arquivo messages. Observei que após as 8:03:00 os registro ficam intercalando com registros as 8:02:50.
O servidor deu uma estabilizada depois que parei o snort e o ipsec, mas ainda deu uma travada após isso.
Alguém consegue identificar algum problema nesse log?
Desde já agradeço.
Aug 14 08:02:59 servidor1 syslogd 1.4.1: restart.
Aug 14 08:02:59 servidor1 syslog: syslogd startup succeeded
Aug 14 08:02:59 servidor1 syslog: klogd startup succeeded
Aug 14 08:02:59 servidor1 kernel: klogd 1.4.1, log source = /proc/kmsg started.
Aug 14 08:02:59 servidor1 kernel: Inspecting /boot/System.map-2.4.18-2cl
Aug 14 08:02:59 servidor1 random: Initializing random number generator: succeeded
Aug 14 08:02:59 servidor1 kernel: Loaded 15974 symbols from /boot/System.map-2.4.18-2cl.
Aug 14 08:02:59 servidor1 kernel: Symbols match kernel version 2.4.18.
Aug 14 08:02:59 servidor1 kernel: Loaded 238 symbols from 10 modules.
Aug 14 08:02:59 servidor1 kernel: Linux version 2.4.18-2cl (root@mapi2.distro.conectiva) (gcc version 2.95.3 20010315 (release)) #1 Mon Mar 11 01:53:17 BRT 2002
Aug 14 08:02:59 servidor1 kernel: BIOS-provided physical RAM map:
Aug 14 08:02:59 servidor1 kernel: BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
Aug 14 08:02:59 servidor1 kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Aug 14 08:02:59 servidor1 kernel: BIOS-e820: 0000000000100000 - 000000000f7f0000 (usable)
Aug 14 08:02:59 servidor1 kernel: BIOS-e820: 000000000f7f0000 - 000000000f7f3000 (ACPI NVS)
Aug 14 08:02:59 servidor1 kernel: BIOS-e820: 000000000f7f3000 - 000000000f800000 (ACPI data)
Aug 14 08:03:00 servidor1 kernel: BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
Aug 14 08:03:00 servidor1 kernel: On node 0 totalpages: 63472
Aug 14 08:03:00 servidor1 kernel: zone(0): 4096 pages.
Aug 14 08:03:00 servidor1 kernel: zone(1): 59376 pages.
Aug 14 08:03:00 servidor1 kernel: zone(2): 0 pages.
Aug 14 08:03:00 servidor1 kernel: Kernel command line: auto BOOT_IMAGE=linux ro root=302
Aug 14 08:03:00 servidor1 kernel: Initializing CPU#0
Aug 14 08:03:00 servidor1 kernel: Detected 797.982 MHz processor.
Aug 14 08:03:00 servidor1 netfs: Mounting other filesystems: succeeded
Aug 14 08:03:00 servidor1 kernel: Console: colour VGA+ 80x25
Aug 14 08:03:00 servidor1 kernel: Calibrating delay loop... 1592.52 BogoMIPS
Aug 14 08:02:50 servidor1 rc.sysinit: Mounting proc filesystem: succeeded
Aug 14 08:03:00 servidor1 kernel: Memory: 247392k/253888k available (1044k kernel code, 6112k reserved, 298k data, 228k init, 0k highmem)
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.ip_forward = 1
Aug 14 08:03:00 servidor1 kernel: Dentry-cache hash table entries: 32768 (order: 6, 262144 bytes)
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.conf.all.rp_filter = 1
Aug 14 08:03:00 servidor1 kernel: Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.conf.default.rp_filter = 1
Aug 14 08:03:01 servidor1 kernel: Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
Aug 14 08:02:50 servidor1 sysctl: kernel.sysrq = 0
Aug 14 08:03:01 servidor1 kernel: Buffer-cache hash table entries: 16384 (order: 4, 65536 bytes)
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.conf.all.log_martians = 1
Aug 14 08:03:01 servidor1 kernel: Page-cache hash table entries: 65536 (order: 6, 262144 bytes)
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.ip_dynaddr = 0
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.icmp_echo_ignore_broadcasts = 1
Aug 14 08:03:02 servidor1 kernel: CPU: L1 I cache: 16K, L1 D cache: 16K
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.conf.all.accept_source_route = 0
Aug 14 08:03:02 servidor1 sshd: sshd startup succeeded
Aug 14 08:03:02 servidor1 sshd[723]: Server listening on 0.0.0.0 port 22.
Aug 14 08:03:02 servidor1 kernel: CPU: L2 cache: 256K
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.icmp_echo_ignore_all = 0
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.icmp_ratemask = 6169
Aug 14 08:03:02 servidor1 kernel: CPU serial number disabled.
