    linuxer
    Padrão DNS nao funciona
    ola td bem com vcs. estou tentando configurar o Bind (9.2) no Fedora Core2, mas nao consigo executa-lo. no lado cliente no momento em q tento pingar uma das minhas maquinas aparece a msg:
    #ping ws2
    ping: unknown host ws2.teste.com
    e quando tento executar o comando abaixo no servidor este acusa o seguinte erro:
    $rndc reload
    rndc: cannot failed: connection refused
    as minha config seguem abaixo, quem puder ajudo fico grato. um abracao
    ********Este é o meu arquivo named.conf em /etc/******
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    controls {
    inet 127.0.0.1 allow { localhost; } keys { rndckey; };
    // a caching only nameserver config
    zone "." IN {
    type hint;
    file "named.ca";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    allow-update { none; };
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    zone "teste.com" {
    type master;
    file "teste.zone";
    zone "0.168.192.in-addr.arpa" IN {
    type master;
    file "192.168.0.reverse";
    include "/etc/rndc.key";
    ///********ESTE É O ARQUIVI DE ZONA**********///
    local: /var/named/teste.zone
    $TTL 86400
    @ 1D IN SOA hifi.teste.com. root.hifi.teste.com. (
    2004103000 ; serial (d. adams)
    3H ; refresh
    15M ; retry
    1W ; expiry
    1D ) ; minimum
    ;Name servers
    1D IN NS hifi.teste.com.
    hifi 1D IN A 192.168.0.1
    localhost 1D IN A 127.0.0.1
    ws2 IN A 192.168.0.2
    ws3 IN A 192.168.0.3
    www IN CNAME hifi.teste.com.
    ///********ESTE É O ARQUIVI DE ZONA REVERSA**********///
    local: /var/named/192.168.0.reverse
    $TTL 86400
    3H ; refresh
    15M ; retry
    1W ; expiry
    1D ) ; minimum
    ;Name servers
    1D IN NS hifi.turmalna.com.
    1 IN PTR hifi.teste.com.
    2 IN PTR ws2.teste.com.
    3 IN PTR ws3.teste.com.
    Obs.:
    resolv.conf nos clientes:
    nameserver 192.168.0.1
    host.conf nos clientes:
    order bind,hosts
    multi on
    resolv.conf no servidor:
    nameserver 120.0.0.1
    configuracoes estao setadas em /etc/sysconfig/network
    HOSTNAME=ws2.teste.com, e assim respectivamente em cada arquivo.
    No Fedora Core 2 o DNS é chroot, vc deve configurar os arquivos em /var/named/chroot/var/etc
    /var/named/chroot/var/named
    Quaquer duvida posta ai! :wink:
    Super_Diaulas
    Companheiro........
    temos que ver se o bind está subindo normal.......
    quanto ao chroot....pode ser........ mas acredito que se estiver subindo normal....esse não é o problema
    quanto ao rndc .........
    tente colocar o include do rndc antes das zonas........
    e depois tem que pegar esse arquivo e copiar em um outro diretório que não me lembro.......
    mas quanto ao rndc.......vai dar por causa do rndc reload....somente isso
    vc pode matar o processo do bind e inica-lo novamente......
    Se quiser informações mais concretas posta aí........ seus arquivos de logs....
    eu dou uma pesquisa para lembrar as confs e te ajudo camarada....
    linuxer
    vou tentar seguir uma das indicacoes acima, depois me comunico com vcs, valeu galera.......
