    serhumano
    Padrão Compilar MySQL
    Eu coloquei na seção de banco de dados.. mas como não uma dúvida do banco de dados em si.. estou transferindo pra cá..
    valeu
    fui compilar meu MySQL.. vejam o q deu..
    [email protected]:/opt/mysql-standard-4.1.7-pc-linux-i686# ./configure --prefix=/opt/mysql-standard-4.1.7-pc-linux-i686
    NOTE: This is a MySQL binary distribution. It's ready to run, you don't
    need to configure it!
    To help you a bit, I am now going to create the needed MySQL databases
    and start the MySQL server for you. If you run into any trouble, please
    consult the MySQL manual, that you can find in the Docs directory.
    Installing all prepared tables
    041207 12:45:35 [Warning] Asked for 196608 thread stack, but got 126976
    Fill help tables
    To start mysqld at boot time you have to copy support-files/mysql.server
    to the right place for your system
    PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
    To do so, start the server, then issue the following commands:
    ./bin/mysqladmin -u root password 'new-password'
    ./bin/mysqladmin -u root -h cable password 'new-password'
    See the manual for more instructions.
    You can start the MySQL daemon with:
    cd . ; ./bin/mysqld_safe &
    You can test the MySQL daemon with the benchmarks in the 'sql-bench' directory:
    cd sql-bench ; perl run-all-tests
    Please report any problems with the ./bin/mysqlbug script!
    The latest information about MySQL is available on the web at
    http://www.mysql.com
    Support MySQL by buying support/licenses at https://order.mysql.com
    Starting the mysqld server. You can test that it is up and running
    with the command:
    ./bin/mysqladmin version
    [email protected]:/opt/mysql-standard-4.1.7-pc-linux-i686# Starting mysqld daemon with databases from /opt/mysql-standard-4.1.7-pc-linux-i686/data
    STOPPING server from pid file /opt/mysql-standard-4.1.7-pc-linux-i686/data/cable.pid
    041207 12:45:35 mysqld ended
    e depois disso ae.. ficou parado.. num deu pra fazer nada.. aí tive q fexar o shell...
    aí como vou compilar? valeu...
    thorium
    cara, vc num precisa compilar, ele jah ta compilado... eh soh descompactar ele e rodar...
    dah uma lida na mensagem de erro...
    serhumano
    vishh, é mess eheheh, foi mal.. eu só li o fim... aí.. q vergonha ops:
