    Padrão Erro Postfix
    Bom galera! tenho rh9 postfix + ipop3 rodando!
    O postfix funfa blz, mas nao recebo nada, ele conecta ao pop e diz q nao tem nenhuma mensagem, e se eu mandar um mail para a conta ele me retorna:
    This is the Postfix program at host ciberia.viavale.com.br.
    I'm sorry to have to inform you that your message could not be
    be delivered to one or more recipients. It's attached below.
    For further assistance, please send mail to <postmaster>
    If you do so, please include this problem report. You can
    delete your own text from the attached returned message.
    The Postfix program
    <[email protected]>: host mail.meuhost.com.br[XXX.XXX.XXX.XX]
    said: 554 <[email protected]>: Recipient address rejected: Relay
    access denied (in reply to RCPT TO command)
    Final-Recipient: rfc822; [email protected]
    Action: failed
    Status: 5.0.0
    Diagnostic-Code: X-Postfix; host mail.meuhost.com.br
    [XXX.XXX.XXX.XX] said:
    554 <[email protected]>: Recipient address rejected: Relay access
    Como se tivesse em relay do servidor que estou mandando! ??
    Padrão Erro Postfix
    Você está com o relay fechado, e o usuário que está tentando enviar email para fora do domínio, não está se autenticando.
    Se precisar de ajuda para resolver, poste novamente.
    Padrão Erro Postfix
    Não é o provedor que mando, TENTATIVA PELO YAHOO
    Hi. This is the qmail-send program at yahoo.com.
    I'm afraid I wasn't able to deliver your message to the following
    addresses.
    This is a permanent error; I've given up. Sorry it didn't work out.
    XXX.XXX.XXX.XX does not like recipient.
    Remote host said: 554 <[email protected]>: Recipient address
    rejected: Relay access denied
    Giving up on XXX.XXX.XXX.XX.
    --- Below this line is a copy of the message.
    Return-Path: <[email protected]>
    Received: (qmail 80234 invoked by uid 60001); 10 Jan 2005 17:33:14
    -0000
    Message-ID: <[email protected]>
    Received: from [200.102.80.18] by web51510.mail.yahoo.com via HTTP;
    Mon, 10 Jan 2005 14:33:14 ART
    Date: Mon, 10 Jan 2005 14:33:14 -0300 (ART)
    Subject: tejyfk
    To: [email protected]
    MIME-Version: 1.0
    Content-Type: multipart/alternative;
    boundary="0-1173499051-1105378394=:78512"
    Content-Transfer-Encoding: 8bit
    --0-1173499051-1105378394=:78512
    Content-Type: text/plain; charset=iso-8859-1
    Padrão Erro Postfix
    Pode nos mostrar o conteúdo das diretivas 'smtpd_sender_restrictions' e 'address_verify_map' do arquivo de configuração do postifx (/etc/postfix/main.cf) ?
    Dê uma lida em http://www.postfix.org/ADDRESS_VERIFICATION_README.html
    Padrão Erro Postfix
    pela mensagem de erro seu problema esta no relay. Verifica o mesmo em seu main.cf, se esta algo parecido com:
    mesmomydestination = 127.0.0.1, $transport_maps, $config_directory/relay
    onde /etc/postfix/relay tem que estar os sues domínios, tipo:
    dominio1.com.br
    dominio2.com.br
    restart o postfix, que vai dar certo com certeza...
    Padrão Erro Postfix
    Citação Postado originalmente por bauer
    dominio1.com.br
    dominio2.com.br
    desculpa, eta Crtl + C - Crtl + V, o correto é:
    t+
    Padrão Erro Postfix
    Mudei e nada :?
