    Padrão Squid
    Pessoal, este é meu squid:
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_dir ufs /var/cache/squid 100 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    pid_filename /var/run/squid.pid
    #pid_filename /var/cache/squid.pid
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80
    acl Safe_ports port 21
    acl Safe_ports port 443 563
    acl Safe_ports port 70
    acl Safe_ports port 210
    acl Safe_ports port 1025-65535
    acl Safe_ports port 280 488 591 777
    acl CONNECT method CONNECT
    acl diretoria_usr proxy_auth duarte prante fabiane claudia roberto
    acl vendas_usr proxy_auth rosimeri
    acl compras_usr proxy_auth cleoni
    acl financeiro_usr proxy_auth andreia
    acl info_usr proxy_auth jurandir flaviok
    acl diretoria_ip src 192.168.100.51-192.168.100.65
    acl vendas_ip src 192.168.100.111-192.168.100.130
    acl compras_ip src 192.168.100.86-192.168.100.95
    acl financeiro_ip src 192.168.100.66-192.168.100.70
    acl info_ip src 192.168.100.152-192.168.100.200
    acl avast_antivirus proxy_auth REQUIRED
    acl metalpan src 192.168.100.0/255.255.255.0
    acl autenticar proxy_auth REQUIRED
    acl exellon proxy_auth jurandir flaviok
    acl exellon_url url_regex exellon.mksnet.com.br
    acl mp3 url_regex -i .*\.mp3$
    acl zip url_regex -i .*\.zip$
    acl exe url_regex -i .*\.exe$
    acl wma url_regex -i .*\.wma$
    acl wmv url_regex -i .*\.wmv$
    acl rar url_regex -i .*\.rar$
    acl blockedsites url_regex -i "/etc/squid/bloqueados/block.txt"
    acl unblockedsites url_regex -i "/etc/squid/bloqueados/unblock.txt"
    acl Avast url_regex 195.70.130.34
    http_access deny manager
    http_access deny !Safe_ports
    #http_access allow info_ip info_usr
    #http_access allow diretoria_ip diretoria_usr
    #http_access allow exellon exellon_url
    #http_access allow Avast avast_antivirus
    #http_access allow unblockedsites !blockedsites
    #http_access allow financeiro_ip financeiro_usr !mp3 !zip !exe !wma !wmv !rar !blockedsites
    #http_access allow compras_ip compras_usr !mp3 !zip !exe !wma !wmv !rar !blockedsites
    #http_access allow vendas_ip vendas_usr !mp3 !zip !exe !wma !wmv !rar !blockedsites
    http_access allow metalpan autenticar
    http_access deny all
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    cache_mem 8 MB
    authenticate_program /usr/lib/squid/smb_auth -W METALPAN -U 192.168.100.254
    proxy_auth_realm Servidor Proxy Squid - Digite sua Senha
    cache_mgr [email protected]
    bom, estou com o seguinte problema, na hora de acessar a net, ele naum está pedindo autenticação e se dou o comando service squid stop, me da a seguinte msg: Interrompendo squid squid: ERROR: No running copy, e naum está mais criando o arquivo squid.pid.
    achei algo na net q menciona fazer o seguinte:
    px ax | grep squid, para ver os processos; no meu caso
    17147 ? S 0:00 /usr/bin/squid
    17149 ? S 0:00 (squid)
    echo 17149 > /var/run/squid.pid
    kill –HUP 17149: me retorna a msg: bash: kill: (17149) – No such pid
    e por ultimo squid –k reconfigure, o qual volta a msg de squid: ERROR: No running copy
    a permissão na pasta /var é drwxr-xr-x 32 root root 4096 Nov 12 21:24 var
    da pasta /var/run é drwxr-xr-x 13 root root 4096 Nov 23 06:42 run
    alguém sabe oq pode ser?????
    karfax
    Padrão Squid
    Tô lendo suas mensagens também na lista squid-br...
    Tenho alguns servidores autenticando squid contra um AD Win2kServer.
    Funciona sem nenhum problema, mas minha configuração parece estar muito diferente da sua.
    Sds,
    Padrão Re: Squid
    Da uma olhada no meu artigo:
    http://www.flogao.com.br/noticia.php...gao=spectrum34
    Citação Postado originalmente por Visitante
    http_port 3128
    no_cache deny QUERY
    httpd_accel_port 80
    cache_mem 8 MB
