    muganga
    pessoal...estou com um problema com um firewall que configurei para um cliente...o OUTLOOK nao funciona
    ETH0 = Placa onde chega a internet
    ETH1 = Placa da rede interna
    #!/bin/sh
    # This script will be executed *after* all the other init scripts.
    # You can put your own initialization stuff in here if you don't
    # want to do the full Sys V style init stuff.
    touch /var/lock/subsys/local
    route add default gw 172.16.2.1
    /sbin/modprobe ip_tables
    /sbin/modprobe iptables_nat
    /sbin/modprobe iptables_filter
    /sbin/modprobe ip_conntrack_ftp
    /sbin/modprobe ip_nat_ftp
    echo "1" > /proc/sys/net/ipv4/ip_forward
    #REGRA PARA LIMPEZA DAS REGRAS (FLUSH)
    iptables -F
    iptables -Z
    iptables -X
    iptables -t nat -F
    iptables -t nat -X
    iptables -t nat -Z
    #REGRA PARA BLOQUEAR(POR MAC)DETERMINADA MAQUINA DE ACESSAR INTERNET (OK)
    iptables -t nat -A PREROUTING -m mac --mac-source 00:07:95:45:66:15 -j DROP
    #Regra para fazer REDIRECIONAMENTO para a porta 8080 (PROXY)(OK)
    iptables -t nat -A PREROUTING -i eth0 -s 10.1.1.0/24 -p tcp --dport 80 -j REDIRECT --to-port 8080
    iptables -t nat -A PREROUTING -s localhost -p tcp --dport 80 -j REDIRECT --to-port 8080
    #REGRA PARA NAO PASSAR A MAQUINA COM O MAC PELO PROXY (NAO)
    iptables -t nat -A PREROUTING -m mac --mac-source 00:05:91:43:60:15 -j ACCEPT
    #Regra para fazer OUTLOOK funcionar
    iptables -A FORWARD -s 10.1.1.0/24 -p tcp --dport 110 -j ACCEPT
    iptables -A FORWARD -s 10.1.1.0/24 -p tcp --dport 25 -j ACCEPT
    NAO ESTA FUNCIONANDO A REGRA ACIMA
    #Regras para bloquear entradas netbios e outras portas (OK)
    iptables -t filter -A INPUT -p udp --dport 137 -j DROP
    iptables -t filter -A INPUT -p udp --sport 138 -j DROP
    iptables -t filter -A INPUT -p udp --dport 138 -j DROP
    iptables -t filter -A INPUT -p udp --sport 139 -j DROP
    iptables -t filter -A INPUT -p udp --dport 139 -j DROP
    iptables -t filter -A INPUT -p udp --sport 445 -j DROP
    iptables -t filter -A INPUT -p udp --dport 445 -j DROP
    iptables -t filter -A INPUT -p tcp --sport 445 -j DROP
    iptables -t filter -A INPUT -p tcp --dport 445 -j DROP
    iptables -t filter -A INPUT -p tcp --sport 1025 -j DROP
    iptables -t filter -A INPUT -p tcp --dport 1025 -j DROP
    iptables -t filter -A INPUT -p udp --sport 1025 -j DROP
    iptables -t filter -A INPUT -p udp --dport 1025 -j DROP
    #Regras para bloquear saida netbios e outras portas (OK)
    iptables -t filter -A OUTPUT -p udp --dport 137 -j DROP
    iptables -t filter -A OUTPUT -p udp --sport 138 -j DROP
    iptables -t filter -A OUTPUT -p udp --dport 138 -j DROP
    iptables -t filter -A OUTPUT -p udp --sport 139 -j DROP
    iptables -t filter -A OUTPUT -p udp --dport 139 -j DROP
    iptables -t filter -A OUTPUT -p udp --sport 445 -j DROP
    iptables -t filter -A OUTPUT -p udp --dport 445 -j DROP
    iptables -t filter -A OUTPUT -p tcp --sport 445 -j DROP
    iptables -t filter -A OUTPUT -p tcp --dport 445 -j DROP
    iptables -t filter -A OUTPUT -p tcp --sport 1025 -j DROP
    iptables -t filter -A OUTPUT -p tcp --dport 1025 -j DROP
    iptables -t filter -A OUTPUT -p udp --sport 1025 -j DROP
    iptables -t filter -A OUTPUT -p udp --dport 1025 -j DROP
    #Regra para aceitar ping da minha maquina
    iptables -A INPUT -s 10.1.1.50/32 -p icmp -j ACCEPT
    iptables -A INPUT -p icmp -j DROP
    #Regra para bloquear ping
    #iptables -A INPUT -p icmp --icmp-type echo-request -j DROP
    #echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_all
    #Regra para bloquear Back Orifice (YES)
    iptables -A INPUT -p tcp -i eth0 --dport 31337 -j DROP
    iptables -A INPUT -p udp -i eth0 --dport 31337 -j DROP
    #Regra para bloquear accesso pelas portas do X Server(interface grafica) (YES)
    iptables -A INPUT -p tcp -i eth0 --dport 5999:6003 -j DROP
    iptables -A INPUT -p udp -i eth0 --dport 5999:6003 -j DROP
