    Puchini
    Padrão Configuraça d minha rede
    Olá amigos eu tenho meu server com uma orinoco, bom meu problema e o siguinte configuro minha placa com o essid do meu provedor consigo me conectar a internet mais o k eu naum to consiguindo e ficar com essa configuraçao uma vez renicializado o pc, minha configuraçao do meu /etc/network/interfaces e o siguinte.....
    auto lo eth0 eth1
    iface eth0 inet static
    address 192.168.0.1
    netmask 255.255.255.0
    network 192.168.0.0
    broadcast 192.168.0.255
    gatewat 192.168.0.1
    iface eth1 inet static
    address 172.16.1.49
    network 172.16.1.49
    broadcast 172.16.1.255
    gatewat 172.16.1.254
    minha configuraçao do essid, channel e demais /etc/pcmcia/network.opts e /etc/pcmcia/wireless.opts configurei com o netcardconfig e sao as siguintes
    case "$ADDRESS" in
    *,*,*,00:02:2D:5E:ED:EE) ESSID="Rede_Privada" ; NWID="PCX"; ;;
    esac
    case "$ADDRESS" in
    INFO="Sample private network setup"
    # Transceiver selection, for some cards -- see 'man ifport'
    IF_PORT=""
    # Use BOOTP (via /sbin/bootpc)? [y/n]
    BOOTP="n"
    # Use DHCP (via /sbin/dhcpcd, /sbin/dhclient, or /sbin/pump)? [y/n]
    DHCP="n"
    # If you need to explicitly specify a hostmane for DHCP request
    DHCP_HOSTNAME=""
    # Use PPP over Ethernet (via the pppoe package)? [y/n]
    PPPOE="n"
    # Use WHEREAMI (via whereami package)? [y/n]
    # Host's IP address, netmask, network address, broadcast address
    IPADDR="172.16.1.49"
    NETMASK="255.255.255.0"
    NETWORK="172.16.1.0"
    BROADCAST="172.16.1.255"
    # Gateway address for static routing
    GATEWAY="172.16.1.254"
    # Things to add to /etc/resolv.conf for this interface
    DOMAIN=""
    SEARCH=""
    DNS_1=""
    DNS_2=""
    DNS_3=""
    # NFS mounts, should be listed in /etc/fstab
    MOUNTS=""
    # If you need to override the interface's MTU...
    MTU=""
    # For IPX interfaces, the frame type and network number
    IPX_FRAME=""
    IPX_NETNUM=""
    #Run ipmasq? [y/n] (see the Debian ipmasq package)
    IPMASQ="n"
    # Extra stuff to do after setting up the interface
    start_fn () { return; }
    # Extra stuff to do before shutting down the interface
    stop_fn () { return; }
    # Card eject policy options
    NO_CHECK=n
    NO_FUSER=n
    esac
    Bom amigos esa e toda minha configuraçao eu consigo navegar e compartilhar a conexao mais cuando el reinicializo o PC e como si a PCMCIA eth1 nao levanta so a eth0 o sinao d todos os Pc's clientes da minha rede consigo pingar pra 172.16.1.49 e pra 192.168.0.1 mais nao pra www.google.com tenhe k accesar via SSH e façer um networking restart ahi començo a pingar do meu server pra yahoo , automaticamente todos os pc's da minha rede ficam online mais acho k debe ter alguma dica pra inicializar Automaticamente, bom amigos si vc's podem me indicar cual e meu problema o me indicar algum tuto pra solucionar este problema....Obrigaadoooo a vc'ssss Francisco.
    pdrbast
    experimente adicionar as suas regras no seu rc.local usando o comando
    vi /etc/rc.d/rc.local
    desculpe mas acho q com isso funciona!!!
    Puchini
    Padrão Configuraçao da minha rede
    Olá pdrbast, disculpa mais ya votei as regras no /etc/rc.d/rc.local
    o ke vote no arquivo /etc/rc.d/rc.local
    /etc/init./networking restart
    iso e o q eu fiz mais nao aidanta o meu problema esta cuando configuro a eth0 e acho k alguma coisa do runlevel k tenho k trocar ,mais nao sei direitamente como façelo pq si inicio sem levantra eth0 o cartao inicialia sem problemas!!!!. bommm espera possam me ajudar....Abraços
