    rfdasilva1
    Padrão DNS no FEDORA
    Pessoal, olhem erro q ocorre quando tento subir DNS...
    alguém me pode me dar uma luz...
    obrigado..
    Nov 25 09:46:46 radio02 named: desligar named failed
    Nov 25 11:47:00 radio02 named[2455]: starting BIND 9.2.3 -u named -t /var/named/chroot
    Nov 25 11:47:00 radio02 named[2455]: using 1 CPU
    Nov 25 11:47:00 radio02 named[2455]: loading configuration from '/etc/named.conf'
    Nov 25 11:47:00 radio02 named[2455]: listening on IPv4 interface lo, 127.0.0.1#53
    Nov 25 11:47:00 radio02 named[2455]: listening on IPv4 interface eth0, 192.168.1.1#53
    Nov 25 11:47:00 radio02 named[2455]: couldn't add command channel 127.0.0.1#953: not found
    Nov 25 11:47:00 radio02 named[2455]: couldn't add command channel ::1#953: not found
    Nov 25 11:47:00 radio02 named[2455]: running
    Nov 25 09:47:00 radio02 named: início de named succeeded
    karfax
    named.conf, please.
    Sds,
    Coloca seu named ai para podermos analizar...
    Agradeço....consegui resolver o problema, desistalando bind-chroor...não sei se foi a melhor opção....+ logo após desistalar....ta funcionando normal..
    agradeço..