    iptables -A INPUT -p tcp -i eth0 --dport 7100 -j DROP
    #Regra para limitar pacotes syn (evita flooding) (YES)
    iptables -A INPUT -p tcp --syn -m limit --limit 1/s -j ACCEPT
    #Regra para bloquear socks tunneling (YES)
    iptables -t filter -A FORWARD -s 64.83.28.77 -j DROP
    iptables -t filter -A FORWARD -d 64.83.28.77 -j DROP
    iptables -t filter -A FORWARD -d 200.221.7.2 -j DROP
    iptables -t filter -A FORWARD -d 63.219.179.196 -j DROP
    #Regra para proteger contra Spoofing (pacotes entram na rede com ip falsificado)(YES)
    iptables -A INPUT -s 10.1.1.0/24 -i eth0 -j DROP
    echo "1" > /proc/sys/net/ipv4/conf/all/rp_filter
    #Regra para proteger contra syn-floods (YES)
    iptables -A FORWARD -p tcp --syn -m limit --limit 1/s -j ACCEPT
    #Regra para proteger contra port scanners
    iptables -N SCANNER
    iptables -A SCANNER -m limit --limit 15/m -j LOG --log-level 6 --log-prefix "FIREWALL: port scanner:"
    iptables -A SCANNER -j DROP
    iptables -A INPUT -p tcp --tcp-flags ALL FIN,URG,PSH -i eth0 -j SCANNER
    iptables -A INPUT -p tcp --tcp-flags ALL NONE -i eth0 -j SCANNER
    iptables -A INPUT -p tcp --tcp-flags ALL ALL -i eth0 -j SCANNER
    iptables -A INPUT -p tcp --tcp-flags ALL FIN,SYN -i eth0 -j SCANNER
    iptables -A INPUT -p tcp --tcp-flags ALL SYN,RST,ACK,FIN,URG -i eth0 -j SCANNER
    iptables -A INPUT -p tcp --tcp-flags SYN,RST SYN,RST -i eth0 -j SCANNER
    iptables -A INPUT -p tcp --tcp-flags SYN,FIN SYN,FIN -i eth0 -j SCANNER
    #Regra para proteger contra ping da morte
    iptables -A FORWARD -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    #Regra para proteger contra pacotes danificados ou suspeitos (ataque DOS)
    iptables -A FORWARD -m unclean -j DROP
    #Regra para bloquear NFS
    iptables -A INPUT -p tcp -i eth1 --syn --dport 111 -j DROP
    #Regra para proteger contra Trojans
    iptables -N TROJAN
    iptables -A TROJAN -m limit --limit 15/m -j LOG --log-level 6 --log-prefix "FIREWALL:trojan:"
    iptables -A TROJAN -j DROP
    iptables -A INPUT -p TCP -i eth0 --dport 666 -j TROJAN
    iptables -A INPUT -p TCP -i eth0 --dport 4000 -j TROJAN
    iptables -A INPUT -p TCP -i eth0 --dport 6000 -j TROJAN
    iptables -A INPUT -p TCP -i eth0 --dport 6006 -j TROJAN
    iptables -A INPUT -p TCP -i eth0 --dport 16660 -j TROJAN
    #Regra para proteger contra worms
    iptables -A FORWARD -p tcp --dport 135 -i eth1 -j REJECT
    iptables -A FORWARD -p tcp --dport 1025 -i eth1 -j REJECT
    iptables -A FORWARD -p udp --dport 1025 -i eth1 -j REJECT
    Código :
    Código :
    iptables -A FORWARD -d 10.1.1.0/24 -p tcp --dport 110 -j ACCEPT
    iptables -A FORWARD -d 10.1.1.0/24 -p tcp --dport 25 -j ACCEPT
    nao esqueca q a volta tbm eh necessaria [/code]
    Código :
    Código :
    iptables -A FORWARD -d 10.1.1.0/24 -p tcp --sport 110 -j ACCEPT
    iptables -A FORWARD -d 10.1.1.0/24 -p tcp --sport 25 -j ACCEPT
    muganga
    valeu visitante...
    coloquei as regras e agora ta tudo normalizado...
    muganga
    visitante...ontem coloquei as regras que vc me passou
    so que hj nao esta mais funcionando....
    iptables -L
    ACCEPT tcp -- 10.1.1.0/24 anywhere tcp dptop3
    ACCEPT tcp -- 10.1.1.0/24 anywhere tcp dpt:smtp
    ACCEPT tcp -- anywhere 10.1.1.0/24 tcp dptop3
    ACCEPT tcp -- anywhere 10.1.1.0/24 tcp dpt:smtp
    mesmo assim o OUTLOOK nao funciona de jeito nenhum.
  1. Iptables + Outlook + Squid
    Por Westm no fórum Servidores de Rede
    Respostas: 9
    Último Post: 10-06-2008, 16:18
  2. Iptables + Outlook + Velox
    Por mjstudios no fórum Servidores de Rede
    Último Post: 03-06-2008, 15:47
  3. Iptables + Outlook + Squid
    Por ZEDjjs no fórum Servidores de Rede
    Respostas: 20
    Último Post: 09-12-2004, 14:54
  4. iptables + outlook
    Por Victor.derrico no fórum Servidores de Rede
    Último Post: 05-05-2004, 07:16
  5. Iptables - outlook
    Por AndrewAmorimdaSilva no fórum Servidores de Rede
    Respostas: 16
    Último Post: 09-01-2003, 12:58