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.icmp_ratelimit = 100
Aug 14 08:03:03 servidor1 kernel: Intel machine check architecture supported.
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.tcp_syncookies = 1
Aug 14 08:03:03 servidor1 kernel: Intel machine check reporting enabled on CPU#0.
Aug 14 08:02:50 servidor1 sysctl: net.ipv4.conf.all.accept_redirects = 0
Aug 14 08:02:50 servidor1 rc.sysinit: Configuring kernel parameters: succeeded
Aug 14 08:03:03 servidor1 keytable: Loading keymap:
Aug 14 08:02:50 servidor1 date: Sat Aug 14 08:02:44 BRT 2004
Aug 14 08:03:03 servidor1 keytable: Loading /usr/lib/kbd/keymaps/i386/qwerty/br-abnt2.kmap.gz
Aug 14 08:03:03 servidor1 kernel: CPU: Intel Pentium III (Coppermine) stepping 06
Aug 14 08:02:50 servidor1 rc.sysinit: Setting clock : Sat Aug 14 08:02:44 BRT 2004 succeeded
Aug 14 08:03:03 servidor1 keytable: Loading system font:
Aug 14 08:03:03 servidor1 kernel: Enabling fast FPU save and restore... done.
Aug 14 08:02:50 servidor1 rc.sysinit: Loading default keymap succeeded
Aug 14 08:03:03 servidor1 keytable: Format: 3
Aug 14 08:03:03 servidor1 kernel: Enabling unmasked SIMD FPU exception support... done.
Aug 14 08:02:50 servidor1 setsysfont: Format: 3
Aug 14 08:03:03 servidor1 kernel: Checking 'hlt' instruction... OK.
Aug 14 08:02:50 servidor1 rc.sysinit: Setting default font (lat1u-16): succeeded
Aug 14 08:03:03 servidor1 rc: Starting keytable: succeeded
Aug 14 08:03:03 servidor1 kernel: POSIX conformance testing by UNIFIX
Aug 14 08:02:50 servidor1 rc.sysinit: Activating swap partitions: succeeded
Aug 14 08:03:03 servidor1 kernel: mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
Aug 14 08:02:50 servidor1 rc.sysinit: Setting hostname servidor1.localdomain: succeeded
Aug 14 08:03:03 servidor1 kernel: mtrr: detected mtrr type: Intel
Aug 14 08:02:50 servidor1 rc.sysinit: Initializing USB controller (usb-uhci
Aug 14 08:03:03 servidor1 kernel: PCI: PCI BIOS revision 2.10 entry at 0xfb0b0, last bus=1
Aug 14 08:02:50 servidor1 rc.sysinit: Mounting USB filesystem: succeeded
Aug 14 08:03:04 servidor1 kernel: PCI: Using configuration type 1
Aug 14 08:02:50 servidor1 rc.sysinit: Remounting root filesystem in read-write mode: succeeded
Aug 14 08:03:04 servidor1 kernel: PCI: Probing PCI hardware
Aug 14 08:02:54 servidor1 rc.sysinit: Activating logical volumes (LVM IOP 10): succeeded
Aug 14 08:03:05 servidor1 kernel: Unknown bridge resource 0: assuming transparent
Aug 14 08:02:54 servidor1 rc.sysinit: Umounting the initrd image: succeeded
Aug 14 08:03:05 servidor1 kernel: Unknown bridge resource 2: assuming transparent
Aug 14 08:02:55 servidor1 rc.sysinit: Finding module dependencies: succeeded
Aug 14 08:03:06 servidor1 kernel: PCI: Using IRQ router VIA [1106/0686] at 00:07.0
Aug 14 08:02:55 servidor1 rc.sysinit: Checking filesystems succeeded
Aug 14 08:03:06 servidor1 kernel: isapnp: Scanning for PnP cards...
Aug 14 08:02:55 servidor1 rc.sysinit: Mounting local filesystems: succeeded
Aug 14 08:03:07 servidor1 kernel: isapnp: No Plug & Play device found
Aug 14 08:02:55 servidor1 rc.sysinit: Enabling swap space: succeeded
Aug 14 08:03:07 servidor1 kernel: Linux NET4.0 for Linux 2.4
Aug 14 08:02:57 servidor1 init: Entering runlevel: 3
Aug 14 08:03:08 servidor1 kernel: Based upon Swansea University Computer Society NET3.039
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.ip_forward = 1
Aug 14 08:03:08 servidor1 kernel: Initializing RT netlink socket
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.conf.all.rp_filter = 1
Aug 14 08:03:09 servidor1 kernel: apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16)
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.conf.default.rp_filter = 1
Aug 14 08:03:10 servidor1 kernel: Starting kswapd
Aug 14 08:02:57 servidor1 sysctl: kernel.sysrq = 0
Aug 14 08:03:10 servidor1 kernel: VFS: Diskquotas version dquot_6.4.0 initialized
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.conf.all.log_martians = 1
Aug 14 08:03:11 servidor1 kernel: Detected PS/2 Mouse Port.
