    Padrão Erro no apt-get
    pessoal ao executar o apt-get e tentar instalar algum arquivou ou atualizar so sistema estou tento a seguinte menssagem de erro:
    Checking GPG signatures...
    Committing changes...
    Preparing... ########################################### [100%]
    1:kernel-default-nongpl ########################################### [ 14%]
    error: unpacking of archive failed: cpio: Bad magic
    2:kernel-default ########################################### [ 29%]
    3:kernel-source ########################################### [ 43%]
    4:kernel-um ########################################### [ 57%]
    5:ncpfs ########################################### [ 71%]
    6:kernel-docs ########################################### [ 86%]
    7:km_wlan ########################################### [100%]
    Alguem sabe o que pode ser??
    Falows
    cara... apareci muitu cpio nessa mensagem...
    ja deu uma olhada pa v si u cpio ta instaladu!!?
    falo!!
    Ta instalado sim, eu ja tentei um apt-get reinstall cpio e apt-get install cpio e no primeiro caso diz que nao pode ser reinstalado e no segundo diz que ja ta na ultima versao. e se tento dar um apt-get delete cpio ele diz que tb tem de remover o kernel, ae nao sei o que faço.
    falows
    bem.. nu casu... u q tu poderia faze é...
    rpm -ql | grep -e cpio
    rpm -e cpio
    mas eu naum usu u CL... entaum naum sei comu funfa direitu u isquema.. mas achu q assim tu tira u cpio sem brema nenhum!!!
    falo!!!!
    Na real nao eh CL eh SuSE com apt-get
    falows