    Meu main.cf
    #soft_bounce = no
    # LOCAL PATHNAME INFORMATION
    # The queue_directory specifies the location of the Postfix queue.
    # This is also the root directory of Postfix daemons that run chrooted.
    # See the files in examples/chroot-setup for setting up Postfix chroot
    # environments on different UNIX systems.
    queue_directory = /var/spool/postfix
    # The command_directory parameter specifies the location of all
    # postXXX commands. The default value is $program_directory.
    command_directory = /usr/sbin
    # The daemon_directory parameter specifies the location of all Postfix
    # daemon programs (i.e. programs listed in the master.cf file). The
    # default value is $program_directory. This directory must be owned
    # by root.
    daemon_directory = /usr/libexec/postfix
    # QUEUE AND PROCESS OWNERSHIP
    # The mail_owner parameter specifies the owner of the Postfix queue
    # and of most Postfix daemon processes. Specify the name of a user
    # account THAT DOES NOT SHARE ITS USER OR GROUP ID WITH OTHER ACCOUNTS
    # AND THAT OWNS NO OTHER FILES OR PROCESSES ON THE SYSTEM. In
    # particular, don't specify nobody or daemon. PLEASE USE A DEDICATED
    # USER.
    mail_owner = postfix
    # The default_privs parameter specifies the default rights used by
    # the local delivery agent for delivery to external file or command.
    # These rights are used in the absence of a recipient user context.
    # DO NOT SPECIFY A PRIVILEGED USER OR THE POSTFIX OWNER.
    #default_privs = nobody
    # INTERNET HOST AND DOMAIN NAMES
    # The myhostname parameter specifies the internet hostname of this
    # mail system. The default is to use the fully-qualified domain name
    # from gethostname(). $myhostname is used as a default value for many
    # other configuration parameters.
    myhostname = mail.meuhost.com.br
    #myhostname = virtual.domain.tld
    # The mydomain parameter specifies the local internet domain name.
    # The default is to use $myhostname minus the first component.
    # $mydomain is used as a default value for many other configuration
    # parameters.
    mydomain = meuhost.com.br
    # SENDING MAIL
    # The myorigin parameter specifies the domain that locally-posted
    # mail appears to come from. The default is to append $myhostname,
    # which is fine for small sites. If you run a domain with multiple
    # machines, you should (1) change this to $mydomain and (2) set up
    # a domain-wide alias database that aliases each user to
    # [email protected]host.
    myorigin = meuhost.com.br
    #myorigin = $mydomain
    # RECEIVING MAIL
    # The inet_interfaces parameter specifies the network interface
    # addresses that this mail system receives mail on. By default,
    # the software claims all active interfaces on the machine. The
    # parameter also controls delivery of mail to [email protected][ip.address].
    inet_interfaces = all
    #inet_interfaces = $myhostname
    #inet_interfaces = $myhostname, localhost
    # The mydestination parameter specifies the list of domains that this
    # machine considers itself the final destination for. That includes
    # Sendmail-style virtual domains hosted on this machine.
    # Do not include Postfix-style virtual domains - those domains are
    # specified elsewhere (see sample-virtual.cf, and sample-transport.cf).
    # The default is $myhostname + localhost.$mydomain. On a mail domain
    # gateway, you should also include $mydomain. Do not specify the
    # names of domains that this machine is backup MX host for. Specify
    # those names via the relay_domains or permit_mx_backup settings for
    # the SMTP server (see sample-smtpd.cf).
    # The local machine is always the final destination for mail addressed
    # to [email protected][the.net.work.address] of an interface that the mail system
    # receives mail on (see the inet_interfaces parameter).
    # Specify a list of host or domain names, /file/name or type:table
    # patterns, separated by commas and/or whitespace. A /file/name
    # pattern is replaced by its contents; a type:table is matched when
    # a name matches a lookup key. Continue long lines by starting the
    # next line with whitespace.
    #mydestination = $myhostname, localhost.$mydomain $mydomain
