    max_mori
    Padrão squid não roda
    p_port 3128
    visible_hostaname ATHLON
    cache_mem 5 MB
    maximum_object_size_in_memory 128 KB
    maximum_object_size 512 MB
    minimum_object_size 0 KB
    cache_dir diskd /var/spool/squid/cache 20 16 16
    cache_mgr email [email protected]
    cache_effective_user usuarioX
    cache_effective_group squid
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_port 6588
    httpd_accel_with_proxy on
    acl micro1 src 192.168.0.254/24
    acl micros src 192.168.0.1-192.168.0.4/24
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 6588 # geo port
    http_acess allow geo
    http_acess allow laboratorio
    http_access deny !Safe_ports
    http_access allow micro1
    http_access allow laboratorio
    icp_access allow micros
    miss_access allow micros
    proxy_auth_realm MandrakeSoft Squid proxy-caching web server
    snmp_access deny all
    fpmazzi
    Onde vc declarou a acl laboratorio e a geo???
    acl micros src 192.168.0.1-192.168.0.4/24 oq vc pretende com esta acl???
    qualquer coisa entre em contacto ... pelo msn....
    abracos
    max_mori
    estes são os erros
    2004/11/23 20:10:35| parseConfigFile: line 2 unrecognized: 'visible_hostaname ATHLON'
    2004/11/23 20:10:35| aclParseIpData: WARNING: Netmask masks away part of the specified IP in '192.168.0.254/24'
    2004/11/23 20:10:35| aclParseIpData: WARNING: Netmask masks away part of the specified IP in '192.168.0.1-192.168.0.4/24'
    2004/11/23 20:10:35| parseConfigFile: line 34 unrecognized: 'http_acess allow geo'
    2004/11/23 20:10:35| parseConfigFile: line 35 unrecognized: 'http_acess allow laboratorio'
    2004/11/23 20:10:35| squid.conf line 36: http_access deny all
    2004/11/23 20:10:35| aclParseAccessLine: ACL name 'all' not found.
    2004/11/23 20:10:35| aclParseAccessLine: Access line contains no ACL's, skipping
    2004/11/23 20:10:35| squid.conf line 37: http_reply_access allow all
    2004/11/23 20:10:35| squid.conf line 38: icp_access deny all
    2004/11/23 20:10:35| squid.conf line 39: ident_lookup_access deny all
    2004/11/23 20:10:35| squid.conf line 40: reply_body_max_size 0 allow all
    2004/11/23 20:10:35| squid.conf line 42: snmp_access deny all
    FATAL: Could not determine fully qualified hostname. Please set 'visible_hostname'
    Squid Cache (Version 2.5.STABLE3): Terminated abnormally.
    CPU Usage: 0.000 seconds = 0.000 user + 0.000 sys
    Maximum Resident Size: 0 KB
    Page faults with physical i/o: 339
    Aborted
    Cara ... ta meio confu... teu conf..:>
    Da uma olhada em um artigo que criei!
    http://www.flogao.com.br/noticia.php...gao=spectrum34
    Citação Postado originalmente por max_mori
    estes são os erros
    Aborted
