    hssouza
    Gostaria de saber se alguém já passou por este problema. É minha primeira expêriencia com o assunto e tô levando surra. Quallquer ajuda é bem vinda.
    Sistema com Mandrake 10 e drbd-7.0.2
    O drdb.conf foi extraido de parte do arquivo que acompanha os fontes.
    servidor_001#/etc/init.d/drbd start
    etc/init.d/drbd: line 1: resource: command not found
    /etc/init.d/drbd: line 2: protocol: command not found
    /etc/init.d/drbd: line 3: incon-degr-cmd: command not found
    /etc/init.d/drbd: /etc/drbd.conf: line 5: syntax error near unexpected token `}'
    /etc/init.d/drbd: /etc/drbd.conf: line 5: ` startup { wfc-timeout 0; degr-wfc-timeout 120; }'
    Starting DRBD resources: [drbd].
    drbd.conf
    resource drbd {
    protocol C;
    incon-degr-cmd "echo '!DRBD! pri on incon-degr' | wall ; sleep 60 ; halt -f";
    disk { on-io-error detach; }
    net { timeout 60; connect-int 10; ping-int 10;
    max-buffers 2048; max-epoch-size 2048; }
    syncer { rate 10M; }
    on servidor_001 {
    address 192.168.1.13:7790;
    disk /dev/sda6; device /dev/drbd0; meta-disk "internal";
    on servidor_002 {
    device "/dev/drbd0"; disk "/dev/sda6"; meta-disk "internal";
    address 192.168.1.12:7790;
    lsmod
    Module Size Used by
    drbd 154228 1
    md5 4896 1
    ipv6 265024 14
    af_packet 23368 0
    ide-floppy 20864 0
    ide-tape 39152 0
    ide-cd 43844 0
    cdrom 40640 1 ide-cd
    floppy 63188 0
    eepro100 32492 0
    mii 6144 1 eepro100
    e1000 87172 0
    intel-agp 19708 1
    agpgart 33996 1 intel-agp
    rtc 14056 0
    ext3 122600 1
    jbd 66104 1 ext3
    sd_mod 18592 4
    aacraid 45248 3
    scsi_mod 121552 2 sd_mod,aacrai
  2. Se o kernel for 2.4, aconselho o uso do drbd-0.6.12
    []´s
    Marcos Pitanga
    Linux Clusters Specialist
    HA + SLB + HPC
  1. Comno configurar o Twin View no Mandrake (10 ou 9.2)
    Por jrbass no fórum Servidores de Rede
    Último Post: 26-05-2004, 13:59
  2. Wireless no Mandrake 10 Official Power Pack
    Por Oráculo no fórum Redes
    Último Post: 16-05-2004, 11:48
  3. OpenWebMail no Mandrake 10 ...
    Último Post: 14-05-2004, 07:47
  4. Mandrake 10 #FINAL# 4 CDS - OFF
    Por bassman no fórum Servidores de Rede
    Último Post: 24-04-2004, 10:05
  5. Como testar o php e o apache no Mandrake 10.0??
    Último Post: 15-04-2004, 13:34