    #mydestination = $myhostname, localhost.$mydomain, $mydomain,
    # mail.$mydomain, www.$mydomain, ftp.$mydomain
    #mydestination = /etc/postfix/mydestinations
    # TRUST AND RELAY CONTROL
    # The mynetworks parameter specifies the list of "trusted" SMTP
    # clients that have more privileges than "strangers".
    # In particular, "trusted" SMTP clients are allowed to relay mail
    # through Postfix. See the smtpd_recipient_restrictions parameter
    # in file sample-smtpd.cf.
    # You can specify the list of "trusted" network addresses by hand
    # or you can let Postfix do it for you (which is the default).
    # By default (mynetworks_style = subnet), Postfix "trusts" SMTP
    # clients in the same IP subnetworks as the local machine.
    # On Linux, this does works correctly only with interfaces specified
    # with the "ifconfig" command.
    # Specify "mynetworks_style = class" when Postfix should "trust" SMTP
    # clients in the same IP class A/B/C networks as the local machine.
    # Don't do this with a dialup site - it would cause Postfix to "trust"
    # your entire provider's network. Instead, specify an explicit
    # mynetworks list by hand, as described below.
    # Specify "mynetworks_style = host" when Postfix should "trust"
    # only the local machine.
    #mynetworks_style = class
    #mynetworks_style = subnet
    #mynetworks_style = host
    # Alternatively, you can specify the mynetworks list by hand, in
    # which case Postfix ignores the mynetworks_style setting.
    # Specify an explicit list of network/netmask patterns, where the
    # mask specifies the number of bits in the network part of a host
    # address.
    # You can also specify the absolute pathname of a pattern file instead
    # of listing the patterns here. Specify type:table for table-based lookups
    # (the value on the table right-hand side is not used).
    mynetworks = 192.168.1.1/24, 127.0.0.0/8
    #mynetworks = /etc/postfix/mynetworks
    #mynetworks = hash:/etc/postfix/network_table
    # The relay_domains parameter restricts what clients this mail system
    # will relay mail from, or what destinations this system will relay
    # mail to. See the smtpd_recipient_restrictions restriction in the
    # file sample-smtpd.cf for detailed information.
    # By default, Postfix relays mail
    # - from "trusted" clients whose IP address matches $mynetworks,
    # - from "trusted" clients matching $relay_domains or subdomains thereof,
    # - from untrusted clients to destinations that match $relay_domains
    # or subdomains thereof, except addresses with sender-specified routing.
    # The default relay_domains value is $mydestination.
    # In addition to the above, the Postfix SMTP server by default accepts mail
    # that Postfix is final destination for:
    # - destinations that match $inet_interfaces,
    # - destinations that match $mydestination
    # - destinations that match $virtual_maps.
    # These destinations do not need to be listed in $relay_domains.
    # Specify a list of hosts or domains, /file/name patterns or type:name
    # lookup tables, separated by commas and/or whitespace. Continue
    # long lines by starting the next line with whitespace. A file name
    # is replaced by its contents; a type:name table is matched when a
    # (parent) domain appears as lookup key.
    # NOTE: Postfix will not automatically forward mail for domains that
    # list this system as their primary or backup MX host. See the
    # permit_mx_backup restriction in the file sample-smtpd.cf.
    relay_domains = 192.168.1.1/24
    # INTERNET OR INTRANET
    # The relayhost parameter specifies the default host to send mail to
    # when no entry is matched in the optional transport(5) table. When
    # no relayhost is given, mail is routed directly to the destination.
    # On an intranet, specify the organizational domain name. If your
    # internal DNS uses no MX records, specify the name of the intranet
    # gateway host instead.
    # In the case of SMTP, specify a domain, host, hostort, [host]ort,
    # [address] or [address]ort; the form [host] turns off MX lookups.
    # If you're connected via UUCP, see also the default_transport parameter.
    #relayhost = $mydomain
    #relayhost = gateway.my.domain
    #relayhost = uucphost
    #relayhost = [an.ip.add.ress]
