Boa tarde pessoal...
Seguinte, to recebendo o seguinte erro quando tento manda uma mensagem:
Wed, 17 Nov 2004 11:03:39 BRST:14718: error_condition:
X-QMailScanner-BWNet-1.24st: Unable to open pipe to
/var/qmail/bin/qmail-queue [16777215] (#4.3.0) -
Broken pipe
O debug completo pra vc's analizarem está abaixo:
Wed, 17 Nov 2004 10:59:49 BRST:13553: +++ starting
debugging for process 13553 by uid=1010
Wed, 17 Nov 2004 10:59:49 BRST:13553: setting UID to
EUID so subprocesses can access files generated by
this script
Wed, 17 Nov 2004 10:59:49 BRST:13553: program name is
qmail-scanner-queue.pl, version 1.24st
Wed, 17 Nov 2004 10:59:49 BRST:13553: incoming pipe
connection from via local process 13553
Wed, 17 Nov 2004 10:59:49 BRST:13553: w_c: mkdir
/var/spool/qmailscan/tmp/newmail110069638968013553
Wed, 17 Nov 2004 10:59:49 BRST:13553: w_c: start
dumping incoming msg into
/var/spool/qmailscan/working/tmp/newmail110069638968013553
[0.000516]
Wed, 17 Nov 2004 10:59:49 BRST:13553: w_c: rename new
msg from
to
/var/spool/qmailscan/working/new/newmail110069638968013553
[0.000462]
Wed, 17 Nov 2004 10:59:49 BRST:13553: d_m: starting
/usr/local/bin/reformime
-x/var/spool/qmailscan/tmp/newmail110069638968013553/
</var/spool/qmailscan/working/new/newmail110069638968013553
[0.000176]
Wed, 17 Nov 2004 10:59:49 BRST:13553: d_m: finished
[0.002964]
Wed, 17 Nov 2004 10:59:49 BRST:13553: d_m: unpacking
message took 0.003096 seconds
Wed, 17 Nov 2004 10:59:49 BRST:13553: unsetting
QMAILQUEUE env var
Wed, 17 Nov 2004 10:59:49 BRST:13553: g_e_h:
return-path is "", recips is "[email protected]"
from=Qmail-Scanner Test
<[email protected]>,subj=Qmail-Scanner
test (1/4): inoffensive message,
x-qmailscanner-bwnet-message-id=<[email protected]>
Wed, 17 Nov 2004 10:59:49 BRST:13553: This is a PLAIN
text message (because it's either not mime, or is
text/plain), skip virus scanners - but not SA
Wed, 17 Nov 2004 10:59:49 BRST:13553: ini_sc: start
scanning
recursively scan the directory
Wed, 17 Nov 2004 10:59:49 BRST:13553: scanloop:
starting scan of directory
"/var/spool/qmailscan/tmp/newmail110069638968013553"...
scanner=clamdscan_scanner,plain_text_msg=1
scanner=spamassassin,plain_text_msg=1
Wed, 17 Nov 2004 10:59:49 BRST:13553: SA: finished
scan of dir
in 0.054753 secs
scanner=perlscan_scanner,plain_text_msg=1
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: starting
scan of directory
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: '.cpl' =
'0' = 'CPL files not allowed per Company security
policy'
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: type is a
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: '.hta' =
'0' = 'HTA files not allowed per Company security
policy'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: '.pif' =
'0' = 'PIF files not allowed per Company security
policy'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: '.scr' =
'0' = 'SCR files not allowed per Company security
policy'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: '.vbs' =
'0' = 'VBS files not allowed per Company security
policy'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: '124:.*That
movie' = 'Virus-subject' = 'Sobig.F'
{cut a little piece to the text be small }
'88:.{100,}' = 'Virus-resent-date' = 'MIME Header
Buffer Overflow'
header!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: checking
for objects containing resent-date: .{100,}
'91:[email protected]|[email protected]|[email protected]|[email protected]|WPADJQ \
[email protected]|[email protected]|bgnd2...airesuivre.com|[email protected] \
net|[email protected]|[email protected]|[email protected]|[email protected]| \
[email protected]|[email protected]@myrealbox.com' = \
'Virus-to' = 'BadTrans Trojan exploit!' Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: \
type is a header!
for objects containing to:
[email protected]|[email protected]@yahoo.com|[email protected] \
ahoo.com|[email protected]|[email protected]|[email protected]|[email protected]| \
[email protected]|[email protected]@excite.com|OZUN \
[email protected]|[email protected]|[email protected] Wed, 17 Nov \
2004 10:59:49 BRST:13553: p_s: 'allfiles.cmd' = '0' = 'Virus W32/Sober-B'
size!
'application.pif' = '0' = 'Sobig.F'
size!
'attach.zip' = '12420' = 'Virus Bagle'
size!
'attacheddocument.zip' = '0' = 'Virus Bagle'
size!
