Instalei o vmware no kurumin mas ele depois pede para reconfiurar o vmware-config.pl :
vmware workstation is installed , but it was not been (correctley) configured for your running kernel. To reconfigure it, your sustem administrator must find and run "vmware-config-pl"
Reconfigurando depois e :
Your kernel was built with "gcc" version "2.95.4", while you are trying to use
"/usr/bin/gcc" version "3.3.4". This configuration is not supported and VMware
Workstation cannot work in such configuration. Please either recompile your
kernel with "/usr/bin/gcc" version "3.3.4", or restart ./vmware-config.pl with
CC environment variable pointing to the "gcc" version "2.95.4".
Que posso fazer?
Citação
