    Padrão Fedora Core 3 Update: exim-4.43-1.FC3.1
    Fedora Update Notification
    FEDORA-2005-001
    2005-01-06
    Product : Fedora Core 3
    Version : 4.43
    Release : 1.FC3.1
    Summary : The exim mail transfer agent
    Description :
    Exim is a mail transport agent (MTA) developed at the University of
    Cambridge for use on Unix systems connected to the Internet. In style
    it is similar to Smail 3, but its facilities are more extensive, and
    in particular it has options for verifying incoming sender and
    recipient addresses, for refusing mail from specified hosts, networks,
    or senders, and for controlling mail relaying. Exim is in production
    use at quite a few sites, some of which move hundreds of thousands of
    messages per day.
    Exiscan is compiled in to allow inbuilt scanning capability. See
    http://duncanthrax.net/exiscan-acl/
    Update Information:
    This erratum fixes two relatively minor security issues which were discovered
    in Exim in the last few weeks. The Common Vulnerabilities and Exposures
    project (cve.mitre.org) has assigned the names CAN-2005-0021 and CAN-2005-0022
    to these, respectively.
    1. The function host_aton() can overflow a buffer if it is presented with an
    illegal IPv6 address that has more than 8 components.
    2. The second report described a buffer overflow in the function
    spa_base64_to_bits(), which is part of the code for SPA authentication. This
    code originated in the Samba project. The overflow can be exploited only if
    you are using SPA authentication.
    * Tue Jan 04 2005 David Woodhouse <[email protected]> 4.43-1.FC3.1
    - Fix buffer overflows (CAN-2005-0021, CAN-2005-0022)
    - Demonstrate SASL auth configuration in default config file
    - Enable TLS and provide certificate if necessary
    - Don't reject all GB2312 charset mail by default
    This update can be downloaded from:
    http://download.fedora.redhat.com/pu...ore/updates/3/
    f4cafadca104a85ff5f31cbf5ca4c4f1 SRPMS/exim-4.43-1.FC3.1.src.rpm
    3412f5b4cf40ad504dbaf2b7e2fffa62 x86_64/exim-4.43-1.FC3.1.x86_64.rpm
    1446c41e65cfd6f15ae60b969ab3d20c x86_64/exim-mon-4.43-1.FC3.1.x86_64.rpm
    e71be8446d9e4d250ca40a41c2d7b49a x86_64/exim-doc-4.43-1.FC3.1.x86_64.rpm
    1d515c5be494e657333549f72f4621e2 x86_64/exim-sa-4.43-1.FC3.1.x86_64.rpm
    bcd320d0c2f88911a3ccc02b95cb2843 x86_64/debug/exim-debuginfo-4.43-1.FC3.1.x86_64.rpm
    7c2205113fe3285a76b797748845548b i386/exim-4.43-1.FC3.1.i386.rpm
    8227e5701319639057b951bc45bbecf8 i386/exim-mon-4.43-1.FC3.1.i386.rpm
    3b7e2741f4208757e92ab2d228b1fe8a i386/exim-doc-4.43-1.FC3.1.i386.rpm
    4e5cbfea028184d6710443a3c0e79c29 i386/exim-sa-4.43-1.FC3.1.i386.rpm
    9c2c6e5d633104ca71bf80b062e9f0a2 i386/debug/exim-debuginfo-4.43-1.FC3.1.i386.rpm
    This update can also be installed with the Update Agent; you can
    launch the Update Agent with the 'up2date' command.
    Updates for the PowerPC architecture are also available from the yum
    repository at the following address:
    ftp://ftp.uk.linux.org/pub/people/dw...3-updates-ppc/
    fedora-announce-list mailing list
    [email protected]
    http://www.redhat.com/mailman/listin...-announce-list
    oq vc quer saber??
    Estou apenas notificando.