'attachedfile.zip' = '0' = 'Virus Bagle'
size!
'dateilist.pif' = '0' = 'Virus W32/Sober-B'
size!
'daten-text.pif' = '0' = 'Virus W32/Sober-B'
size!
'details.pif' = '0' = 'Sobig.F'
size!
'document.zip' = '0' = 'Virus Bagle'
size!
'document_9446.pif' = '0' = 'Sobig.F'
size!
'document_all.pif' = '0' = 'Sobig.F'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: 'eicar.com'
= '69' = 'EICAR Test Virus'
size!
'happy99.exe' = '10000' = 'Happy99 Trojan'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: 'info.zip'
size!
'information.zip' = '12420' = 'Virus Bagle'
size!
'letter.zip' = '0' = 'Virus Bagle'
size!
'message.zip' = '0' = 'Virus Bagle'
size!
'moreinfo.zip' = '0' = 'Virus Bagle'
size!
'movie0045.pif' = '0' = 'Sobig.F'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: 'msg.zip' =
'0' = 'Virus Bagle'
size!
'msginfo.zip' = '0' = 'Virus Bagle'
size!
'myprofile.zip' = '0' = 'Virus Troj/Tofger-A'
size!
'readme.zip' = '12422' = 'Virus Bagle'
size!
'server.com' = '0' = 'Virus W32/Sober-B'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: 'text.zip'
size!
'textdocument.zip' = '0' = 'Virus Bagle'
size!
'textfile.zip' = '12416' = 'Virus Bagle'
size!
'thank_you.pif' = '0' = 'Sobig.F'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: 'wendy.zip'
= '0' = 'Virus Mimail'
size!
'wicked_scr.scr' = '0' = 'Sobig.F'
size!
'www.gwbush-new-wars.com' = '0' = 'Virus W32/Sober-B'
size!
'www.hcket-user-pcs.com' = '0' = 'Virus W32/Sober-B'
size!
'your_details.pif' = '0' = 'Sobig.F'
size!
'your_document.pif' = '0' = 'Sobig.F'
size!
'yourlist.pif' = '0' = 'Virus W32/Sober-B'
size!
'zipped_files.exe' = '120495' =
'W32/ExploreZip.worm.pak virus'
size!
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: skipping
auto-generated file 1100696389.13555-0.newmail
auto-generated file orig-newmail110069638968013553
Wed, 17 Nov 2004 10:59:49 BRST:13553: p_s: finished
scan of dir
in 0.009644 secs
finished scan of
Wed, 17 Nov 2004 10:59:49 BRST:13553: ini_sc: scanning
message took 0.064901 seconds
Wed, 17 Nov 2004 10:59:49 BRST:13553: q_r: fork off
child into /var/qmail/bin/qmail-queue...
Wed, 17 Nov 2004 10:59:49 BRST:13553: q_r: xstatus=0
Wed, 17 Nov 2004 10:59:49 BRST:13553: error_condition:
Broken pipe
Wed, 17 Nov 2004 10:59:49 BRST:13553: cleanup:
/usr/bin/rm -rf
Wed, 17 Nov 2004 10:59:49 BRST:13553: --- all
finished. Total of 0.073974 secs
X-QMailScanner-BWNet-1.24st: Unable to close pipe to
/var/qmail/bin/qmail-queue [255] (#4.3.0) - Illegal
seek
/usr/bin/rm -rf
finished. Total of 0.079091 secs
Wed, 17 Nov 2004 11:03:39 BRST:14718: +++ starting
debugging for process 14718 by uid=1010
Wed, 17 Nov 2004 11:03:39 BRST:14718: w_c: elapsed
time from start 0.000962 secs
Wed, 17 Nov 2004 11:03:39 BRST:14718: return-path='',
recips='[email protected]'
from='Qmail-Scanner Test
<[email protected]>',
subj='Qmail-Scanner test (1/4): inoffensive message',
via local process 14718
Wed, 17 Nov 2004 11:03:39 BRST:14718: This is a PLAIN
text message, skip virus scanners - but not SA
Wed, 17 Nov 2004 11:03:39 BRST:14718: SA: finished
scan in 0.054384 secs - hits=-2.8
Wed, 17 Nov 2004 11:03:39 BRST:14718: p_s: finished
scan in 0.007424 secs
Wed, 17 Nov 2004 11:03:39 BRST:14718: ini_sc: finished
scan of
"/var/spool/qmailscan/tmp/newmail110069661968014718"...
Broken pipe
Wed, 17 Nov 2004 11:03:39 BRST:14718: ------ Process
14718 finished. Total of 0.071022 secs
seek
14718 finished. Total of 0.076005 secs
Eu tentei quase de tudo, procurei no google, fiz updates mas nada!! :/
Qualquer ajuda vai ser muito bem vida..
Obrigado!!!
