    guardian_metal
    [root@lasertools-serv lsts]# /sbin/route del default
    [root@lasertools-serv lsts]# /sbin/route add default eth1
    [root@lasertools-serv lsts]# /sbin/route add default gw 192.168.172.1
    [root@lasertools-serv lsts]# /etc/init.d/network restart
    Shutting down interface eth0: [ OK ]
    Shutting down interface eth1: [ OK ]
    Shutting down loopback interface: [ OK ]
    Disabling IPv4 packet forwarding: [ OK ]
    Setting network parameters: [ OK ]
    Bringing up loopback interface: [ OK ]
    Bringing up interface eth0: [ OK ]
    Bringing up interface eth1: [ OK ]
    Kernel IP routing table
    Destination Gateway Genmask Flags Metric Ref Use Iface
    192.168.172.0 * 255.255.255.0 U 0 0 0 eth0
    192.168.172.0 * 255.255.255.0 U 0 0 0 eth1
    169.254.0.0 * 255.255.0.0 U 0 0 0 eth1
    default 192.168.172.1 0.0.0.0 UG 0 0 0 eth0
    Pelo o que me parece é que ele usa o endereço 192.168.172.1 como gateway na eth0 mas eu adicionei o gateway 192.168.172.1 na eth1.
    O que há de errado?
    Agora vejam isso:
    [root@lasertools-serv network-scripts]# cat ifcfg-eth0
    BOOTPROTO=none
    PEERDNS=no
    IPV6INIT=no
    TYPE=Ethernet
    HWADDR=00:07:E9:19:EB:AA
    DEVICE=eth0
    MTU=""
    NETMASK=255.255.255.0
    BROADCAST=192.168.172.255
    IPADDR=192.168.172.4
    NETWORK=192.168.172.0
    USERCTL=no
    ONBOOT=yes
    You have new mail in /var/spool/mail/henrique
    [root@lasertools-serv network-scripts]# cat ifcfg-eth1
    GATEWAY=192.168.172.1
    BOOTPROTO=none
    PEERDNS=no
    HWADDR=00:0BB:8E:98:9B
    TYPE=Ethernet
    IPV6INIT=no
    DEVICE=eth1
    MTU=""
    IPADDR=192.168.172.2
    ONBOOT=yes
    USERCTL=no
    O gateway esta na interface eth1 mas o comando route me mostra na eth0. O que faço agora?
    Minhas linhas de nat.
    iptables=/sbin/iptables
    IF_EXTERNA=eth1
    IF_INTERNA=eth0
    #Habilita (NAT)
    $iptables -t nat -A POSTROUTING -o $IF_EXTERNA -j MASQUERADE
    #Redireciona Todas as portas para a 8080 (http) (Squid)
    $iptables -t nat -A PREROUTING -s 192.168.172.0/24 -p tcp --dport 80 -j REDIRECT --to 8080
    $iptables -t nat -A PREROUTING -s 192.168.172.0/24 -p udp --dport 80 -j REDIRECT --to 8080
    $iptables -t nat -A PREROUTING -s localhost -p tcp --dport 80 -j REDIRECT --to 8080
    $iptables -t nat -A PREROUTING -s localhost -p udp --dport 80 -j REDIRECT --to 8080
    abc
    Desabilita as interfaces, e levanta tudo na mao,:
    ifconfig e route
    E veja o que acontece
    Se der certo coloque no rc.local
    estanisgeyer
    Você fez uma pequena confusão. Seria assim:
    # route del default
    # route add default gw 192.168.172 eth1
    # service network restart
    Att.
    guardian_metal
    Reiniciei cada uma das interfaces na mão e continua igual e:
    [root@lasertools-serv lsts]# /sbin/route add default gw 192.168.172.1 eth1
    guardian_metal
    Pra quem acha maluko, veja só:
    1. Configurando o Gateway padrão e reiniciando a rede:
    Obs: Mesmo configurando o gateway na eth1, ele só funciona na eth0 quando reinicio a rede.
    2. Configurando o Gateway padrão e não reiniciando a rede:
    default 192.168.172.1 0.0.0.0 UG 0 0 0 eth1
    Obs: Mesmo configurando o gateway na eth1, ele só funciona na eth1 se o serviço rede não for reiniciado.
    Solução: Colocar o seguinte em rc.local;
    E pronto. Loko, né?
  1. Problemas nas rotas Linux <-> PPPoE Mikrotik
    Por tianguapontocom no fórum Servidores de Rede
    Respostas: 8
    Último Post: 25-03-2011, 14:57
  2. Problema na rota ..eu acho....
    Por Duca no fórum Servidores de Rede
    Último Post: 13-08-2005, 21:20
  3. Problemas na impressao pela rede
    Por sartori no fórum Servidores de Rede
    Último Post: 23-05-2005, 12:12
  4. Problema na hora de configurar o mouse SOCORRO- URGENTE
    Por Bruno Antelo no fórum Sistemas Operacionais
    Respostas: 8
    Último Post: 02-12-2004, 01:47
  5. Rede ponto a ponto ad-hoc wireless problema na rota de retor
    Por denilson no fórum Servidores de Rede
    Último Post: 24-09-2003, 14:32