    # REJECTING UNKNOWN LOCAL USERS
    # The local_recipient_maps parameter specifies optional lookup tables
    # with all names (not addresses) of users that are local with respect
    # to $mydestination and $inet_interfaces. If this parameter is
    # defined, then the SMTP server will reject mail for unknown local
    # users.
    # If you use the default Postfix local delivery agent for local
    # delivery, uncomment the definition below.
    # Beware: if the Postfix SMTP server runs chrooted, you may have to
    # copy the passwd (not shadow) database into the jail. This is
    # system dependent.
    #local_recipient_maps = $alias_maps unixasswd.byname
    # INPUT RATE CONTROL
    # The in_flow_delay configuration parameter implements mail input
    # flow control. This feature is turned on by default, although it
    # still needs further development (it's disabled on SCO UNIX due
    # to an SCO bug).
    # A Postfix process will pause for $in_flow_delay seconds before
    # accepting a new message, when the message arrival rate exceeds the
    # message delivery rate. With the default 50 SMTP server process
    # limit, this limits the mail inflow to 50 messages a second more
    # than the number of messages delivered per second.
    # Specify 0 to disable the feature. Valid delays are 0..10.
    #in_flow_delay = 1s
    # ADDRESS REWRITING
    # Insert text from sample-rewrite.cf if you need to do address
    # masquerading.
    # Insert text from sample-canonical.cf if you need to do address
    # rewriting, or if you need username->Firstname.Lastname mapping.
    # ADDRESS REDIRECTION (VIRTUAL DOMAIN)
    # Insert text from sample-virtual.cf if you need virtual domain support.
    # "USER HAS MOVED" BOUNCE MESSAGES
    # Insert text from sample-relocated.cf if you need "user has moved"
    # style bounce messages. Alternatively, you can bounce recipients
    # with an SMTP server access table. See sample-smtpd.cf.
    # TRANSPORT MAP
    # Insert text from sample-transport.cf if you need explicit routing.
    # ALIAS DATABASE
    # The alias_maps parameter specifies the list of alias databases used
    # by the local delivery agent. The default list is system dependent.
    # On systems with NIS, the default is to search the local alias
    # database, then the NIS alias database. See aliases(5) for syntax
    # details.
    # If you change the alias database, run "postalias /etc/aliases" (or
    # wherever your system stores the mail alias file), or simply run
    # "newaliases" to build the necessary DBM or DB file.
    # It will take a minute or so before changes become visible. Use
    # "postfix reload" to eliminate the delay.
    #alias_maps = dbm:/etc/aliases
    #alias_maps = hash:/etc/aliases
    #alias_maps = hash:/etc/aliases, nis:mail.aliases
    #alias_maps = netinfo:/aliases
    # The alias_database parameter specifies the alias database(s) that
    # are built with "newaliases" or "sendmail -bi". This is a separate
    # configuration parameter, because alias_maps (see above) may specify
    # tables that are not necessarily all under control by Postfix.
    #alias_database = dbm:/etc/aliases
    #alias_database = dbm:/etc/mail/aliases
    #alias_database = hash:/etc/aliases
    #alias_database = hash:/etc/aliases, hash:/opt/majordomo/aliases
    # ADDRESS EXTENSIONS (e.g., user+foo)
    # The recipient_delimiter parameter specifies the separator between
    # user names and address extensions (user+foo). See canonical(5),
    # local(8), relocated(5) and virtual(5) for the effects this has on
    # aliases, canonical, virtual, relocated and .forward file lookups.
    # Basically, the software tries user+foo and .forward+foo before
    # trying user and .forward.
    #recipient_delimiter = +
    # DELIVERY TO MAILBOX
    # The home_mailbox parameter specifies the optional pathname of a
    # mailbox file relative to a user's home directory. The default
    # mailbox file is /var/spool/mail/user or /var/mail/user. Specify
    # "Maildir/" for qmail-style delivery (the / is required).
    #home_mailbox = Mailbox
    #home_mailbox = Maildir/
    # The mail_spool_directory parameter specifies the directory where
    # UNIX-style mailboxes are kept. The default setting depends on the
    # system type.
    #mail_spool_directory = /var/mail
    #mail_spool_directory = /var/spool/mail
    # The mailbox_command parameter specifies the optional external
    # command to use instead of mailbox delivery. The command is run as
    # the recipient with proper HOME, SHELL and LOGNAME environment settings.
    # Exception: delivery for root is done as $default_user.
    # Other environment variables of interest: USER (recipient username),
    # EXTENSION (address extension), DOMAIN (domain part of address),
    # and LOCAL (the address localpart).
    # Unlike other Postfix configuration parameters, the mailbox_command
    # parameter is not subjected to $parameter substitutions. This is to
    # make it easier to specify shell syntax (see example below).
    # Avoid shell meta characters because they will force Postfix to run
    # an expensive shell process. Procmail alone is expensive enough.
    # IF YOU USE THIS TO DELIVER MAIL SYSTEM-WIDE, YOU MUST SET UP AN
    # ALIAS THAT FORWARDS MAIL FOR ROOT TO A REAL USER.
    #mailbox_command = /some/where/procmail
    #mailbox_command = /some/where/procmail -a "$EXTENSION"