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.ip_dynaddr = 0
Aug 14 08:03:11 servidor1 kernel: pty: 256 Unix98 ptys configured
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.icmp_echo_ignore_broadcasts = 1
Aug 14 08:03:12 servidor1 kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI ISAPNP enabled
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.conf.all.accept_source_route = 0
Aug 14 08:03:12 servidor1 kernel: ttyS00 at 0x03f8 (irq = 4) is a 16550A
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.icmp_echo_ignore_all = 0
Aug 14 08:03:13 servidor1 kernel: Real Time Clock Driver v1.10e
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.icmp_ratemask = 6169
Aug 14 08:03:13 servidor1 kernel: block: 128 slots per queue, batch=32
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.icmp_ratelimit = 100
Aug 14 08:03:14 servidor1 kernel: RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.tcp_syncookies = 1
Aug 14 08:03:14 servidor1 kernel: Uniform Multi-Platform E-IDE driver Revision: 6.31
Aug 14 08:02:57 servidor1 sysctl: net.ipv4.conf.all.accept_redirects = 0
Aug 14 08:03:15 servidor1 kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Aug 14 08:02:57 servidor1 network: Setting network parameters: succeeded
Aug 14 08:03:15 servidor1 kernel: VP_IDE: IDE controller on PCI bus 00 dev 39
Aug 14 08:02:58 servidor1 network: Bringing up interface lo: succeeded
Aug 14 08:03:16 servidor1 kernel: VP_IDE: chipset revision 6
Aug 14 08:02:58 servidor1 network: Bringing up interface eth0: succeeded
Aug 14 08:03:16 servidor1 kernel: VP_IDE: not 100%% native mode: will probe irqs later
Aug 14 08:02:59 servidor1 network: Bringing up interface eth1: succeeded
Aug 14 08:03:17 servidor1 kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Aug 14 08:03:17 servidor1 kernel: VP_IDE: VIA vt82c686b (rev 40) IDE UDMA100 controller on pci00:07.1
Aug 14 08:03:17 servidor1 kernel: ide0: BM-DMA at 0xc000-0xc007, BIOS settings: hdaMA, hdbio
Aug 14 08:03:18 servidor1 kernel: ide1: BM-DMA at 0xc008-0xc00f, BIOS settings: hdcio, hddio
Aug 14 08:03:18 servidor1 kernel: hda: SAMSUNG SV2042H, ATA DISK drive
Aug 14 08:03:18 servidor1 kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Aug 14 08:03:19 servidor1 kernel: hda: 39865392 sectors (20411 MB) w/426KiB Cache, CHS=2481/255/63
Aug 14 08:03:19 servidor1 kernel: ide-floppy driver 0.97.sv
Aug 14 08:03:19 servidor1 kernel: Partition check:
Aug 14 08:03:20 servidor1 kernel: hda: hda1 hda2
Aug 14 08:03:20 servidor1 kernel: Floppy drive(s): fd0 is 1.44M
Aug 14 08:03:20 servidor1 kernel: FDC 0 is a post-1991 82077
Aug 14 08:03:20 servidor1 kernel: Cronyx Ltd, Synchronous PPP and CISCO HDLC (c) 1994
Aug 14 08:03:21 servidor1 kernel: Linux port (c) 1998 Building Number Three Ltd & Jan "Yenya" Kasprzak.
Aug 14 08:03:21 servidor1 kernel: ide-floppy driver 0.97.sv
Aug 14 08:03:21 servidor1 kernel: md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
Aug 14 08:03:22 servidor1 kernel: md: Autodetecting RAID arrays.
Aug 14 08:03:22 servidor1 kernel: md: autorun ...
Aug 14 08:03:22 servidor1 kernel: md: ... autorun DONE.
Aug 14 08:03:23 servidor1 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Aug 14 08:03:23 servidor1 kernel: IP Protocols: ICMP, UDP, TCP, IGMP
Aug 14 08:03:23 servidor1 kernel: IP: routing cache hash table of 2048 buckets, 16Kbytes
Aug 14 08:03:24 servidor1 kernel: TCP: Hash tables configured (established 16384 bind 16384)
Aug 14 08:03:24 servidor1 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Aug 14 08:03:24 servidor1 kernel: NET4: AppleTalk 0.18a for Linux NET4.0
Aug 14 08:03:24 servidor1 kernel: RAMDISK: Compressed image found at block 0
Aug 14 08:03:25 servidor1 kernel: Freeing initrd memory: 305k freed
Aug 14 08:03:25 servidor1 kernel: EXT2-fs warning: checktime reached, running e2fsck is recommended
Aug 14 08:03:25 servidor1 kernel: VFS: Mounted root (ext2 filesystem).
