    Padrão problema ao iniciar o guardian
    eu instalei o snort foi de boa o guadian tbm mas na hora de rodar ele apareceu a seguinte mensagem:
    [[email protected] etc]# guardian.pl -c /etc/guardian.conf
    OS shows Linux
    Warning! HostIpAddr is undefined! Attempting to guess..
    Couldn't figure out the ip address
    abaixo esta o guardian.conf
    [[email protected] etc]# cat guardian.conf
    # The machines IP address that is visable to the internet
    # If this is left undefined, then guardian will attempt to get the information
    # from ifconfig, as long as it has an interface to use. This would be useful
    # for people on ppp links, or dhcp machines, or if you are lazy
    # HostIpAddr
    # Here we define the interface which we will use to guess the IP address, and
    # block incoming offending packets. This is the only option that is required
    # for guardian to run. If the rest are undefined, guardian will use the default.
    Interface eth0
    # The last octet of the ip address, which gives us the gateway address.
    HostGatewayByte 1
    # Guardian's log file
    LogFile /var/log/guardian.log
    # Snort's alert file. This can be the snort.alert file, or a syslog file
    # There might be some snort alerts that get logged to syslog which guardian
    # might not see..
    AlertFile /var/log/snort/alert
    # The list of ip addresses to ignore
    IgnoreFile /etc/guardian.ignore
    # The time in seconds to keep a host blocked. If undefined, it defaults to
    # 99999999, which basicly disables the feature.
    TimeLimit 86400
    desde já valew ae
    []´z
    Daniel
    se a variavels "HostIpAddr" estiver comentada no guardian.conf, então o guardian irá atribuir o endereço ip a ela pelo comando ifconfig na interface de rede selecionada na variavel "Interface" ....
    Como está a saida de ifconfig eth0?
    Caso seu IP seja fixo, descomente a linha HostIpAddr e atribua o IP de eth0 a ela...
    sim meu ip eh fixo, tentei desta forma mas nao foi...
    HostIpAddr
    Interface eth0 192.168.1.254
    HostGatewayByte 1
    # might not see..
    TimeLimit 86400
    Jul 2001
    Campinas Area
    heheh
    A opcao requer que voce informe seu IP amigo:
    HostIPAddr 200.200.200.200
    affee rsrs
    valew psy
    [[email protected] bin]# guardian.pl -c /etc/guardian.conf
    OS shows Linux
    My ip address and interface are: 192.168.1.254 eth0
    Loaded 2 addresses from /etc/guardian.ignore
    Becoming a daemon..
    Jul 2001
    Campinas Area
    Disponha ;]
    Citação Postado originalmente por PiTsA
    aqui to com esse problema, mas tem um diferença, quando logo na maquina remotamente com usuario comum, depois do um su -
    ele roda o guardian.pl tranquilo, mas se eu dou su e depois rodo o guardian .pl ai da o erro, ele n consegue atribuir, apesar que a saida do ifconfig e = para su e su -
    alguem tem alguam ideia?
    Citação Postado originalmente por Brenno
    Cara é que a diferença é que o su não carrega as variveis de root, já o su - carrega, pode ser alguma coisa em relação a isso, sem ser exatamente no ifconfig.
    falows
    vlw pela dica mas isso eu já sabia, tanto é que já tentei colocas as variaveis iguais do su su -, mesmo assim num rolou. alguma besterinha que ta faltando, o problema eh saber o que é .
    mesmo assim vlw
    mesmo assim vlw
    Sim mas qual seria o problema do su -, só pra eu saber quem sabe posso ajudar.
    falows
    fiz um script simples, a onde ele chama o guaridan.pl -c config , eu acesso a maquina via ssh como usuario normal, pois root não rola, ao acessar a maquina com usuario normal. eu digito, su - e execute o script, o guardian funcionar normal. se for fazer o mesmo processo dando su , ele n roda, não consegue acha o ip da ppp0 que aqui eh velox.
    ai você me pergunta:
    mas ta funcionando?
    ta sim, o problema é quando colocando no crontab para levantar o snort+guardian, ai só levanta o snort.
    pois tenho outro script que fica tentando conectar a velox quando o mesmo cai, e quando levanta, ele executa outro script derruba o snort e guardian e levanta de novo.
    vlw
    mas ta funcionando?
    vlw
    Ta eu entendi mais ou menos, é que pelo script voce não ta conseguindo chamar o su - é isso??
    falows
    +-, é pq no crontab ele executa o script como su e suas variaveis, por isso que o guardian não ta funcionando.
    Entendi, se achar alguma coisa te dou um toque.
    falows
