    Padrão Erro no Squid
    ae galera deêm uma olhada no meu squid.conf e me digam o que esta errado ae nele
    visible_hostname servidor
    http_port 192.168.0.0:8080
    cache_mem 32 MB
    cache_swap_low 90
    cache_swap_high 95
    cache_mgr [email protected]
    cache_effective_user proxy
    maximum_object_size 16384 KB
    minimum_object_size o KB
    maximum_object_size_in_memory 20 kb
    #cache_dir ufs /var/spool/squid 1000 16 256
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    auth_param basic program /usr/lib/squid/ncsa_auth /etc/squid/squid_passwd
    auth_param basic children 5
    auth_param basic realm Digite seu Login
    acl autenticate proxy_auth REQUIRED
    #auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    acl all src 192.168.0.0/24
    acl redeinterna src 192.168.0.0/24
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    http_access allow redeinterna
    http_access allow autenticate
    #ttp_access allow manager localhost
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    coredump_dir /var/cache/squid
    grilo
    kra posta o erro q esta dando qd vc vai inicializar ele
    e o q vc pretente fazer...]
    valews
    Padrão Re: Erro no Squid
    De uma zoiada no meu artigo :> 8)
    http://www.flogao.com.br/noticia.php...gao=spectrum34
    Citação Postado originalmente por LinuxKids
    cache_mem 32 MB
    cache_swap_low 90
    cache_swap_high 95
    no_cache deny QUERY