Aug 14 08:03:26 servidor1 kernel: Journalled Block Device driver loaded
Aug 14 08:03:26 servidor1 kernel: kjournald starting. Commit interval 5 seconds
Aug 14 08:03:26 servidor1 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Aug 14 08:03:27 servidor1 kernel: Freeing unused kernel memory: 228k freed
Aug 14 08:03:27 servidor1 kernel: Adding Swap: 120448k swap-space (priority -1)
Aug 14 08:03:28 servidor1 kernel: usb.c: registered new driver usbdevfs
Aug 14 08:03:28 servidor1 kernel: usb.c: registered new driver hub
Aug 14 08:03:28 servidor1 kernel: usb-uhci.c: $Revision: 1.275 $ time 02:11:50 Mar 11 2002
Aug 14 08:03:29 servidor1 kernel: usb-uhci.c: High bandwidth mode enabled
Aug 14 08:03:29 servidor1 kernel: PCI: Found IRQ 11 for device 00:07.2
Aug 14 08:03:29 servidor1 kernel: PCI: Sharing IRQ 11 with 00:07.3
Aug 14 08:03:30 servidor1 kernel: PCI: Sharing IRQ 11 with 00:0e.0
Aug 14 08:03:30 servidor1 kernel: usb-uhci.c: USB UHCI at I/O 0xc400, IRQ 11
Aug 14 08:03:30 servidor1 kernel: usb-uhci.c: Detected 2 ports
Aug 14 08:03:30 servidor1 kernel: usb.c: new USB bus registered, assigned bus number 1
Aug 14 08:03:31 servidor1 kernel: hub.c: USB hub found
Aug 14 08:03:31 servidor1 kernel: hub.c: 2 ports detected
Aug 14 08:03:31 servidor1 kernel: PCI: Found IRQ 11 for device 00:07.3
Aug 14 08:03:31 servidor1 kernel: PCI: Sharing IRQ 11 with 00:07.2
Aug 14 08:03:31 servidor1 kernel: PCI: Sharing IRQ 11 with 00:0e.0
Aug 14 08:03:32 servidor1 kernel: usb-uhci.c: USB UHCI at I/O 0xc800, IRQ 11
Aug 14 08:03:32 servidor1 kernel: usb-uhci.c: Detected 2 ports
Aug 14 08:03:32 servidor1 kernel: usb.c: new USB bus registered, assigned bus number 2
Aug 14 08:03:32 servidor1 kernel: hub.c: USB hub found
Aug 14 08:03:33 servidor1 kernel: hub.c: 2 ports detected
Aug 14 08:03:33 servidor1 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
Aug 14 08:03:33 servidor1 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Aug 14 08:03:33 servidor1 kernel: EXT3 FS 2.4-0.9.17, 10 Jan 2002 on ide0(3,2), internal journal
Aug 14 08:03:33 servidor1 kernel: LVM version 1.0.1-rc4(ish)(03/10/2001) module loaded
Aug 14 08:03:34 servidor1 kernel: loop: loaded (max 8 devices)
Aug 14 08:03:34 servidor1 kernel: dmfe: Davicom DM9xxx net driver, version 1.36.4 (2002-01-17)
Aug 14 08:03:34 servidor1 kernel: PCI: Found IRQ 10 for device 00:0a.0
Aug 14 08:03:34 servidor1 kernel: PCI: Sharing IRQ 10 with 00:07.5
Aug 14 08:03:35 servidor1 kernel: eth0: Davicom DM9102 at pci00:0a.0, 00:80:ad:0a:5d:41, irq 10.
Aug 14 08:03:35 servidor1 kernel: 8139too Fast Ethernet driver 0.9.24
Aug 14 08:03:35 servidor1 kernel: PCI: Found IRQ 11 for device 00:0e.0
Aug 14 08:03:35 servidor1 kernel: PCI: Sharing IRQ 11 with 00:07.2
Aug 14 08:03:36 servidor1 kernel: PCI: Sharing IRQ 11 with 00:07.3
Aug 14 08:03:36 servidor1 kernel: eth1: RealTek RTL8139 Fast Ethernet at 0xd0078000, 00:10:dc:02:84:ab, IRQ 11
Aug 14 08:03:36 servidor1 kernel: eth1: Setting 100mbps half-duplex based on auto-negotiated partner ability 40a1.
Aug 14 08:03:47 servidor1 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Aug 14 08:03:47 servidor1 kernel: ip_conntrack (1983 buckets, 15864 max)
