    dB
    Padrão erro no iptables
    caros estou rodando o firewall e esta dando o seguinte erro:
    modprobe: Can't locate module iptables_nat
    Using /lib/modules/2.4.26/kernel/net/ipv4/netfilter/ip_conntrack_ftp.o.gz
    Using /lib/modules/2.4.26/kernel/net/ipv4/netfilter/ip_nat_ftp.o.gz
    iptables v1.2.10: --tcp-flags requires two args.
    Try `iptables -h' or 'iptables --help' for more information.
    Meu iptables ta assim:
    Código :
    #!/bin/bash
    modprobe iptables_nat
    insmod ip_conntrack_ftp
    insmod ip_nat_ftp
    # Limpa tabela
    #iptables -F
    # Fecha tudo
    iptables -P INPUT DROP
    #iptables -P OUTPUT DROP
    iptables -P FORWARD DROP
    # Proteção contra ping suspeito
    iptables -A FORWARD -m unclean -j DROP
    # Contra ping
    iptables -A FORWARD -p icmp --icmp-type echo-request -j DROP
    # Contra ping of death
    iptables -A FORWARD -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    # Contra syn-floods
    iptables -A FORWARD -p tcp -m limit --limit 1/s -j ACCEPT
    # Contra port scanners
    iptables -A FORWARD -p tcp --tcp-flags SYN,ACK,FIN,RST -m limit --limit 1/s -j ACCEPT
    # Mascaramento
    iptables -t nat -A POSTROUTING -o eth+ -j MASQUERADE
    # Liberando portas
    iptables -A FORWARD -p tcp --dport 80 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 25 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 110 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 22 -j ACCEPT
    tem o modulo de NAT no kernel?
    karfax
    modprobe iptable_nat
    O seu está iptables_nat :cry:
    Sds,
