Olá colegas, Sou iniciante e tenho problemas ao inicializar o Jboss, (red hat 7.2). Agradeço muito se alguém puder dar uma mãozinha
Seguem alguns dados:
[root@JBServer bin]# echo $PATH
/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/usr/java/j2sdk1.4.2_06/bin:/usr/local/jboss/bin:.:/root/bin
[root@JBServer bin]# echo $JAVA_HOME
[root@JBServer bin]# echo $CLASSPATH
.:/usr/java/j2sdk1.4.2_06/jre/lib/ext/pgjdbc2.jar:/usr/java/j2sdk1.4.2_06/lib/tools.jar:/usr/java/j2sdk1.4.2_06/lib:/usr/java/j2sdk1.4.2_06/lib:
[root@JBServer bin]# sh run.sh
Estado de meu console durante a inicialização:
JBoss Bootstrap Environment
JBOSS_HOME: /usr/local/jboss
JAVA: /usr/java/j2sdk1.4.2_06/bin/java
JAVA_OPTS: -server -Xms128m -Xmx128m -Dprogram.name=run.sh
CLASSPATH: /usr/local/jboss/bin/run.jar:/usr/java/j2sdk1.4.2_06/lib/tools.jar
Failed to boot JBoss:
java.lang.ClassNotFoundException: org.jboss.system.server.ServerImpl
at java.net.URLClassLoader$1.run(URLClassLoader.java:199)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at org.jboss.system.server.ServerLoader.createServer(ServerLoader.java:271)
at org.jboss.system.server.ServerLoader.load(ServerLoader.java:253)
at org.jboss.Main.boot(Main.java:143)
at org.jboss.Main$1.run(Main.java:405)
at java.lang.Thread.run(Thread.java:534)
Meu profile:
[root@JBServer bin]# cat /etc/profile
# /etc/profile
# System wide environment and startup programs, for login setup
# Functions and aliases go in /etc/bashrc
# Path manipulation
if [ `id -u` = 0 ] && ! echo $PATH | /bin/grep -q "/sbin" ; then
PATH=/sbin:$PATH
fi
if [ `id -u` = 0 ] && ! echo $PATH | /bin/grep -q "/usr/sbin" ; then
PATH=/usr/sbin:$PATH
fi
if [ `id -u` = 0 ] && ! echo $PATH | /bin/grep -q "/usr/local/sbin" ; then
PATH=/usr/local/sbin:$PATH
fi
if ! echo $PATH | /bin/grep -q "/usr/X11R6/bin" ; then
PATH="$PATH:/usr/X11R6/bin"
fi
# No core files by default
ulimit -S -c 0 > /dev/null 2>&1
USER=`id -un`
LOGNAME=$USER
MAIL="/var/spool/mail/$USER"
HOSTNAME=`/bin/hostname`
HISTSIZE=1000
if [ -z "$INPUTRC" -a ! -f "$HOME/.inputrc" ]; then
INPUTRC=/etc/inputrc
fi
JBOSS_HOME=/usr/local/jboss
JAVA_HOME=/usr/java/j2sdk1.4.2_06
JDK_HOME=$JAVA_HOME
CLASSPATH=.:$JAVA_HOME/jre/lib/ext/pgjdbc2.jar:$JAVA_HOME/lib/tools.jar:$JAVA_HOME/lib:$JDK_HOME/lib:
PATH=$PATH:$JAVA_HOME/bin:$JBOSS_HOME/bin:.
LANG=en_US.iso885915
export PATH USER LOGNAME MAIL HOSTNAME HISTSIZE INPUTRC JAVA_HOME JBOSS_HOME LANG CLASSPATH
for i in /etc/profile.d/*.sh ; do
if [ -r $i ]; then
. $i
fi
done
unset i
Citação