    # The mailbox_transport specifies the optional transport in master.cf
    # to use after processing aliases and .forward files. This parameter
    # has precedence over the mailbox_command, fallback_transport and
    # luser_relay parameters.
    # Specify a string of the form transport:nexthop, where transport is
    # the name of a mail delivery transport defined in master.cf. The
    # :nexthop part is optional. For more details see the sample transport
    # configuration file.
    #mailbox_transport = lmtp:unix:/file/name
    #mailbox_transport = cyrus
    # The fallback_transport specifies the optional transport in master.cf
    # to use for recipients that are not found in the UNIX passwd database.
    # This parameter has precedence over the luser_relay parameter.
    #fallback_transport = lmtp:unix:/file/name
    #fallback_transport = cyrus
    # The luser_relay parameter specifies an optional destination address
    # for unknown recipients. By default, mail for unknown local recipients
    # is bounced.
    # The following expansions are done on luser_relay: $user (recipient
    # username), $shell (recipient shell), $home (recipient home directory),
    # $recipient (full recipient address), $extension (recipient address
    # extension), $domain (recipient domain), $local (entire recipient
    # localpart), $recipient_delimiter. Specify ${name?value} or
    # ${name:value} to expand value only when $name does (does not) exist.
    # luser_relay works only for the default Postfix local delivery agent.
    #luser_relay = [email protected]
