    rlucatto
    Padrão firewall teste
    boa tarde
    estou montando um firewall e gostaria de testar para saber o quanto estou segura alguem poderia me ajudar ?
    garupeiro
    heheheh passa o seu ip ae!!!
    rlucatto
    vai com calma
    garupeiro
    amigo nao esta respondendo nao!!!!!
    Acho que vc me engano ou postou o ip errado ou a maquina esta desligado!!! 8)
    rlucatto
    o ip esse mesmo
    e esta online
    (no tcp responses received -- assuming all ports filtered)
    All 1660 scanned ports on 200.207.152.27 are: filtered
    1660 portas abertas.....
    Adding open port 1481/tcp
    Adding open port 503/tcp
    Adding open port 1398/tcp
    Adding open port 346/tcp
    Adding open port 350/tcp
    Adding open port 730/tcp
    Adding open port 2007/tcp
    Adding open port 1446/tcp
    Adding open port 26/tcp
    Adding open port 209/tcp
    Adding open port 56/tcp
    Adding open port 471/tcp
    Adding open port 816/tcp
    Adding open port 1526/tcp
    Adding open port 580/tcp
    Adding open port 389/tcp
    Adding open port 384/tcp
    Adding open port 13782/tcp
    Adding open port 1546/tcp
    Adding open port 467/tcp
    Adding open port 94/tcp
    Adding open port 377/tcp
    Adding open port 1059/tcp
    Adding open port 7326/tcp
    Adding open port 46/tcp
    Adding open port 1367/tcp
    Adding open port 1409/tcp
    Adding open port 721/tcp
    Adding open port 404/tcp
    Adding open port 264/tcp
    Adding open port 2903/tcp
    Adding open port 697/tcp
    Adding open port 7070/tcp
    Adding open port 982/tcp
    Adding open port 1984/tcp
    Adding open port 1214/tcp
    Adding open port 1479/tcp
    Adding open port 632/tcp
    Adding open port 913/tcp
    Adding open port 391/tcp
    Adding open port 711/tcp
    Adding open port 9/tcp
    Adding open port 667/tcp
    Adding open port 767/tcp
    Adding open port 4144/tcp
    Adding open port 3292/tcp
    Adding open port 782/tcp
    Adding open port 775/tcp
    Adding open port 2017/tcp
    Adding open port 232/tcp
    Adding open port 322/tcp
    Adding open port 885/tcp
    Adding open port 2006/tcp
    Adding open port 2053/tcp
    Adding open port 879/tcp
    Adding open port 67/tcp
    Adding open port 32776/tcp
    Adding open port 875/tcp
    Adding open port 371/tcp
    Adding open port 738/tcp
    Adding open port 3052/tcp
    Adding open port 387/tcpAdding open port 119/tcp
    Adding open port 3/tcp
    Adding open port 497/tcp
    Adding open port 2026/tcp
    Adding open port 4559/tcp
    Adding open port 1002/tcp
    Adding open port 882/tcp
    Adding open port 2564/tcp
    Adding open port 570/tcp
    Adding open port 1670/tcp
    Adding open port 302/tcp
    Adding open port 426/tcp
    Adding open port 419/tcp
    Adding open port 339/tcp
    Adding open port 2064/tcp
    Adding open port 1524/tcp
    Adding open port 1016/tcp
    Adding open port 170/tcp
    Adding open port 871/tcp
    Adding open port 3372/tcp
    Adding open port 559/tcp
    Adding open port 33/tcp
    Adding open port 1442/tcp
    Adding open port 535/tcp
    Adding open port 105/tcp
    Adding open port 24/tcp
    Adding open port 1412/tcp
    Adding open port 205/tcp
    Adding open port 18181/tcp
    Adding open port 7003/tcp
    Adding open port 177/tcp
    isso foi oq coube no buffer do meu terminal!!!
    filtra direito issa mane!
    Sinceramente? Eu acho que você está rodando um honeypot. =)
    aii ai.... se ta "filtered" o firewall está barrando, e o portscan não sabe se a porta está realmente aberta ou não.... isto é um falso-positivo... até parece que iria ter 1600 portas aberta lá 8O
    hahahahhahahahah ow dexa eu zua cara meu!!!!! vcs estraga a brincadara
    rlucatto
    fala
    serio cara
    faleu
    rlucatto
    scaneei da porta 20 ate a 150 apenas....
    Starting nmap 3.45 ( http://www.insecure.org/nmap/ ) at 2004-11-05 14:59 BRST
    Interesting ports on 200-207-152-27.speedyterra.com.br (200.207.152.27):
    (The 126 ports scanned but not shown below are in state: filtered)
    PORT STATE SERVICE VERSION
    21/tcp open ftp Microsoft ftpd 5.0
    25/tcp open smtp Postfix smtpd
    53/tcp closed domain
    80/tcp open http Microsoft IIS webserver 5.0
    110/tcp open pop3 UW Imap pop3 server 2003.83rh
    eh mas ele ta vuneravel mesmo assim... ele nao ta filtrando as flag tcp.... consegui faze um FIN scan nele
    gmlinux
    Ai galera, cuidado que o cara pode passar um ip de terceiros...
