    Educpd
    Olá galera,
    Estão aparecendo uns IP´s estranhos nos meus relatórios Exemplo:
    201.0.242.26 tentando acessar o endereço error:request-too-large
    218.17.231.96 tentando acessar o endereço mx1.mail.tw.yahoo.com:25
    200.216.14.165 tentando acessar o endereço www.google.com
    Alguem saberia me dizer a origem desses Ip´s??? Porque acontece isso?/
    Aguardo a ajuda dos amigos;....
    Edu
  2. Hehehehe, porque estão utilizando o seu proxy... =)
    Educpd
    Amigos, Segue meu squid.conf
    # --- Configuracao do Squid --- #
    http_port 8080
    icp_port 3130
    ftp_passive off
    #dns_nameservers
    #--- inicio Conf.Proxy transparente---#
    httpd_accel_host virtual
    httpd_accel_port 80
    #httpd_accel_single_host on
    httpd_accel_with_proxy on
    #--- fim---#
    #htcp_port 4827
    icp_query_timeout 2000
    maximum_icp_query_timeout 2000
    no_cache deny QUERY
    cache_mem 256 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 512 MB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 64 KB
    cache_dir ufs /var/spool/squid 300 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    mime_table /etc/squid/mime.conf
    auth_param basic program /usr/lib/squid/smb_auth -W EMPRESA -U 10.0.0.7
    auth_param basic children 5
    auth_param basic realm *** Web ***
    authenticate_ttl on 1000
    auth_param basic credentialsttl 2 hours
    acl conexoes maxconn 1
    acl controle proxy_auth REQUIRED
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80
    acl Safe_ports port 20
    acl Safe_ports port 21
    acl Safe_ports port 443 563
    acl Safe_ports port 70
    acl Safe_ports port 210
    acl Safe_ports port 1025-65535
    acl Safe_ports port 777 # multilink http
    acl CONNECT method CONNECT
    #---ACL's do Usuario---#
    acl manha time MTWHF 7:00-13:00
    acl tarde time MTWHF 14:00-18:30
    acl usuario src "/etc/squid/usuarios"
    #acl ips_bloqueados src "/etc/squid/ips_bloqueados"
    acl redeSP src 10.0.0.0/255.255.255.0
    acl redeAM src 10.0.5.0/255.255.255.0
    acl redeMG src 10.0.4.0/255.255.255.0
    acl redeLAB src 10.0.3.0/255.255.255.0
    acl ips_liberados src "/etc/squid/ips_liberados"
    acl palavra_libera url_regex -i "/etc/squid/palavra_libera"
    acl palavra_quente url_regex -i "/etc/squid/palavraquente"
    #acl controle_banda url_regex -i .exe$ .jpg$
    acl download url_regex -i .mpeg$ .mp3$ .avi$ .mpg$ .wav$ .wmv$ .iso$ .rar$
    # ---Acessos--- #
    http_access deny manager
    #http_access deny ips_bloqueados
    http_access allow ips_liberados
    http_access allow palavra_libera
    http_access deny palavra_quente
    http_access deny download
    http_access allow users
    http_access allow usuario controle
    http_access allow redeSP
    http_access allow redeMG
    http_access allow redeAM
    http_access allow redeLAB
    http_access deny all
    cache_mgr eduardo@empresa.com.br
    ie_refresh on
    Tem algo errado ????
    Edu
  4. Troca o:
    Código :
    http_port 8080
    por
    Código :
    http_port 192.168.0.1:8080
    Educpd
    Stéfano
    Qual a diferença de 8080 para 192.168.0.1:8080
    Isso impede que alguem de fora usar meu proxy ????
    Edu
  1. Problema estranho com IPs Válidos
    Por Int no fórum Mikrotik
    Último Post: 02-11-2016, 18:45
  2. Ominitik com IP estranho?
    Por Julianolinux no fórum Mikrotik
    Último Post: 04-09-2016, 06:59
  3. Relatório SARG com IPs fora do seguimento LAN
    Por aprendiz_ce no fórum Servidores de Rede
    Último Post: 16-04-2011, 10:14
  4. Sarg gerando relatorio com ip externo?
    Por Lincoln no fórum Servidores de Rede
    Último Post: 19-12-2007, 19:48
  5. impressão remota com ip redirecionado
    Por rogerio_rms no fórum Servidores de Rede
    Último Post: 24-06-2002, 18:19