    #luser_relay = admin+$local
    # JUNK MAIL CONTROLS
    # The controls listed here are only a very small subset. See the file
    # sample-smtpd.cf for an elaborate list of anti-UCE controls.
    # The header_checks parameter specifies an optional table with patterns
    # that each logical message header is matched against, including
    # headers that span multiple physical lines. Patterns are matched
    # in the specified order, and the search stops upon the first match.
    # When a pattern matches, what happens next depends on the associated
    # action that is specified in the right-hand side of the table:
    # REJECT the entire message is rejected.
    # REJECT text.... The text is sent to the originator.
    # IGNORE the header line is silently discarded.
    # WARN the header is logged (not rejected) with a warning message.
    # WARN text... as above, and the text is logged, too.
    # These patterns do not apply to MIME headers in the message body.
    # See also the body_checks example in the sample-filter.cf file.
    #header_checks = regexp:/etc/postfix/header_checks
    # FAST ETRN SERVICE
    # Postfix maintains per-destination logfiles with information about
    # deferred mail, so that mail can be flushed quickly with the SMTP
    # "ETRN domain.tld" command, or by executing "sendmail -qRdomain.tld".
    # By default, Postfix maintains deferred mail logfile information
    # only for destinations that Postfix is willing to relay to (as
    # specified in the relay_domains parameter). For other destinations,
    # Postfix attempts to deliver ALL queued mail after receiving the
    # SMTP "ETRN domain.tld" command, or after execution of "sendmail
    # -qRdomain.tld". This can be slow when a lot of mail is queued.
    # The fast_flush_domains parameter controls what destinations are
    # eligible for this "fast ETRN/sendmail -qR" service.
    #fast_flush_domains = $relay_domains
    # SHOW SOFTWARE VERSION OR NOT
    # The smtpd_banner parameter specifies the text that follows the 220
    # code in the SMTP server's greeting banner. Some people like to see
    # the mail version advertised. By default, Postfix shows no version.
    # You MUST specify $myhostname at the start of the text. That is an
    # RFC requirement. Postfix itself does not care.
    smtpd_banner = $myhostname ESMTP $mail_name
    #smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
    # PARALLEL DELIVERY TO THE SAME DESTINATION
    # How many parallel deliveries to the same user or domain? With local
    # delivery, it does not make sense to do massively parallel delivery
    # to the same user, because mailbox updates must happen sequentially,
    # and expensive pipelines in .forward files can cause disasters when
    # too many are run at the same time. With SMTP deliveries, 10
    # simultaneous connections to the same domain could be sufficient to
    # raise eyebrows.
    # Each message delivery transport has its XXX_destination_concurrency_limit
    # parameter. The default is $default_destination_concurrency_limit for
    # most delivery transports. For the local delivery agent the default is 2.
    #local_destination_concurrency_limit = 2
    #default_destination_concurrency_limit = 10
    # DEBUGGING CONTROL
    # The debug_peer_level parameter specifies the increment in verbose
    # logging level when an SMTP client or server host name or address
    # matches a pattern in the debug_peer_list parameter.
    debug_peer_level = 2
    # The debug_peer_list parameter specifies an optional list of domain
    # or network patterns, /file/name patterns or type:name tables. When
    # an SMTP client or server host name or address matches a pattern,
    # increase the verbose logging level by the amount specified in the
    # debug_peer_level parameter.
    #debug_peer_list = 127.0.0.1
    #debug_peer_list = some.domain
    # The debugger_command specifies the external command that is executed
    # when a Postfix daemon program is run with the -D option.
    # Use "command .. & sleep 5" so that the debugger can attach before
    # the process marches on. If you use an X-based debugger, be sure to
    # set up your XAUTHORITY environment variable before starting Postfix.
    debugger_command =
    PATH=/usr/bin:/usr/X11R6/bin
    xxgdb $daemon_directory/$process_name $process_id & sleep 5
    # INSTALL-TIME CONFIGURATION INFORMATION
    # The following parameters are used when installing a new Postfix version.
    # sendmail_path: The full pathname of the Postfix sendmail command.
    # This is the Sendmail-compatible mail posting interface.
    sendmail_path = /usr/sbin/sendmail
    # newaliases_path: The full pathname of the Postfix newaliases command.
    # This is the Sendmail-compatible command to build alias databases.
    newaliases_path = /usr/bin/newaliases
    # mailq_path: The full pathname of the Postfix mailq command. This
    # is the Sendmail-compatible mail queue listing command.
    mailq_path = /usr/bin/mailq
    # setgid_group: The group for mail submission and queue management
    # commands. This must be a group name with a numerical group ID that
    # is not shared with other accounts, not even with the Postfix account.
    setgid_group = postdrop
    # manpage_directory: The location of the Postfix on-line manual pages.
    manpage_directory = /usr/local/man
    # sample_directory: The location of the Postfix sample configuration files.
    sample_directory = /etc/postfix
    # readme_directory: The location of the Postfix README files.
    readme_directory = no
    Padrão Erro Postfix
    e vc adicionou o(s) seu(s) dominio(s) que irão receber email em:
    #/etc/postfix/relay
    depois de salvo não esqueçe de retartar o serviço....
    Padrão Erro Postfix
    Adicionei sim!
    Exemplo
    meudominio.com.br
    Abs
    Padrão Erro Postfix
    Opa...
    altere seu relay_domains, para:
    relay_domains = $mydestination
    restart o postfix...
    Padrão Erro Postfix
    e mantenha o $mydestination como te passei anteriormente....
    t+
    Padrão Erro Postfix
    O erro no meu log agora!
    Jan 11 09:52:42 mail postfix/nqmgr[2170]: C83134FA98: from=<[email protected]>, size=93617, nrcpt=1 (queue active)
    Jan 11 09:52:42 mail postfix/local[2200]: fatal: open database /etc/aliases.db: No such file or directory
    Jan 11 09:52:43 mail postfix/smtpd[2189]: disconnect from adsl.vanet.com.br[200.192.140.24]
    Jan 11 09:52:43 mail postfix/nqmgr[2170]: warning: premature end-of-input from private/local socket while reading input attribute name
    Jan 11 09:52:43 mail postfix/nqmgr[2170]: warning: private/local socket: malformed response
    Jan 11 09:52:43 mail postfix/nqmgr[2170]: warning: transport local failure -- see a previous warning/fatal/panic logfile record for the problem description
    Jan 11 09:52:43 mail postfix/master[2166]: warning: process /usr/libexec/postfix/local pid 2200 exit status 1
    Jan 11 09:52:43 mail postfix/master[2166]: warning: /usr/libexec/postfix/local: bad com
    Padrão Erro Postfix
    Verificou as permissões do arquivo "/etc/aliases.db" ?
    Ele existe ?
    Abraços.
    Padrão Erro Postfix
    Não existe! Qual a função dele? :::
    Padrão Erro Postfix
    Bem, o problema do relay foi resolvido, agora vamos adiante...
    já que não está usando aliases para email, comente a linha:
    #newaliases_path = /usr/bin/newaliases
    t+
    Padrão Erro Postfix
    Blzzzzz agora foi!!
    Não funfou desabilitar a linha
    Tive que copiar o aliases e aliases.db do diretorio do postfix para dentro do /etc.
    Não entendi a moral!
    Verifiquei os logs E NENHUMMMM ERRINHO!
    Bom galera, agradeço a ajuda de todos!
    Valeu mesmo
    Abs
